Author Topic: Perferred place to buy Forstner Bit Online?  (Read 4703 times)
massive88
« on: February 24, 2009, 11:37:43 am »
I want to try using a forstner bit on my next project, as so many people have talked about how well they work in MDF and on plexi, but I cant find any locally at the sizes I would want, namely 1 3/16" (Japanese buttons) and 1 1/8" (Happ).
Is there any reason to not go for these guys?
http://www.amazon.com/Steelex-1-3-16-FORSTNER-BIT/dp/B0000DD32V/ref=sr_1_1?ie=UTF8&s=hi&qid=1235493314&sr=1-1
http://www.amazon.com/Steelex-1-1-8-FORSTNER-BIT/dp/B0000DD0IM/ref=sr_1_29?ie=UTF8&s=hi&qid=1235493736&sr=1-29
Or is there another option I should be looking at for ordering a better/similar product?
Thanks.
« Last Edit: February 24, 2009, 11:42:45 am by massive88 »
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
Re: Perferred place to buy Forstner Bit Online?
« Reply #1 on: February 24, 2009, 11:47:10 am »
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/forsbit.htm
1-13/64" (30.6mm)
121/128" (24.1mm)
Work perfect for Japanese buttons! Tested many many times over.
massive88
« Reply #2 on: February 24, 2009, 12:00:50 pm »
Up til now Ive used 1 3/16" hole saws for Japanese buttons, and they work perfectly.  However, the hole saw may be working it out to slightly larger as it oscillates.  My assumption is that with a forstner bit there would be less oscillation as you drive the hole, making a more precise hole.
How well do the Japanese buttons fit using the 1 13/64"?  Do they fall in?  Do you have to push them in?  Would the fall out of the hole if you turned it upside down and gave it a little shake?
MrMojoZ
« Reply #3 on: February 24, 2009, 01:06:09 pm »
Hmm lets say they'd take more than just a little shake, but you could shake them out.
blakemcginnis
  • Last login:July 21, 2009, 08:31:04 pm
« Reply #4 on: February 28, 2009, 12:13:09 am »
So for standard happ buttons you would use a 1 1/8" bit?
foleykoontz
  • Last login:November 11, 2020, 09:36:10 am
« Reply #5 on: April 28, 2009, 01:11:46 pm »
Ya that's right. Also is there any place to buy this bit by itself, online or off? I've checked most places online but all of them have $8 shipping for a $4 bit. Harbor Freight seemed to have it but only in a $40 bit kit.
massive88
« Reply #6 on: May 01, 2009, 12:16:53 pm »
patchboston
  • Last login:September 02, 2020, 09:31:04 am
« Reply #7 on: May 10, 2009, 10:47:48 am »
would these bits work with a harder surface, other than wood? I have a metal CP that needs to have new holes drilled, but I have no clue on what to use..
Own: Pac-man, TMNT, P.O.W.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #8 on: May 10, 2009, 09:13:23 pm »
You can't use a forstner on metal.  Use a metal hole saw.
