Author Topic: Nag Screen v.0.84 - I am so lost! Please help!  (Read 1723 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: February 05, 2009, 09:22:54 am »
I'm desperate to get rid of the nag screens on my MAME v.0.84 - it would mean I had my set up almost exactly how I want it.
I downloaded http://sourceforge.net/project/showfiles.php?group_id=91067&package_id=95932
which will rid me of nag screens but I take it I have to compile it? Well, I'm totally new to compiling MAME and I haven't a clue where to start, what I need, where to get it and how to do it! I know threads like this are annoying but everyone has to start somewhere, right?
If anyone can please help, I'd be eternally grateful!
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Nag Screen v.0.84 - I am so lost! Please help!
« Reply #1 on: February 05, 2009, 10:16:24 am »
I don't think you need to recompile mame to remove screen from 0.84.
Try to run mame with parameter -skip_disclaimer -skip_gameinfo
ex :
mame pacman.zip  -skip_disclaimer -skip_gameinfo
you can also , i think disable from ini file.
Generate the mame.ini file (if you don't have it) using that command : mame -cc
Then look in the file , search for disclaimer  and gameinfo  and change the value to 1 or 0 .
slapaham
« Reply #2 on: February 05, 2009, 11:23:39 am »
Cheers youki... I'll give it a go and post back here! :cheers:
slapaham
« Reply #3 on: February 05, 2009, 11:54:23 am »
FANTASTIC! It worked. Such a simple solution too :P
Thanks so much youki - you've made me a very happy chap! :D
TheNoodleMan
  • Last login:March 16, 2010, 04:12:03 pm
« Reply #4 on: February 05, 2009, 02:28:37 pm »
ex :
wow, very helpful and simple. Thanks
youki
    • Atomic Front End
« Reply #5 on: February 05, 2009, 03:24:06 pm »
It works only with old mame version, on recent ones it doesn't work i think.
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: February 07, 2009, 01:42:14 pm »
Yep for newer versions check the hiscore diff pinned topic.
