Author Topic: clrmamepro won't split  (Read 1479 times)
Goatz18
  • Last login:September 06, 2021, 06:53:51 pm
  • The Bringer of Destruction and Doom!
    • Arcade Project Alpha
« on: February 25, 2009, 12:05:59 pm »
I have successfully made a .dat file of my Mame v1.06 using the mame -listxml >mame.xml and then datutil mame.xml. I can bring the .dat up in clrmampro v3.122c just fine. I then load the set of roms and files just fine. But when I drag a rom into the set, it doesn't split it into the necessary files in order for me to play it, clrmamepro just rebuilds it exactly the way it was before. I have every Split option ticked. What could I be doing wrong? I have tried all the "tutorials" and google searches that I could find, that's how I got this far, but it's just not doing what it is said to supposed to be doing. Thanks.
P.S. I dig the web site and forums, big help in getting my machine up and running.
« Last Edit: February 25, 2009, 12:13:26 pm by Goatz18 »
Hoopz
  • Intellivision Rocks!
Re: clrmamepro won't split
« Reply #1 on: February 25, 2009, 12:11:51 pm »
I can't specifically answer your question but I wanted to see if you had looked at this tutorial?
http://www.cphsolutions.f2s.com/guides/cmprotutorial.htm
That may help you out.   :dunno
Goatz18
« Reply #2 on: February 25, 2009, 01:36:37 pm »
Are there just some files of roms that won't rebuild to a given version of Mame? That tutorial was the best one I have seen, but I got the same result. Thanks anyway, this is just weird. If anyone has successfully rebuilt roms to Mame v1.06 from clrmamepro, let me know what you did.
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« Reply #3 on: February 25, 2009, 01:42:57 pm »
You probably need the 'rollback' MAME roms. Older romsets have different versions of some of the roms and cannot be rebuilt from newer romsets, therefore you need a copy of the roms that have changed considerably - these are the 'rollback roms'.
Goatz18
« Reply #4 on: February 25, 2009, 02:00:43 pm »
That sounds right. I'll give it a try. I've seen 'rollback' roms before, just never knew what they stood for. Thanks.
slapaham
« Reply #5 on: February 25, 2009, 04:31:00 pm »
Thats okay, glad I could help - I will say one thing... they aren't easy to acquire unfortunately! :'(
