March 01, 2026, 08:33:08 pm
I run MK4 without issue. Core2Duo here running .129u3 on Windows XP x64...I can say for sure MK4 worked in .129u2 as well. I can't remember if it worked prior.
Quote from: FrizzleFried on February 26, 2009, 03:29:08 pmI run MK4 without issue. Core2Duo here running .129u3 on Windows XP x64...I can say for sure MK4 worked in .129u2 as well. I can't remember if it worked prior.What Ghz are you at Frizzle?
Hrm I havent tried MK4 (no one ever wants to play any but MK2), but Im at 3.2 Ghz on XP64, so I should be good, Ill have to check it out.
