Author Topic: Load Picture Error Mala v1.05  (Read 4903 times)
Dorian
  • Last login:July 04, 2011, 03:45:31 am
« on: February 24, 2009, 05:14:58 pm »
Hy,
i get following error if i scroll through my gamelist
Code: [Select]
2009.02.24  18:28:23.07   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 00E2D000
2009.02.24  20:10:40.70   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 0212D000
2009.02.24  21:36:37.87   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 020FD000
2009.02.24  22:57:45.56   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 0236D000
2009.02.24  23:03:54.79   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 017ED000
anyone can halp me? thanks
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Load Picture Error Mala v1.05
« Reply #1 on: February 24, 2009, 06:50:57 pm »
sounds like a problem with your snaps, try to identify which snap is making it crash and replace it
Dorian
« Reply #2 on: February 25, 2009, 05:07:31 am »
the screenshots are from here and i have renamed with this (No-intro Screenshot Archive - Image renamer) Tool from the same site, to get a named snap and no CRC named Snap. Is it possible that the tool is crap?
« Last Edit: February 25, 2009, 05:11:30 am by Dorian »
dungbeetle46
« Reply #3 on: February 25, 2009, 06:12:41 am »
the snaps should be ok try fuzzyrenamer to rename them
remove your snaps altogether and see if mala crashes, if it doesnt then its obviously a problem with your snaps
Dorian
« Reply #4 on: February 26, 2009, 05:20:49 am »
ok the snaps are guilty, i think the rename tool is defect! Where can I get the "fuzzyrenamer"? Works the "fuzzyrenamer" also with the dat files, or is it possible to "learn" Mala to take the CRC named snaps?
« Last Edit: February 26, 2009, 05:22:35 am by Dorian »
dungbeetle46
« Reply #5 on: February 26, 2009, 05:28:57 am »
get snaps here
http://localarcade.com/screenshotarchive/screenshots.htm
and use google to get fuzzyrenamer
Dorian
« Reply #6 on: February 26, 2009, 02:42:18 pm »
get snaps here
do you have a other link for me, because the packs are down, or inpossible to download, it skips after seconds!
dungbeetle46
« Reply #7 on: February 27, 2009, 05:02:07 am »
http://www.emu-france.com/?page=fichiers&idSysteme=14
the previous link is for other emus but its not working properly at the moment, might have to wait a couple of days
« Last Edit: February 28, 2009, 07:53:17 am by dungbeetle46 »
