Author Topic: amazingly easy question..  (Read 1588 times)
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« on: June 26, 2003, 06:17:35 pm »
ok this is going to sound dumb but i reinstalled and moved stuff to another drive, now i cant
remember for the life of me whats the command line is to remove the 2 warnings from the rom
startup in MAME, anyone able to tell me? i had all the command lines wrote down but cant find
that one. ugh.
thanks.
Lilwolf
Re:amazingly easy question..
« Reply #1 on: June 26, 2003, 06:31:03 pm »
edit mame.ini (or whatever its called... mamepp.ini)... if you don't have one... mame -cc
skip_disclaimer         1
skip_gameinfo           1
or
-skip_disclaimer
-skip_gameinfo
Syxx
  • Bling Bling
« Reply #2 on: June 26, 2003, 06:37:40 pm »
ahh yes thats it. thanks i knew it was something like that.
IG-88
« Reply #3 on: June 26, 2003, 08:12:30 pm »
skip_disclaimer         1
skip_gameinfo           1
or
-skip_disclaimer
-skip_gameinfo
I take it you can only do that in DOS mame correct?
-HarumaN
« Reply #4 on: June 27, 2003, 04:20:55 am »
Nope, Windows too :)  I think it is at the end of mame.ini...
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: June 27, 2003, 04:33:27 am »
skip_disclaimer         1
skip_gameinfo           1
or
-skip_disclaimer
-skip_gameinfo
Short answer:
No, you can only do that with the windows mame, sort of. :P
Long Answer:
Don't confuse mame, dmame and mame32, nor dos applications and commandline applications.
Dos mame ("dmame") makes mame.cfg.  Windows (commandline) mame ("mame") mames mame.ini.  And mame32 (win mame + GUI) makes it's own ini files which are usually read from the ini folder.  Each is a little different looking, but mame and mame32 ini files are interchangeable (ie: copy into the ini folder), while mame.cfg is different than the other two in details if not in outline.
Dos applications cannot use win32 or directX.  A windows commandline application starts from the dos-looking commandline, but uses win32 API and/or directX.  Mame uses win32 API and directX, just like mame32; dmame does not use win32 API or directX.
Robin
Knowledge is Power
