Author Topic: wells 25 k7000 is flatlined..really no vert  (Read 1930 times)
davidb72
  • Last login:July 09, 2013, 03:41:50 am
« on: February 04, 2009, 11:25:49 pm »
i have a k7000 that has a horizontal line across the center of the screen.  this board was dead and i replaced the following so far....IC3..IC4..Q11..IC2 --WAS USED...and replaced all the caps -bought from happ-  this does have the remote board that is good- borrowed from my other working monitor. i am at a stopping point as dont know where to go from here.. i do have 24volts at pin 6 on ic3... b+ volt good...any help would be appreciated :angry:
Ken Layton
  • Guru
  • Technician
Re: wells 25 k7000 is flatlined..really no vert
« Reply #1 on: February 04, 2009, 11:54:04 pm »
C51 is not included in capkits and may be bad. It's a .68 uf @ 35 volt dipped tantalum type. Check to be sure your vert size and vert hold pots are good.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: February 05, 2009, 12:13:15 am »
Any cold solder joints or bad traces noticable?
Solder joints around the yoke connector and such.....
davidb72
« Reply #3 on: February 06, 2009, 09:47:01 pm »
ken thx for reply..changed c51 still inop i checked voltage to it is not getting any. the ic2 i replaced is off of another working board. where else would i look for the this voltage problem. i have another k7000 that im checking volts with and it does work . please  help.   david
