Author Topic: Anyone know how to cut aluminum stock?(OSCAR?)  (Read 1265 times)
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« on: June 25, 2003, 02:52:45 pm »
I have like 2 feet of aluminum that is about 1X2 inches I need to cut it into 12 2 inch pieces. Anyone have a clue how to do this? I have a grinder to clean up the edges so that isn't a concern. I used a steel cutting circular saw blade once when cutting steel shafts for a set of golf clubs didn't know if this was alright to use on aluminum. I'd really hate to have to do it with a hack saw.
I need it so I can add a support table to my table saw to cut larger pieces of wood for my new cocktail cab i'm starting.
Anyone got any ideas?
AlanS17
    • AlanS17
Re:Anyone know how to cut aluminum stock?(OSCAR?)
« Reply #1 on: June 25, 2003, 03:35:33 pm »
I bet you can find a blade for a jigsaw that can handle this. Of course... I'm no metal worker.
OSCAR
    • Oscar Controls
« Reply #2 on: June 25, 2003, 03:56:38 pm »
I've cut aluminum stock on a tablesaw before.  You need a special blade, but it works great.  This is the type of blade you need:  http://www.mytoolstore.com/tenryu/alumic.html
I found a post in Google written by someone who knows what they are talking about, and explains it probably better than I could.  You should read this before trying to cut aluminum on your tablesaw.
Google post
TrickyFishy
  • Last login:May 09, 2006, 02:37:20 am
    • miniMame.com - half-sized arcade cabinets
« Reply #3 on: June 25, 2003, 04:00:56 pm »
I used to work in a machine shop.  You should be able to cut it with any fine to medium toothed saw like a jigsaw.
A hacksaw should go through it pretty fast.  Much faster than a piece of steel.
70% PacMan cab
Mike
« Reply #4 on: June 25, 2003, 04:14:28 pm »
Thanks for all your help. Yeah I used to be a tool and die apprentice(Also was an auto mechanic apprentice and a carpenter apprentice, took me a while to figure out what i wanted to do with my life, so now i'm a software developer) and we cut all our metal on a bandsaw. But the blade wasn't the same as my bandsaw blade for wood. I think i'm going to go the table saw router. I think i will end up buying more of this aluminum and need to cut it.
locash
  • Last login:March 22, 2008, 06:45:21 pm
  • Got cash?
« Reply #5 on: June 25, 2003, 04:14:51 pm »
I spent some time in a machine shop as well.  We used to cut sheets of aluminum (1/4" thick) on a 8" table saw.  I don't think the blade was anything unusual, just carbide.  Made a hell of a lot of noise.  Given options this would not be my first choice, it just never felt quite right.
If I were cutting 1x2 stock as you describe, I would probably stick to a jig saw or band saw with a fine tooth bi-metal blade.
In truth a hacksaw shouldn't take too long.
"I believe that every individual is naturally entitled to do as he pleases with himself and the fruits of his labor, so far as it in no way interferes with any other men's rights."
Abraham Lincoln
