Author Topic: Mame 130u1 CHD changes  (Read 10068 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: March 19, 2009, 02:37:33 pm »
Oh No! All Chd's need to be updated according to Mamedev.  Can anyone make a batch file to do this?
Thanks for your help,
Southpaw
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
Re: Mame 130u1 CHD changes
« Reply #1 on: March 19, 2009, 03:03:44 pm »
Here's what I've made: Be sure to change the first line to point to the folder that contains the chd folders...my chd folders were all in the 'rom' folder...
And change the line "c:\mame\chdman" to point to your chdman exe. AND USE AT YOUR OWN RISK!
dir /b /s /A:D c:\mame\roms >list.txt
FOR /F "tokens=1" %%A IN (list.txt) do (
   dir /s /b %%A\*.chd > filelist.txt
   FOR /F "tokens=1" %%f IN (filelist.txt)   do (
      c:\mame\chdman -update %%f %%f_n
      del %%f
      move %%f_n %%f
« Last Edit: March 19, 2009, 03:05:25 pm by MKChamp »
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
« Reply #2 on: March 19, 2009, 03:22:42 pm »
Just keep in mind, I don't think there is a way to 'go back' once you've updated your CHD files - so those who enjoy a certain functionality or speed of a pre-0.130 build might want to only update when the game is needed (or tuck the old CHD's somewhere "in case")
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: March 19, 2009, 04:23:22 pm »
Does MK's HS.diff file also eliminate the new error for CHD's from appearing?  If so,  I won't even bother updating.
MKChamp
  • Stil around.
« Reply #4 on: March 19, 2009, 05:46:41 pm »
Yep...no error messages.
Dariusz
  • Last login:November 23, 2018, 02:41:36 pm
« Reply #5 on: March 31, 2009, 06:39:12 am »
Hi All,
Do all the CHD's including the LD's need to be updated from Mame 130?
If so, what is the best way to convert all the CHD's? Is it by using a batch file? or are there other options?
If the batch file is the only option, Is there a batch file which someone can provide that:
Reads the original CHD's from one directory (without modifying the CDS's), and converts the CHD's to a destination directory?
BTW. My CHD are in root subdirectories and not in the root rom folder itself.
Any feedback is kindly appreciated,
Dariusz
