Author Topic: where to put skin files for mamewah?  (Read 2104 times)
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« on: June 25, 2003, 09:21:09 am »
recently i have been using advanceMENU as my frontend, but after seeing the skin stuzza made for mamewah, i decided to d/l it and switch to mamewah. i have all of his image files and the .lay files. where do i put them, and what do i need to do? thanks in advance
Jacob
It's all about the Pentiums
Rocky
Re:where to put skin files for mamewah?
« Reply #1 on: June 25, 2003, 04:23:06 pm »
Here's what I do and it works for me.  Put the .lay files and all your other files for the skin (not artwork) in the same directory. It doesn't matter.  I'm using \Mamewah\Skins
Then edit the main Mamewah.cfg file to tell it where the .lay file is. That should do it.
Also you have to tell the emu.cfg where the artwork is.
Rocky
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« Reply #2 on: June 25, 2003, 04:31:30 pm »
where can i get some skins? i'd love some, but im to lazy and unimaginative to make my own.
anyone wanna send me some of there works? or got a site?
AIM SyxxPakk6
« Reply #3 on: June 25, 2003, 06:17:03 pm »
It doesn't matter where you put the .LAY file, so long as you point to it in MAMEWAH.  BUT, the .LAY file will contain the exact path of the images (maybe made on someone elses PC), so you need to edit the .LAY file and adjust this to your image path (do not alter anything else).
Where's this skin stuzza made, did I miss it?
Syxx: I don't know at the moment, but if anyone wants to send me their layouts, I'll bung a page up on my site for them :)
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Coming Soon
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #5 on: June 25, 2003, 09:34:02 pm »
Instructions for using my Skin with a 1024x768 layout:
  • Download the zip file which contains the graphics and .lay file
  • Extract the contents of the zip file to wherever you want.
  • Open the Mamewah Layout Designer and choose File -> Open Layout
  • Select the
« Reply #6 on: June 26, 2003, 04:41:03 am »
Great skin stuzza! :)
I will try and improve MAMEWAH so you do not need to change the image paths etc., which is a bit of a pain atm...
jakejake28
« Reply #7 on: June 26, 2003, 11:12:26 am »
thanks all, i finally got it out, it is really coool ;D
