Author Topic: Sanwa 29" Monitor Parts  (Read 3541 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: March 02, 2009, 03:31:07 pm »
Need help on getting the monitor to VGA and power cord and a 29" universal frame/chassis...search in Happ and other sites and cant find any...thnx!
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
grantspain
Re: Sanwa 29" Monitor Parts
« Reply #1 on: March 02, 2009, 07:07:17 pm »
depends on what sanwa you are talking about
Ortizimo
« Reply #2 on: March 02, 2009, 11:10:33 pm »
DUH!!! yes of course...29-PFX-A
grantspain
« Reply #3 on: March 03, 2009, 10:00:31 am »
getting those parts may be difficult,sanwa are difficult to get in touch with and now their website is down also
a frame could be used from almost any 29" monitor and it will be easy to make the voltage cable
only problem could be the vga cable
but if i am correct you could probably make a vga lead with the correct plug as i believe it goes to a 6 pin header
Ortizimo
« Reply #4 on: March 07, 2009, 06:00:11 pm »
Ok, the seller of the arcade monitor tells me that the monitors come without the VGA cable and the power cable and that the power cable has to be home made and that this is a usual thing...does anyone know if this is true or not?
grantspain
« Reply #5 on: March 08, 2009, 07:17:31 am »
is it this lot of pfx on ebay atm,if so they look like a warehouse stock and are likely not to have any cables-building a power cable is about the easiest thing you could do
Ortizimo
« Reply #6 on: March 16, 2009, 06:15:49 pm »
The monitor has a 5 male prone looks like an molex...where can I get the parts to make the cable? What are they named?
« Last Edit: March 19, 2009, 10:52:19 pm by Ortizimo »
Ortizimo
« Reply #7 on: March 19, 2009, 10:54:09 pm »
need help with the pic...got to find the parts to make the cable...the guy told me he was going to mail me the cable and now he wont even pick up the phone or answer any emails... (see pic above)...thnx!
MonMotha
« Reply #8 on: March 19, 2009, 11:02:43 pm »
That power connector is an AMP Universal Mate-n-Lok.
Housing
Contact
Suitable crimper
Your standard cheapie crimp tool will not produce good crimps on these connectors.  I have access to the proper crimper if you would like me to make one for you for a small fee.
Ortizimo
« Reply #9 on: March 20, 2009, 07:33:49 am »
What is the small fee...I really need this cable ASAP and not just the connector but the entire power cord with it! Please contact me at...snecs2 at cableone.net
« Last Edit: March 20, 2009, 05:16:12 pm by Ortizimo »
