Author Topic: I need a recommendation for 25-27" TV for mame cab. Also VGA to S-Video question  (Read 2901 times)
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
I haven't had much luck in the past with using a TV in a cab. I was wondering if someone could recommend one by brand or model number that has shown good results.
I'll be using S-Video from computer to TV.
I have another computer I'd like to use (someday) without S-Video output. Has anyone tried those $4.00 vga to s-video cables with good results?
TAG
  • Last login:May 23, 2014, 05:52:05 pm
The Toshiba 27A33 has had a lot of positive reviews on this site, but I was never able to track one down on Craigslist.  I'm using a JVC AV-27320, and I've got no complaints so far!
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
ghettodish
Anyone use a Sony Wega? I'm seeing some good prices for them on CL.
TAG
If you don't know it already, two features you definitely want to look for on any TV if you're looking to power everything up in the cabinet with one button are (1) power return and (2) last channel recall.  I imagine the WEGAs probably have them.
-- Dirk Gently
ghettodish
I'll be using a smart strip so no worries.
TAG
I'm using one, too, which is why last channel return is necessary.  When the TV shuts off via the Smartstrip, then when the power comes back on, some sets will tune into the default channel (3 or 4, usually, I think).  With last channel return, however, it will come back to whatever the last setting was (in my case, Video 1).
-- Dirk Gently
ghettodish
I'll be using the Control (main) outlet for the TV so it will still get power for last channel, etc. My computer is safe for Hard(yank-the-plug-out) Shutdown with normal reboot after power-on.
TAG
Ah, got it.  At any rate, I'm pleased with the JVC, and hopefully you'll get more input from other members and find one that you're happy with.
Which others have you tried in the past that you didn't like?
-- Dirk Gently
ghettodish
I've tried a 25" Sharp and a 27" Magnavox (I think). Both had RCA inputs, no s-video.
TOK
  • The Game Always Wins
S-Video looks rotten, IMO. Browse the monitor/video forum. All the info you need is already there.
ghettodish
Funny you should say that. After a few people told me that today I found a 25" arcade monitor on Craig's List. I just brought it home. Can anyone help me ID it?
http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=35549654&albumId=3372975
I'll post this in the Monitor Forum later.
Ummon
  • Trade Count: (+13)
Well, it looks analog. I'd google all the numbers you can find.
Yo. Chocolate.
Stephen Hawking
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
I can ID the Sun Chips. Tasty!
ghettodish
Ken Layton says it's a QNIC model CGM-2500. I think it's from a Neo Geo? I got it from a trusted local seller for $50. It even works!
« Last Edit: February 18, 2009, 02:25:41 am by ghettodish »
