July 29, 2010, 09:50:43 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
mamemarquees.com is now gameongrafix.com - new name, same great products and more! Click to see what's new!
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend controls.dat
Maximus Arcade Old Boards Old Archives
Unread posts | New Replies | Recent posts | Arcade | Rules | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: ANNC: Seesaw Circus - Beta 2 (now fully playable with hiscore and skinable)  (Read 830 times)
Space Fractal
Wiki Master
Trade Count: (+1)
Full Member
Offline Offline
Space Fractal
View Profile WWW
« on: March 14, 2009, 08:56:53 AM »
Also released at: http://greatflash.co.uk/index.php?topic=159.msg1212#msg1212
Download:
http://www.spacefractal.com/seasawcircus/SeasawCircus_v2.0_beta2.zip
Here is the text from the read-me (JUST UPDATED):
SEESAW CIRCUS:
Freeware with Blitz Max source code included.
No warranty.
Version 2.0 Beta 2
- Second Release (see source code for changes)
Purpose:
 - A Little remark from a old arcade game by Exidy (you can find the Rom's on MAME site).
 - Since it a version 2.0, This because I (Space Fractal) have created a java version,
  of the same name. I do have renamed this game to "Seesaw Circus" for easier search.
 - A 100% cabinet friendly game without any onscreen config or such (config.ini).
 - This game is released as GNU and hence all source code is included.
Control:
 - Mouse, Spinner (X axis only)
  If you press LEFT BUTTON to start a new game, the game autochange the control to
  the mouse and disable joystick in that game. LEFT BUTTON is used to switch side on
  your seesaw.
 - Analog Joystick (A harder game):
  If you press any JOYSTICK BUTTON to start a new game, that button would been auto
  assigned as your switch button to turn around your seesaw (and disable the mouse).
  The game does also auto change the joystick port, you have pressed that
  JOYSTICK BUTTON to. BTW you can play the game using PL2 analog joystick, as long
  the button is also used the port too.
   = A Perfect game, if you do not have a trackball, but have a UltraStick
    (Ultimarc) instead. Remember to change it status to analog before play.
THERE ARE NO JOYSTICK MODE SETTING IN CONFIG, DUE IT AUTO CHANGE AUTOMATIC BETHEEN
JOYSTICK AND MOUSE. HINCE IT NOT INCLUDED THAT SETTING IN CONFIG.INI
Credits & Quit:
 - Credits and Quit is assigned to same key as the arcade emulator MAME does.
  "5" to add one credit (as default, changeable)
  "6" to add two credits (as default, changeable)
  ESCAPE to QUIT directly (but save hiscore etc).
  These keys are NOT remmap able, but since these are so called M.A.M.E (TM) defaults,
  you should have no problems to fit it on your M.A.M.E. cab.
  PL1 Start is NOT used on this game, hence it can autochange MOUSE / JOYSTICK mode.
Config:
 Open config.ini in your notepad application and change to feed your need. There are
 description, what they does.
Released to:
 Build Your Own Arcade Controls (http://www.arcadecontrols.com)
Changes Since First version (taken directly from source code):
'     - Hiscore now works fully.
'     - Retouched sprites to hires graphics, but keep the retro.
'     - Possisible to add own graphics as a new skin.
'     - Changed the logo, but could been better (but works in classic skin).
'     - Added a widescreen option in config.ini.
'     - More forgivement collection detection of the seesaw middle.
'   !!! FULLY PLAYABLE GAME NOW WITH HISCORE !!!!
'    WHAT MISSING:
'     - A Enhanced graphics mode (why I created possible for skins).
'     - Enhached Graphics mode (as long with the classic mode).
'     - Better hiscore inserting, but works fine.
'     - Sound FX.
Best Regards by
Space Fractal
Logged
Software Projects: MultiFE (Jukebox/Game frontend) :: Seesaw Circus (a little game for spinner)
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.259 seconds with 12 queries.
