Author Topic: Still problems with MameWah  (Read 2350 times)
Dariusz Friedel
« on: March 01, 2002, 06:16:22 am »
Posted by Dariusz Friedel on February 28, 2002 at 01:07:22:
In Reply to: Re: MameWah Problem - Cannot run posted by Peeper on February 26, 2002 at 12:21:46:
I still get the problem happening. Cuold it be that there is a bug in the source code of MameWah?
I've tried the following in detail:
1. Attempted to remove gvbox by:
C:\WINDOWS\SYSTEM\Regsvr32.exe c:\here\gvbox.ocx
where c:\here\gvbox.ocx is replaced with the actual file location.
2. Then deleting the files of the HD.
When doing 1 above I get the following error message:
LoadLibrary ('C:\windows/gvbox.ocx') failed. GetLastError returns 0x00000485.
I reinstall MameWah and still get the error messages as outlined in my original post.
I then decide to manualy remove gvbox from the registed by regedit.exe by searching all entrees of gvbox in the register and deleting them.
Once I reinstall MameWah I again get the old error message again?
Is there any one that can help me. Is the a problem with MameWah or with my computer?
Please help as I would like to test MameWah.
Kind REgards
Dariusz
: : I am hoping the there is some one that can help me here, as i would like to test an alternative front-end to ArcadeOS.
: : I have downloaded the letest version of MameWah (0.893). When installing, I get the following message:
: : 'An error occured while registering the file 'c:\windows\system\gvbox.ocx''
: : I get the option to Abort, Reentry or Ignore. The only option the allows we to preceed is Ignore.
: : Once the installation is finnished, and I run MameWah, I get the following error which cancels ManeWah from running. Error is:
: : 'Component 'gvbox.ocx' or one of its dependencies not correctly registered: a file is missing or invalid'.
: Try this:
: Find out where the gvbox.ocx file is located (let's assume c:\here\gvbox.ocx for this example).
: Go to The start bar, hit File, Run, and type in:
: C:\WINDOWS\SYSTEM\Regsvr32.exe c:\here\gvbox.ocx
: where c:\here\gvbox.ocx is replaced with the actual file location.
: Hopefully you'll get a registration succeeded message, and be able to run the program...
: Good Luck!!
: : Has some one had this problem before?
: : What would be the solution to get MameWah running?
: : (Note: after the first instalation I had deleted the file gvbox.ocx, and re-tried the installation again, but got the same problem. I run win98 on a P133.)
: : Any sugestions would me kindly appreciated.
: : Dariusz
Smack
Hmm. Not Sure, works for me.
« Reply #1 on: March 04, 2002, 01:04:47 pm »
That one stumps me. I just installed the newest version of MAMEwah (to try it for the first time) I havent' had any such errors with mine. (1gz PIII under Win98)
