Author Topic: mamewah question  (Read 1418 times)
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
mamewah question
« on: June 26, 2003, 09:35:17 pm »
hi. i have just moved to v95b recently, and really like the change. except for one thing; on my zsnes list, i do not get a single rom to show up on the list. all other lists work well, and i have checked over this list around 25 times, but to no avail. i think it might be something with the settings, but i do not know. oh yeah, it worked on v90. here are the settings that i think i have something wrong.
Show DOS Box = 0
Send ROM Path = True
Use Long Filenames = False
Send ROM Extension = False
DAT Filename = c:\emulation\zsnes\zguicfgw.dat
NMS Filename =
CatVer Filename =
ROM Path = C:\EMULATION\ZSNES\ROMS
ROM Extension = SRM
List Generation Method = 0
also, what setting should i show the list (eg. rom path only, rom vs. dat, etc.)? and should my emu1-0.lst be empty? i feel like a real idiot, but really cannot figure it out for the life of me. thanks in advance
Jacob
It's all about the Pentiums
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
Re:mamewah question
« Reply #1 on: June 26, 2003, 11:38:34 pm »
First of all, set your ROM extension to SMC
You should show the list using ROM path only.  Your .lst file certainly should not be empty :).  Set it up to generate a game list using ROM path only.  After this, I think you'll find the .lst file will be populated :)
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
jakejake28
Re:mamewah question
« Reply #2 on: June 26, 2003, 11:55:59 pm »
yes. thank you. it works like it did on the last version. thanks again
Jacob
