November 21, 2009, 06:08:45 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Sounds cuts out in Xmame  (Read 677 times)
escher
Trade Count: (0)
Full Member
Offline Offline
Out of the game for way too long
View Profile
« on: March 14, 2009, 07:24:10 PM »
Just what the topic says.  I'm using Wah!cade, though I've tested it straight from the command line and the same thing happens.  Sometimes it'll be a minute into a game, sometimes it'll be 10, but at some point the sound always completely cuts out.  I've tried searching around, but everything I'm finding is either mame related (not xmame) or extremely ancient.
The command I'm running, with all arguments, is:
xmame -jt 1 -jdev /dev/input/js0 -fullscreen -vidmod 1 [game]
I'm still sort of new at Linux, though I know my way around a bash shell just fine.  Any suggestions?
Logged
escher
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1 on: March 14, 2009, 11:05:29 PM »
Well, I've switched over to SDLMAME, and I still have sound issues.  This time, it's just that everything is very crackly, but I haven't had it cut out on me...
Logged
tikbalang
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #2 on: March 16, 2009, 08:23:00 AM »
a similar thing happened to me, but in DOS and using advancemame. i used an all-in-one mobo with built-in everything. everything works fine until i load big games (kof2003, mslug5) and then there is no sound anymore, even after i comeback to advmenu.
for some reasons, i solved it when i used a separate video card. i don't know if it work the same with linux.
Logged
jerryjanis
Trade Count: (0)
Full Member
Offline Offline
Skate or Die!!!
View Profile WWW
« Reply #3 on: May 09, 2009, 09:10:59 AM »
I have found the same with SDLMame.  I tried it on several computers (both Linux and Windows XP), but I found the sound to be really crackly.  Unfortunately I did not find a fix to the problem, although the version I'm using is likely several months old at this point.  I was actually planning on switching to XMame, since an old version of XMame that I used to use did not have sound problems.
Logged
Quinny
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #4 on: June 01, 2009, 08:47:12 AM »
This maybe isn't helpful but I had issues in Ubuntu getting my onboard gfx to work (it was very slow). Once I got this sorted, the sound in sdlmame was delayed by split seconds and was very frustrating. I tinkered with the sound and reduced the sound delay but could not get rid of it completely.
If you are having issues with sound in sdlmame, how is the sound output from the O/S? Are there any other apps that can play sound that you could test with?
Also, my sound delay issue was with pulseaudio. I followed some instructions to disable it and to use alsa. I am using onboard sound too.
Logged
bloodyviking77
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #5 on: July 31, 2009, 06:24:46 AM »
what version of SDLMAME are you running and on what hardware?
I've found that as the hardware requirements of newer versions of MAME (since about .106) have steadily outstripped my supply of free/salvaged/junk PCs that I have used for my cabs.
If your hardware is on the aged side, I'd suggest trying an older version of SDLMAME, or alternatively AdvanceMAME.
Logged
Shut up! Bloody Vikings!!
escher
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #6 on: July 31, 2009, 03:01:30 PM »
Yeah, I eventually gave up.  I pretty much trace all my problems to being an early Athlon 64 chip and an ATi video card.  Everything works fine under WinXP, so that's what I'm using for now.  When I rebuild the machine (hopefully soon), I'm going to be more careful in my hardware choices.
Logged
Arbee
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #7 on: September 18, 2009, 10:12:17 PM »
On recent distros based on PulseAudio crackling and other sound issues in SDLMAME can generally be resolved with either "-audiodriver alsa" or "-audiodriver esd".
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.269 seconds with 23 queries.
