Author Topic: Doing the arcade machine with 5/8 instead of 3/4?  (Read 3202 times)
daok
  • Last login:July 04, 2009, 09:30:00 pm
« on: February 07, 2009, 12:40:15 pm »
I am thinking of doing the whole machine with 5/8 MDF instead of 3/4 (I have see a lot of project with 3/4). The reason is the weight of the machine... I try to cut down the weight.
Do you see any problem using 5/8 MDF to build the entire machine?
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
Re: Doing the arcade machine with 5/8 instead of 3/4?
« Reply #1 on: February 07, 2009, 01:19:50 pm »
I used 5/8" for the same reason and it worked just fine.  Though it was a little harder to find.
http://forum.arcadecontrols.com/index.php?topic=82241.0
... Why is it that you always find it in the last place that you look? ...
Franco B
« Reply #2 on: February 08, 2009, 06:05:48 am »
I used 3/4" for the sides and then 5/8" for everything else to partially keep the weight down but still have the look of 3/4" t-moulding.
daok
« Reply #3 on: February 08, 2009, 05:16:55 pm »
For the Molding, I see on the website that I can get 5/8 so it doesnt look to be a problem.
Thank for your feedback :)
  • Last login:Yesterday at 12:32:01 am
« Reply #4 on: February 09, 2009, 03:12:39 pm »
My cabinet at home uses 5/8" instead of 3/4. It definitely cut down the weight, but the downside is that a lot of t-molding suppliers have limited colours in stock in the 5/8 category. But you don't necessarily need to get 5/8" molding for your cab, you can get 3/4" then trim it down for your needs, see here:
http://forum.arcadecontrols.com/index.php?topic=86699.0
daok
« Reply #5 on: February 09, 2009, 03:28:57 pm »
Interesting, I am still not very sure of how to do it with the chisel, doesn't seem to be that much easy and the more dangerous part will be around the plexiglass... humm :dizzy:
