Author Topic: p360 psx hack question....!  (Read 1032 times)
desistyle3
  • Last login:June 26, 2003, 11:35:05 am
« on: June 25, 2003, 10:43:55 pm »
does anyoen know where to solder the 5V for the p360 on the madcatz psx PCB?  Its the one with no analogs and the handle grips are long.  Some people tell me its a madcatz 2001 or 2002?
thanks!
desistyle3
Re:p360 psx hack question....!
« Reply #1 on: June 26, 2003, 11:35:29 am »
bump..
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: June 26, 2003, 11:49:55 am »
bump..
You should use a multimeter.  Or I'd highly recommend using an additional/different power source as sometimes the drain can be too much and cause intermittent issues (hypothetically)
Even if you use a wall wart ac->DC adpater make sure it's putting a true 5volts under load... again... with a multimeter =P
Sorry can't be much more help than that.
good luck!
Rampy
