Author Topic: No audio with Jaguar  (Read 6413 times)
ngiovas
  • Last login:January 07, 2010, 09:20:08 pm
« on: March 02, 2009, 07:13:48 pm »
I'm not sure if this is the correct place to post this question, but I configured MaLa to work with a Jaguar emulator (Virtual Jaguar).  When I try to run a game there is no audio.  Does anyone have any suggestions of how to correct this?
Thanks,
Nick
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: No audio with Jaguar
« Reply #1 on: March 03, 2009, 07:13:59 am »
from jaguar readme
- A note on sound -
By default, the Virtual Jaguar's DSP is turned off, since it doesn't work very
well at present (it requires a lot of horsepower to sound decent at this
point!). In order to hear any sound at all, you have to either edit the vj.cfg
file and change the appropriate line or set the DSP on in the GUI (found under
Settings|Misc). One word of caution: Use the old DSP core instead of the new
pipelined version for now--the new pipelined DSP core has not yet been
optimized and runs quite slow at present! Once the DSP issues have been ironed
out, it will be turned on by default and you won't have to deal with it
anymore. ;)
ngiovas
« Reply #2 on: March 03, 2009, 03:31:27 pm »
Thanks.  I should have read the release notes more carefully.  Now the real question is - should I turn on the sound.  I probably won't for now.
