Author Topic: Unfavorite Front End?  (Read 3299 times)
Ummon
  • Trade Count: (+13)
« on: March 17, 2009, 01:19:22 am »
Instead of saying why you like one or the other, tell what you don't like. For example:
Maximus Arcade:
- supposed to support old Mame32 gamelist ini - but doesn't.
- no feature to set ambience directory, etc, so you have to dig in the help file to find out there's a file that you just put everything in. Um, hmm.
- theme editor seems made for those familiar with business-level image editing programs. Also, for some totally weird-ass reason, MA crops the corners of the image.
- OH, and that sneaky thing he does to your system in that makes you have to purchase it, regardless of taking it off. I think this expires in a year, because I was....finally...able to try it out again without buying it. Of course, as I'm having issues with easily getting it how I'd like, the trial date's probably going to expire before I handle them.
(I dunno, maybe the issues I have with FEs are rare. Wouldn't surprise me, actually.)
« Last Edit: March 17, 2009, 01:25:24 am by Ummon »
Yo. Chocolate.
Stephen Hawking
headkaze
  • 0x2b|~0x2b?
Re: Unfavorite Front End?
« Reply #1 on: March 17, 2009, 02:44:43 am »
Bit negative doncha thing? Maybe you could change it to "What would you like to see if your favourite FE?"
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: March 17, 2009, 05:07:54 am »
Yes, that's a bit negative.
Mainly speaking about feature.  Often Features exist but sometime are simply not found but the user.
It is hard nowaday to master completly a front end. They can do so much things.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: March 17, 2009, 08:13:02 am »
Getting your FE of choice to work 'exactly' how you want can take some time. Youki is dead-on, FE's are complex with many config options. Most FE devs strive to make the setup as easy as possible - but a basic law of software says; flexibility = complexity.
Robots will kill you.
Arcade Addiction
tspeirs
  • Last login:July 23, 2020, 07:44:52 am
« Reply #4 on: March 17, 2009, 08:48:17 am »
Exactly, I am constantly troubled by this with GameEx. Trying to make it simple but powerful at the same time. Even driven to the point of thinking about a deriverative build. Actually Id give credit to Maximus Arcade for doing that quite well. Although in the end, might be a year or more, once they get tired of it, will want more power from a front end. I mean the funnest part was building and setting up our arcade machines right?
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: March 17, 2009, 09:10:51 am »
There are a few threads asking about this sort of thing, and I think it's pretty evenly divided between tinkerers and gamers.
How often do you play your Mame cab?
how many play there cab alot, or got fed up with it?
Probably more threads like that too.
TOK
  • The Game Always Wins
« Reply #6 on: March 17, 2009, 09:27:33 am »
I enjoy building, and I know videos, spinning menus and music appeal to a lot of people but I want the fastest speed and least involvement with a front end possible. Screenshots to help pick out new games to try are about the only extra I like.
Probably puritanical thinking to many, but console games and all that other stuff seem out of place to me on an arcade cab.
Every front end I've tried has nice aspects, even MAME32 (or MAME UI now), but I use a stripped down version of XP and no-frills setup of MaLa.
youki
    • Atomic Front End
« Reply #7 on: March 17, 2009, 09:44:30 am »
Each user is different and want different things , it is the problem.  more you try to cover all users needs more your FE becomes complex to  configure  and for a Dev it is very hard to comprise  between power , flexibility and easibility...
As tspeir , i was thinking of doing different release , like for a car manufacturer you have different model car .  I think to do the same things for the FE.
Front End todays are like big trucks they can carry lot of things. But if you need just to carry a boxe of bubble gums , of course you can use a truck ... but may be a motorbike could be enough...
Goatz18
  • Last login:September 06, 2021, 06:53:51 pm
  • The Bringer of Destruction and Doom!
    • Arcade Project Alpha
« Reply #8 on: March 17, 2009, 01:33:00 pm »
Yeah, I have customized my FE a bit and I'm like "That looks pretty good." Then I watch a video of what someone else did with the same FE and I'm like "My setup sucks, how did he do that?"
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #9 on: March 17, 2009, 04:00:32 pm »
MAME UI. Looks too much like a Windoze app than a front-end  8)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Ummon
« Reply #10 on: March 18, 2009, 05:56:31 pm »
You know, I sometimes like that look. I wouldn't call it an FE, though. It's just a convenience, really, with some visual appeal to me.
Depends on how serious one is about the topic an all. I was using somewhat affective language in introducing and relating a topic. And it elicited a plethora of responses, mostly informative. Regardless, the issues I pointed out are in fact issues that can seriously detract from the experience of setting things up, let alone enjoying the use of the FE. And however anyone else wishes to express (on) it, that's what this thread is about.
Here's some things about GameEx (perhaps my favorite potential FE) that have always confounded me:
- can't specify more than one track for ambience...at least not easily. That is, where in others, you simply specify a directory, GE makes you select one track.
- VP and Daphne are not plug and play.
- I've never been able to get all my games showing in their respective lists when using the mame32 folders ini. (It occurs to me that maybe, for some inconceivable reason, MameUI will work differently? I'll try that. Still, the above issues are significant.)
Yo. Chocolate.
Stephen Hawking
tspeirs
« Reply #11 on: March 18, 2009, 06:26:52 pm »
Thats the thing and sums up with this thread has turned into about exactly, as per your first point about GameEx. You can in fact easily specify a playlist folder, its just that folks dont know how to do it! Albeit it wasnt working until recently due to a bug :)
OK maybe your right about your post, perhaps negativity is not the word, but I would not say it was productive. Most FE Authors and I know Youki for sure, try to please everyone with what they need from a front end.
« Last Edit: March 18, 2009, 06:35:03 pm by tspeirs »
lingpanda
  • Last login:May 16, 2010, 01:43:52 pm
« Reply #12 on: March 18, 2009, 10:14:40 pm »
Tom,
How close have you come to saying enough is enough? As in no more GE updates? I can't believe you still update as frequent as you do. I do appreciate all your hard work and GE is my frontend of choice to this day.
tspeirs
« Reply #13 on: March 19, 2009, 01:35:26 am »
Im probably seeking an unrealistic perfection, and have not considered stopping. Although I am currently running short on new things I want to do with it, other than improving what it already does.
Ummon
« Reply #14 on: March 20, 2009, 11:30:36 pm »
I know they do, in general at least. It's certainly the same as any project, in that the development is relative to the interests of those developing. And for the most part, I think those and the general public's are met. Mine aren't, and that's why I'm posting, but I'm not upset about it.
Regarding the ambience path setting, in my experience it is automatic, in that you set the path, or you have to click on a file in the path. If you meant that, all this time, it was supposed to allow a folder but wasn't, well one down and one closer to using it.
Yo. Chocolate.
Stephen Hawking
BASS!
  • Just have fun.
« Reply #15 on: March 21, 2009, 12:20:44 am »
Have you given the new version a try yet? He has managed to do some serious bug fixing lately :)
loadman
    • MaLa
« Reply #16 on: March 21, 2009, 02:41:14 am »
Not cool.   :'(
Ummon
« Reply #17 on: March 21, 2009, 04:48:26 am »
New version of?
Not cool.   :'(
Actually, knowing things that aren't functioning helps in making them better. Negative/affirmative, rather than 'positive/negative'.
Yo. Chocolate.
Stephen Hawking
BASS!
  • Just have fun.
« Reply #18 on: March 21, 2009, 09:32:41 pm »
The new version of maximus.
Ummon
« Reply #19 on: March 23, 2009, 03:54:29 pm »
Mmm. I have it, and have played with it a little, and the issues I mentioned above are in response to that experience in particular.
Yo. Chocolate.
Stephen Hawking
youki
    • Atomic Front End
« Reply #20 on: March 24, 2009, 04:44:49 am »
Did you post your issue on their support forums?
BASS!
  • Just have fun.
« Reply #21 on: March 25, 2009, 05:23:36 am »
Yeah, delusional is the mod on that forum. I would give him a pm and see if he can talk to mameseer about your issue. He is one of the few people who can get him on the line if he wants. That guys a really stand up person, very helpful:-)
Ummon
« Reply #22 on: March 25, 2009, 04:51:10 pm »
Actually, over a year ago...pehaps more....I added these into the 'feature suggestions/bug complaints' part of that forum, and it seems they didn't make it into the versions since. But I'll holler over there again.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #23 on: March 26, 2009, 03:38:31 am »
You know, I forgot that one of the things about MA is it's 'cabinet' interface. If you get rid of those images, it's apparently hard-coded to use them and will ---smurfette--- about them not being there, etc.
Yo. Chocolate.
Stephen Hawking
