Author Topic: Analog pedal  (Read 979 times)
mytymaus007
Analog pedal
« on: February 11, 2009, 09:10:51 pm »
If I had to have one pedal,would i be able to play all racing games with an analog pedal or should i go with a switch pedal for MAME games only, Also does anyone have a list of all different pedal games
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Analog pedal
« Reply #1 on: February 11, 2009, 09:15:49 pm »
In theory, an analog pedal would work with both types of game as you should be able to set an 'analog threshold' (say, half way depressed) in MAME that will then register as a digital 'press', plus obviously you retain analog functionalty for those games that need it.
You can go budget and pick up a PC steering wheel with pedals, then just use whatever wheel you want if you've already bought a 270 or 360 wheel.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Analog pedal
« Reply #2 on: February 12, 2009, 12:05:58 pm »
Using RomLister & mame 0.129u3 listxml, I get 79 games, attached.
Robin
Knowledge is Power
