Author Topic: How well does Tekken and Virtua fighter run in MAME?  (Read 5654 times)
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« on: March 17, 2009, 03:38:56 pm »
I was playing VF in my version .110 mame the other night, and though it's playable, it has noticeable tearing. Is the .128 version better? Same query for Tekken.
(I know this has likely been addressed before, but I'm at work, and my searching abilities are limited ATM...)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Bender
Re: How well does Tekken and Virtua fighter run in MAME?
« Reply #1 on: March 17, 2009, 04:25:58 pm »
both seem to run pretty well on a 64 bit system
couldn't even get Tekken to load on the same computer running a 32 bit os
ViciousXUSMC
  • Last login:July 28, 2009, 10:25:53 am
« Reply #2 on: March 17, 2009, 05:13:06 pm »
I never tried :P so just tried it.
Tekken
Tekken 2
Tekken 3
All 3 loaded, and ran fine under .129 full speed with no probems at all under x86, I did not use or need x64 so do not think its a requirement, I guess it may help if your computer is slower.
However all 3 games get a "yellow" mame menu noting they have emulation problems.  Says video & sound are not 100%  video looked fine but the sound I could tell the announcer voice was kind of muted & muffled some.
Very playable though.
Edit: Version does matter
I just tried .117 since I keep it around for my Wiimote (wiimote wont work with later versions) and Tekken 3 was in slow motion :P
« Last Edit: March 17, 2009, 05:15:29 pm by ViciousXUSMC »
BASS!
  • Just have fun.
« Reply #3 on: March 17, 2009, 05:36:41 pm »
Just load zinc and get that running. It even uses your graphics card!
TelcoLou
« Reply #4 on: March 17, 2009, 05:46:24 pm »
... I tried. It gave me a headache  :laugh2:
Thanks for the replies folks, I'll get the .128 versions of both games and try it out when I get home tonight, or maybe tomorrow morning.
ViciousXUSMC
« Reply #5 on: March 17, 2009, 05:48:51 pm »
Just got Zinc, it says in the readme that it has sound & even speed emulation problems for stuff too.
I have not tried it out yet though.
dreamakuma
  • Last login:July 08, 2010, 02:14:54 am
« Reply #6 on: March 17, 2009, 05:53:14 pm »
after I upgraded from 0.81 to 0.103 I have tekken, virtua fighter, beasterizer, street fighter EX and EX plus, and battle arena toshinden, running playable. sound issues pop up and a few small issues with EX(characters will dissapear and respawn on the other side of the screen.) But very playable.
Newbie in working on cabs, expert in playing, breaking, moving slowly, and overall failing at them too.
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #7 on: March 17, 2009, 05:55:35 pm »
If I recall correctly, the past few versions of MAME have made some big advances with the PSX based games like Tekken, so you're probably on the right track using that version.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
ViciousXUSMC
« Reply #8 on: March 17, 2009, 06:10:02 pm »
Zinc was a no go for me, have not quite figured out how to get the renderer path set, tried a GUI and it says my roms are not there even tho I set the directory and the same ones work in mame.
Guess I will stick with mame.
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« Reply #9 on: March 17, 2009, 11:58:28 pm »
I run Tekken 2 on mine with a Pent 1.6, gig of ram, using Mame .129. It is playable but surely not full speed. I really don't have a point of reference, tho, because I really didn't play that one a lot.
ViciousXUSMC
« Reply #10 on: March 18, 2009, 01:20:47 am »
For reference its full speed on my cpu a Q6600 @ 3.6ghz
I have the multi-core flag on in mame but I think it only uses 2 cores not all 4.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #11 on: March 18, 2009, 08:24:27 am »
I just use the "PSX" emulator with the ISOs.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #12 on: March 18, 2009, 09:02:16 am »
Snap. Better speed at low spec, more options for gameplay... pisses on the arcade versions. Same goes for Soul Edge, SF EX, Rival Schools...... need I go on?
ViciousXUSMC
« Reply #13 on: March 18, 2009, 03:33:12 pm »
Yeah but you lose that insert credits now message :P
Same applies for a lot of games actually, not sure why anybody likes it but MK4 was another game that people have trouble with, and the best solution was MK Gold for dreamcast.
For me just using my computer to emulate its all the same, for somebody with a cab and some kind of front end that they like where its all loaded into one thing and easy to use via the arcade controls I can see why they may push to get the mame version working instead of adopting the consoles version.
ivwshane
    • My first mame cab! (WIP)
« Reply #14 on: March 18, 2009, 03:42:16 pm »
If you guys aren't posting your pc specs then it's hard to gauge a games playability.
TelcoLou
« Reply #15 on: March 18, 2009, 04:07:15 pm »
Report:
Got my .128 versions and Tekken 1 plays damn-near perfect, as far as I can tell. No noticeable tearing, gameplay is nice and smooth.
Virtua Fighter is better, but still seeing some polygon tearing and randomly appearing triangles, but very playable.
Oh my specs are WinXP home, P4 @3ghz, 2GB RAM, and a 256mb Radeon gfx card.
I may give the PSX emu a go ... some day.
Thanks for all the help folks  8)
