Author Topic: Donkey Kong Repair ?  (Read 6928 times)
CTpunk
  • Last login:February 18, 2009, 02:35:40 pm
« on: February 15, 2009, 01:17:12 pm »
I just moved this thread to the MONITOR section. Seems more fitting for the issue at hand.
Hey there brand new to this and have a few questions regarding a Donkey Kong machine I just picked up rather cheap. Dont know what generation this is but its got the blue sides and has a Sanyo monitor. Ive gotten some useful info from researching around here and elsewhere but havent found the exact problem yet. The game fires up and plays, guy runs and jumps and dies but Ive got no real screen (see pic). Its seemed to collapse into one center vertical line. I havent done anything except cleaned out the layer of dust on everything, inside and out. Does this look like a "cap kit" repair? Also if it is a cap kit issue how many caps are we talking about here? Replacing them all on each and every board? Seems like there are over 100 no? Thanks for any help and please ask me to include any info that I may have left out.
RJ
« Last Edit: February 15, 2009, 01:34:07 pm by CTpunk »
CTpunk
Re: Donkey Kong Repair ?
« Reply #1 on: February 15, 2009, 01:19:23 pm »
Also should the monitors tube be lit up pretty hot to be normal? Dosent appear to.
THE POKER BRAT
  • Last login:August 04, 2015, 05:50:58 am
« Reply #2 on: February 15, 2009, 04:35:06 pm »
i have the same prob on my bomb jack cabinet,...(some people say its a width coil)
WANT LIST: , asteroids mini, crazy climber mini, tron mini, goldball PINBALL,.
SirPeale
  • Green Mountain Man
« Reply #3 on: February 15, 2009, 04:40:38 pm »
If it's a Sanyo EZ there is a switch on the main board. IIRC it says "Test Mode" or something close to it.  If it gets flipped it'll produce a result like what you're seeing there.
If that works...good.  If not, you have something called vertical collapse.  Try my suggestion first and we'll go from there.
CTpunk
« Reply #4 on: February 15, 2009, 09:36:21 pm »
Only seemed to find one switch, its on the board thats right behind/underneath the monitor. The silver base plate under the monitor says Japan EZ so I assume it is a Sanyo EZ. Dont know what you meant by IIRC but the little white switch says "normal" beside it. I flipped it but it did nothing as far as I know.
SirPeale
« Reply #5 on: February 15, 2009, 09:44:25 pm »
IIRC = If I Remember Correctly.
Check TR401, TR402 and TR403.
It could also be a bad cap, have you done any work on this monitor?
CTpunk
« Reply #6 on: February 16, 2009, 12:31:07 am »
Nope nothing yet. I guess Ill start with a Cap kit. Tell me this. Does the cap kit come with caps for different boards, some of the boards, one of the boards?
Level42
« Reply #7 on: February 16, 2009, 11:28:02 am »
A cap kit is only for the monitor. A monitor usually has two boards: The main board and the neck board. All (or actually, most) caps are included for those boards not for the game PCB or power supply. For some power supplies  there are cap-kits available, but I haven't seen them for the Nintendo power supplies. Probably because they are a nightmare to open at all.
CTpunk
« Reply #8 on: February 16, 2009, 12:47:41 pm »
Level42 thank you that answers my question. I will order a cap kit and consider whether or not its something I can do or find someone to do it for me. Thanks for all input guys.
Will update this thread.
Level42
« Reply #9 on: February 16, 2009, 01:36:07 pm »
The Sanyo's are great monitors. At least, the one in my Nintendo cab is. I think it's the best looking original monitor I've got running. I didn't even so a cap-kit on it yet ! (Just the famous "fold-over" cap.).
