Author Topic: hanterex polo not powering up  (Read 1365 times)
bulge2
  • Last login:October 07, 2019, 08:29:55 am
« on: March 16, 2009, 04:07:15 pm »
hi
ive got a hanterex polo 25" which is about 5 years old. it was working perfectly before the cabinet was moved from one location to another (on a truck).  I havent put any dodgy power through it and there is some signs of life:
when i power up the cabinet i can hear a quiet ticking sound coming from the circuit board (underneath the metal cage in the picture)- the monitor doesnt buzz and power up at all.  the tick is about once a second or two? ive had a look around and cant see anything obvious
heres a piccy of the monitor
i unplugged the power and video to get a better photo - they are plugged in
help!
« Last Edit: March 16, 2009, 04:22:09 pm by bulge2 »
Kevin Mullins
    • Me on Myspace
Re: hanterex polo not powering up
« Reply #1 on: March 16, 2009, 04:36:12 pm »
First thing I would do is fix that fuse holder that's kinda jacked up.
bulge2
« Reply #2 on: March 16, 2009, 05:06:59 pm »
thats been done - i took it out to check it was ok
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: March 16, 2009, 10:51:31 pm »
normally if it has a smps , the tick would likely be caused by a shorted component .
hot , or secondary diodes are common failures.
being trucked , it may have encountered some rough handling in transit .
or the failure could simply be coincidence... :dunno
a visual inspection is the first step, with some components checks to follow....
qrz
