Author Topic: E-Touch (Formally Freebox) V5.00.30 Released (DEMO LINKED IN POST)  (Read 29221 times)
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
V5.00.30
Main App:
BUG: Key Higlighting showed even if keys were disabled (FIXED)
BUG: If there is no genre folder then the creation of most played fails on load (FIXED)
BUG: Tracklisting GIF was faded with fanart (FIXED)
BUG: In credit mode the back button was hidden on play options if you had no credit (FIXED)
BUG: If you had no credit and play options showed costing label didn't clear after adding credit (FIXED)
BUG: When no songs were playing the now playing info didn't clear (FIXED)
BUG: Burn CD Crashed out if there were no files in the download folder (FIXED)
BUG: Compilation albums didn't show correctly when selected from Top10 (FIXED)
BUG: Compilation albums didn't show correctly when selected from History (FIXED)
BUG: Path didn't always set correctly for NETWORK QUE Files. (FIXED)
BUG: Compilation albums didn't show correctly in Most Played (Popular) (FIXED)
BUG: The most played button now works correctly, it is ordered by artist not popularity so the slider works
BUG: Shuffle queue on play didn't work (FIXED)
BUG: Download Album and Track didn't read tags other than MP3 (FIXED)
BUG: Download track didn't copy .CDG part for karaoke (FIXED)
BUG: Days to show new graphic didn't save (FIXED)
BUG: Add All to queue button shows up if you page the tracklisting and have no credits (FIXED)
BUG: Add all to queue button shows on search results screen with no credits but it doesn't work (FIXED)
BUG: Duration slider and time didn't work on dual screen (FIXED)
BUG: Track listing didn't show correctly when paged if using filenames. (FIXED)
BUG: Random play delay between tracks effects queue (FIXED)
BUG: Default.jpg for fanart didn't show on now playing screen (FIXED)
BUG: If add all to queue was disabled it would still show for non commercial users (FIXED)
BUG: Fanart and Animated GIF on same screen caused timer issues (FIXED)
BUG: using Terminal and master the master tried to charge again for songs supplied from the termial (FIXED)
BUG: Terminal didn't show the queue from the master (FIXED)
BUG: When using filenames for tracklist the file extension was shown (FIXED)
BUG: Master assumed play now for songs from the terminal (FIXED)
BUG: If CDG file was present with MP3 Media type was shown as audio not karaoke  (FIXED)
BUG: Save Queue on shutdown causes the queue to load last song played on restart (FIXED)
BUG: If you select the video availble button it switches to video DB. (FIXED)
BUG: If using filename for track listing tack time didn't clear. (FIXED)
BUG: Download ALBUM was broken (FIXED)
ADDED: If no tag is found it will attempt to do it from the filename the same as the config does.
ADDED: Terminal should now show the queue from the master
ADDED: Terminal should now show now playing info, also can click the cover on now playing screen
ADDED: load default.jpg for fanart if fanart isn't found
ADDED: Support for GIF On tracklisting page "tracklist.gif"
ADDED: Support for GIF On Top10 page "top10.gif"
ADDED: Support for GIF On genre page "genre.gif"
ADDED: /d command line flag now shows a debug window.
ADDED: Click cover in tracklist view to display back cover if found (Filenmae set in options)
ADDED: Most_played.cvr is now generated on load and should work.
ADDED: Random play can now be set to use the most played (Popular)
ADDED: Ability to turn off track highlighting when using key inputs.
CHANGED: Whole back end has changed fixing a lot of things, hope it's not broken anything.
I also tidied up some things in the main app to help things run a little smoother.
Config:
BUG: Number of days to consider new didn't save (FIXED)
BUG: Genres didn't build correctly using UPDATE (FIXED)
ADDED: Ability to attempt autotag from path using artist\album\track
ADDED: Ability to continue album cover download from where you left off last time.
Skintool:
BUG: Numerous bug fixes where align, shift and copy styles didn't work.
BUG: Animated Gif on Top 10 couldn't be moved (FIXED)
BUG: Some animated gifs' didn't preview (FIXED)
BUG: Covers on history screen were bound by another screen (FIXED)
BUG: Caption couldn't be changed on some options buttons (FIXED)
BUG: Make Same Size, Copy Styles etc missed Animation Setting button (FIXED)
ADDED: Ability to position main windows by entering Co-Ordinates
History Editor:
ADDED: Remove missing files
ADDED: Support for new History file format.
ADDED: Remap drive letter.
ADDED: Box for Compilation Type.
ADDED: Box for Media Type.
ADDED: Populate boxes for editing on track selection.
Forum release thred: http://www.freeboxjukebox.com/Forum/index.php?topic=2207.0
Notes:
As always a fresh install is recommended due to several file changes. Most noticably the history files however there is an app called History_Edit you can use to upgrade your files. Click on Load V1 History or V2 history depending on how long it has been since you upgraded. You will know when you have selected theright one as your history should look correct in the bottom display. Then click save and it will be saved out in the new format. It is important you do that before playing any new song otherwise you may corrupt the file.
V5.00.28
Main App:
BUG: Key shortcuts on Top20 let you go 2 past the last entry (FIXED)
BUG: Do not repeat artist for X songs in random didn't work (FIXED)
BUG: Do not repeat song for X songs in random didn't work (FIXED)
BUG: Random play on top10 crashed if it was empty. (FIXED)
BUG: Weighting could crash jukebox (FIXED)
BUG: If weighting wasn't set then it could crash (FIXED)
BUG: Download Album only gave album name for folder not artist name as well (FIXED)
BUG: Download.bat wouldn't be called on download album (FIXED)
CHANGED: Setting weighting doesn't need the option checked and unchecked
ADDED: Key Shortcuts now let you choose songs on top20.
ADDED: Random Play weighting to enable more customisation
ADDED: Auto populate genres,years and artists with those in the top10
ADDED: Improved Tag Support
ADDED: Ability to have a download.bat int he download folder, this is called when a track is downloaded.
Skintool:
BUG: Some buttons couldn't be moved down on the decades screen (FIXED)
Config:
BUG: Update was sorting the list wrong (FIXED)
BUG: Update didn't work correctly (FIXED)
CHANGED: Shouldn't have to close config between building libraries
ADDED: Close button added on get album cover screen
ADDED: Tag Support added for the following using Audiogenie:
    * Musepack Audiofiles / MPEGPLUS
    * Monkey's Audiofiles
    * Windows Wavefiles
    * FLAC Audiofiles
    * OggVorbis Audiofiles
    * AAC Files
    * WMA Files
    * MP4/M4A Files
NOTE:
A Fresh install is recommened due to the amount of changes made.
« Last Edit: February 16, 2010, 06:15:09 am by Barry Barcrest »
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
Re: E-Touch (Formally Freebox) V5 Released
« Reply #1 on: March 12, 2009, 07:16:39 am »
Very Nice!  :cheers:
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
BobA
  • What Me Worry?
« Reply #2 on: March 12, 2009, 01:12:27 pm »
Thanks for all the work on your renamed program.   I installed it on Vista Home Prem and it went thru the config and found my music files but when I run the program and play a song and I get the following error.  The song starts playing and the following error is shown.
Run-time error 75
Path/File access error
E-touch Jukebox has stopped working.
Bob
kizer
    • Links4jeeps.com
« Reply #3 on: March 12, 2009, 01:15:49 pm »
Isn't it funny. A ton of time beta testing and the day it comes out there is a bug. ;) Barcrest is all over it now trying to figure it out.
Fan Art rocks. Thanks Barcrest for listening to my request. ;)
How did I get it to work? I threw up the ACDC.jpg file in the same folder as the FanArt and guess what it reads it and wham. Just make sure that the artist name for the image is spelled the same way as the artist.cvr file.
I'll throw up a link for some fan art for download at 1280x or better resolution for this demo. It autoscales so it fits very well and looks nice.
Visitor Q
  • The Saw Is Family
« Reply #4 on: March 12, 2009, 03:57:25 pm »
That does not work per artist though does it? The custom backrounds...
kizer
    • Links4jeeps.com
« Reply #5 on: March 12, 2009, 05:10:58 pm »
Yes per Artist. Heres A Few. Please forgive the hard to see track listings. This was a farther back beta when artist image wasn't dimmed and the tracks where not brough to the front. From what I recall Barcrest is going to set the transperancy so you can brighten and dim the artist image.
AeroSmith
Perfect Circle
Like I said up above. Just take your images and make sure they are named the same as the .CVR files are for artist and put them in the FanArt folder. For example up above its.
AeroSmith.jpg that goes with the AeroSmith.cvr, PerfectCricle.jpg that goes with PerfectCircle.cvr
Keep in mind if you do not use a background the background defaults to black like it always has.
« Last Edit: March 12, 2009, 05:14:38 pm by kizer »
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
How to Use Fan Art
« Reply #6 on: March 12, 2009, 11:41:07 pm »
I just thought I'd pass this along with regard to E-Touch and the use of Fan Art.
In the file where you decided to place E-Touch to install to, chances are you used the default
c:\Program Files\E-Touch Jukebox
You will find a folder called 'Fanart'
Just place a .jpg of your choice in the c:\Program Files\E-Touch Jukebox\fanart folder.
IT MUST BE THE SAME AS THE ARTIST FOLDER NAME AS TO WHERE YOU PLACED YOUR MUSIC!
Example: If you placed your music in c:\my music\ACDC then the .jpg in the 'Fanart' folder should be ACDC.jpg or Aerosmith should be Aerosmith.jpg
Then after running the config to update and load your albumns, start up E-Touch Jukebox
Then after starting up, Press the <ESC> key to got the Configuration Screen.
UNDER THE 'Button Settings' BUTTON, OVER IN THE BOTTOM RIGHT CORNER, THERE IS A SECTION CALLED 'FAN ART'. YOU HAVE TO CHECK THE BOXES FOR WHERE YOU WANT THE FAN ART TO APPEAR
ALSO THERE IS A SLIDER UNDER THE CHECK BOXES FOR TRANSPERANCY. MOVE THE SLIDER TO YOUR TASTE
*** In future releases the Fan Art Slider should be labeled for what it is used for. It had taken me 20 minutes  :angry:   :banghead: to finally use the slider. Just my Opinion ***
Click the 'Save Settings' button, then the 'Back' button.
Then select an albumn you know you have placed a .jpg for in the 'Fanart' folder.
There you should see your Fan Art in action! ;D
Hopefully this has helped!   :cheers:
Fordman
« Last Edit: March 12, 2009, 11:43:07 pm by Fordman »
  • Last login:February 04, 2026, 05:27:25 pm
« Reply #7 on: March 13, 2009, 02:00:03 am »
 :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« Reply #8 on: March 13, 2009, 12:25:38 pm »
This is awsome thanks Barry!  How do you get the decade/Chart to work?  Every time I click it is says chart not found.
BobA
  • What Me Worry?
« Reply #9 on: March 13, 2009, 12:36:29 pm »
Run-time error 75
Bob
Update:
I installed it on my Windows 7 system in Vista compatibility mode and it had an error in the config.   I was using a small version of my music file so I deleted all the albums that had no MP3 info and the program was able to finish the config and run.
Update2:
Got my Vista install working.   Ran E-touch as Admin and the error went away.  Setting up the compat mode in Windows 7 reminded me to run it as Admin.
Update3:
Installed E-Touch on my touch screen juke that runs XP SP3.   Installed without a hicupp.   Great work Barry.  Will give it a good tryout on the working juke.
« Last Edit: March 13, 2009, 02:00:43 pm by BobA »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #10 on: March 13, 2009, 01:58:52 pm »
click on a year and go back and it will work. It defaults to the current year/month and those charts are not availble yet.
BobA
  • What Me Worry?
« Reply #11 on: March 18, 2009, 04:39:55 pm »
Very impressed.   I sent in my money.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.3 Released (DEMO LINKED IN POST)
« Reply #12 on: March 29, 2009, 01:56:08 pm »
New demo attached using the current version of the source. Fixed up a few bugs and added some new features. This one has new search code that is quicker but it does this by loading the whole library in at the start. If you want the old search which doesn't do this then you need to switch the new searh flag to 0 in the freebox.ini file.
Sly
  • Last login:August 30, 2016, 08:49:53 pm
« Reply #13 on: April 02, 2009, 04:46:17 pm »
Barry
Just wondering if you are in the process of switching hosts for the website and forum. It still does not seem to be working. I know you were thinking of changing hosts because of bandwidth issues. Hope you get it up and going again.
chooo_wooo
  • Newbie
  • Last login:April 02, 2009, 06:24:11 pm
« Reply #14 on: April 02, 2009, 06:24:11 pm »
Barry
I am interested in purchasing the full software from you, but your site is still down.  I have been waiting for a few weeks now for your site to go back up.  Is there any other way I can purchase it?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #15 on: April 03, 2009, 05:57:24 am »
You can purchase the software directly from me just drop me a mail...
I am having trouble with the site. I do have a new host but the old one has not unlocked my site so i can't pull the SQL information out. I have a back up from mid feb that i have loaded onto the new host and it's looking like i will have to go with that. This means a few posts are lost and some user accounts, i'm not happy about it but it's out of my hands. I'll make an announcement once I have something up.
kizer
    • Links4jeeps.com
« Reply #16 on: April 06, 2009, 02:17:09 pm »
Barcrest I'll shoot you an email about this site problem.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.5 Released (DEMO LINKED IN POST)
« Reply #17 on: May 01, 2009, 05:01:09 pm »
This demo has been updated for those interested.
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« Reply #18 on: May 21, 2009, 02:41:42 pm »
I have bought previous versions of this software and I will be buying the new versions.............. couple questions
I have never been able to get the fast forward to work, whenever I move the fast forward bar all I hear is the track skipping for like 10 seconds then it plays normal...........
also the quick link for any Artists with the words "THE" in front of their name never works, in the setup I do not have checked replace The Band with Band, The
also all tags are 100% CORRECT. again this only happens to bands with "the" in front of their names
anyone experience this?
ps. Hey Barcrest any news on that crazy looking animated skin someone was working on before? is it progressing?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #19 on: May 22, 2009, 07:59:11 am »
The animated skin never got released or at least as far as i am aware. The quick link should work, have you tried it with the latest V5 demo linked here? I will double check it's not a bug. The seek bar is flakey i might just lock it so it can't be dragged and have it there as just a visual depection of how long is left.
volno
  • Last login:November 23, 2012, 12:39:28 pm
« Reply #20 on: May 24, 2009, 07:51:40 pm »
Demo link not working for me - Page not found
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #21 on: May 25, 2009, 05:05:37 am »
Try here it might be the hotlinking.
http://www.freeboxjukebox.com/Forum/index.php?topic=1391.0
It works from that post.
volno
« Reply #22 on: May 25, 2009, 07:45:22 am »
many thanks, that works
digitaldj
« Reply #23 on: June 03, 2009, 11:35:51 pm »
Barry,
I ve been checking out your software and it ROCKS! One of these days I'm gonna have to build me a touch screen juke. I have a lot of far out ideas but no time to do them right now. One is very futuristic but would be limited to screenh size because of touch screen. I get a chance I will sketch it up and post it.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #24 on: June 04, 2009, 07:46:36 am »
Barry,
I was thinking of making a real large one using the touchscreen table idea that i saw on the web. I can't remember the link but basically it has IR Leds illuminating through the edge of a perspex sheet and then uses the wii remote touchscreen mod. You can touch it without the need for IR pen doing it this way and it used a projector for the display. It did seem like a lot of work and expense though but there is the possability for much larger touchscreen displays doing this.
Thanks for the kind words dude.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.12 Released (DEMO LINKED IN POST)
« Reply #25 on: June 09, 2009, 02:22:05 pm »
Demo updated to V5.00.12  ;D
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.22 Released (DEMO LINKED IN POST)
« Reply #26 on: October 30, 2009, 12:20:11 pm »
Been a while, Demo updated to V5.00.22  ;D
Details in first post along with download link.
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #27 on: November 06, 2009, 03:09:51 pm »
Is there a website you can obtain this fanart?  Does anyone have a comprehensive list - appropriately tagged - that is available for download.  Fanart is a really kickass feature.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.23 Released (DEMO LINKED IN POST)
« Reply #28 on: November 30, 2009, 12:52:01 pm »
Been a while, Demo updated to V5.00.23  ;D
Details in first post along with download link. You can now operate the juke without having a touchscreen using keyboard inputs to add support for button operated jukes. Right now you can pick and Album then Track then a play option only using key inputs. Support will be extended to search, top 10, genres and history screens if there is enough interest.
kizer
    • Links4jeeps.com
« Reply #29 on: November 30, 2009, 06:23:42 pm »
Yes.
http://www.freeboxjukebox.com/Forum/index.php?topic=1819.0
Flake
« Reply #30 on: November 30, 2009, 09:00:52 pm »
Yes.
Thanks a ton dude
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.28 Released (DEMO LINKED IN POST)
« Reply #31 on: December 28, 2009, 08:57:31 am »
Updated again for christmas :)
Flake
« Reply #32 on: December 28, 2009, 09:09:48 am »
When you say a fresh install is recommended due to the amount of changes does this mean all I have to do is run the uninstall app then reinstall the new version or do I need to completely delete the Etouch program folder.  I believe the uninstall app does not completely wipe away folders such as the fanart and skin folders and some config files.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #33 on: December 30, 2009, 08:45:21 am »
Remove the folder and re-install would be the best. If you are not running a previous version 5 demo then you can just install. If you have the full version then you don't need to worry about this obviously.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: E-Touch (Formally Freebox) V5.00.30 Released (DEMO LINKED IN POST)
« Reply #34 on: February 16, 2010, 06:18:20 am »
Demo updated, loads of new stuff added and new skins included.
dafelandry
  • Last login:March 21, 2012, 12:08:40 pm
« Reply #35 on: February 16, 2010, 07:33:08 pm »
RIGHT ON!! JUST GO THE EMAIL CANT WAIT TO TRY IT OUT!! Barry you rule!!
