Author Topic: best setting in mame for a lcd monitor  (Read 36026 times)
redketchup
  • Last login:September 30, 2021, 09:22:45 pm
« on: March 05, 2009, 07:49:52 am »
Hi
I just wandering if is there a good consensus in setting in Mame (and other emulator, project 64, znes, fusion, nestopia) for 19 LCD monitor. Is there something I should know about this setting that going to give me a better image.
Thanks Gino
ahofle
    • Arcade Ambience Project
Re: best setting in mame for a lcd monitor
« Reply #1 on: March 05, 2009, 10:52:58 am »
Run MAME at your panel's native resolution if possible and try some of the effects to make it look more authentic.
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« Reply #2 on: March 05, 2009, 11:02:14 am »
I've had good luck with SailorSat's triad3 and triad6 effects. Here's the link:
http://forum.arcadecontrols.com/index.php?topic=66402.msg858667#msg858667
« Last Edit: March 05, 2009, 01:10:48 pm by Todd H »
redketchup
« Reply #3 on: March 05, 2009, 02:59:05 pm »
Hi
Could you please share with me your Mame.ini file that concern this change just to be sure i put it in the right place..
thank,s Gino
Todd H
  • It's Gameday!
« Reply #4 on: March 05, 2009, 06:18:18 pm »
First, download the triad effects in the link above and place in your artwork folder in the MAME directory. Then just follow SailorSat's directions below:
Step1 - Upscale the resolution by 3 (vertical) or 4 (horizontal) with a bilinear filter ("prescale 4" in mame.ini, "filter 1" in mame.ini)
Step2 - Apply the RGB Triad; triad3 for vertical, triad6 for horizontal. ("effect triad6" in mame.ini)
Step3 - Set the output resolution the native screen resolution of my CRT Tube ("resolution0 1600x1200x32@60" in mame.ini)
The prescale and effect options are under # WINDOWS VIDEO OPTIONS in mame.ini. The resolution option is under # PER-WINDOW VIDEO OPTIONS in the ini. The filter option is under # DIRECT3D-SPECIFIC OPTIONS in the ini. You should be all set.
« Last Edit: March 05, 2009, 06:20:09 pm by Todd H »
redketchup
« Reply #5 on: March 05, 2009, 06:39:12 pm »
thanks Gino
try it tonight when go back home
redketchup
« Reply #6 on: March 05, 2009, 10:51:07 pm »
Hi
just try the setting and the game look better but  run real slow
Any idea
Gino
« Last Edit: March 05, 2009, 11:06:34 pm by redketchup »
Todd H
  • It's Gameday!
« Reply #7 on: March 06, 2009, 06:31:58 am »
How powerful of a computer do you have? Using effects causes a performance hit so you'll need some horsepower.
Blanka
« Reply #8 on: March 06, 2009, 06:46:08 am »
If you use OpenGL effects you don't loose horsepower as all the overlay stuff is handled by the GFX card. Mame renders each frame into an OpenGL buffer on the vidcard, and after that OpenGL starts scaling and rendering the overlays. Your processor won't drop a single frame because of that. On a mac you can even throw in a bunch of Quartz effects, and only the heaviest stuff (full Roy Lichtenstein rendering) starts irritating my modest 7600GS card.
Don't blame me if the Windows version does not have this nice OpenGL scaling. I don't know about that.
« Last Edit: March 06, 2009, 06:48:36 am by Blanka »
redketchup
« Reply #9 on: March 06, 2009, 10:01:28 am »
P4 2 gig
512 meg ram
onbaord video card
Just to know if the problem is the processor or the ram....
Todd H
  • It's Gameday!
« Reply #10 on: March 06, 2009, 10:12:14 am »
P4 2 gig
512 meg ram
onbaord video card
Are you running the most recent version of MAME or an older version? Are all games running slow with effects added or just certain games? What resolution are you running?
redketchup
« Reply #11 on: March 06, 2009, 10:24:44 am »
last version of mame
try with couple of resolution and all the same, don't try a lot of game, but the one I try was slow.
Todd H
  • It's Gameday!
« Reply #12 on: March 06, 2009, 10:32:13 am »
Hmmm. You might not have enough horsepower. Plus 512MB of ram is a little low IMO, especially running on-board video. Looks like you may have to forgo effects until you do a little computer updating.
redketchup
« Reply #13 on: March 06, 2009, 10:42:59 am »
what the minimum acceptable to running this king of effect
Todd H
  • It's Gameday!
« Reply #14 on: March 06, 2009, 10:49:43 am »
Right now I'm using an Intel Core Duo with 2 GB of Ram and they run fine.
Post your MAME ini and let me take a look. I want to make sure there's nothing else that could be causing this.
redketchup
« Reply #15 on: March 06, 2009, 10:55:23 am »
thank's
I'm at work, so I will post it tonight
pinballwizard79
« Reply #16 on: August 21, 2010, 07:40:35 pm »
Edit: old thread
