Author Topic: Killer Instinct 2 monitor problem HELP!!  (Read 15040 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
Re: Killer Instinct 2 monitor problem HELP!!
« Reply #40 on: February 17, 2009, 02:10:52 pm »
oh yea  i knew it was my shocked look that the dang mame works on that monitor/cabinet but a dang jamma board wont work
SirPeale
  • Green Mountain Man
« Reply #41 on: February 17, 2009, 02:26:17 pm »
Sounds like a problem with the board.  Did you try the same board in another machine?
adidas1984x
« Reply #42 on: February 17, 2009, 02:33:53 pm »
yes if i put either board in the mk4 cabinet they work and look perfect
Kevin Mullins
    • Me on Myspace
« Reply #43 on: February 17, 2009, 02:37:19 pm »
And what model monitor is in the other cabinet ?
adidas1984x
« Reply #44 on: February 17, 2009, 03:19:22 pm »
i know for a fact what it is cause i bought it a year ago its a wg k7000 and it uses a isolation transformer
grantspain
« Reply #45 on: February 17, 2009, 04:26:03 pm »
have you checked your voltages yet from the psu
adidas1984x
« Reply #46 on: February 17, 2009, 04:35:57 pm »
remember i only know the basics as you can see i got it workign mame wise and hooking it up but how do i ck the voltage on the psu i have a volt meter so im good there
grantspain
« Reply #47 on: February 17, 2009, 05:22:54 pm »
here is my take on the situation,
monitor works with mame no problems
game board works on other cabs no problem
that only leaves wiring from game board to monitor or power supply voltage low
first trace you wiring for the monitor video input signal and using continuity test/bleep test on your multimeter prove that the wiring has no breaks(also you manipulate the wire whilst the machine is on to see if this causes a problem)
then if everything checks out with this perfect then you need to set your multimeter to dc volts and a range of 20 volts and meter the game board edge connector,i can not remember if its jamma but if it is then you put the ground of the multimeter to pin 1 or 2 and the volts lead of the meter to pins 3 or 4---this will give you the +5v reading which should not be less than +5.05 and not more than +5.20
google for multimeter demonstrations if unsure how to do
adidas1984x
« Reply #48 on: February 26, 2009, 02:39:27 pm »
ok faulty jamma board power suply was the problem but since i dedided to mame it it works great (darn powers supplys)
