Author Topic: CP2viewer running like 6 times\NFL Blitz issue  (Read 1092 times)
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« on: February 04, 2009, 09:53:28 pm »
Hi all,
Running CP2viewer in Mala. Sometimes when I check task manager I see several (or more) .exes running at the same time. Is this bad? How can I fix it? it seems that it is taking some PC power away. Kids play the cab, and I suspect that this happens when they try and start a game and don't wait for the viewer to pop up before they hit more buttons.
Also, I get NFL Blitz to work fine using RomCenter but when I play it through Mala it doesn't work. I noticed that RomCenter uses a different code with it calls up the emu "%4" "%1" or something like that, whereas Mala just uses %roms%. Maybe they are two different things. I'm a dumbass as far as that goes. Thanks for the help.
