Author Topic: Jap inspired cab design in sketchup  (Read 15804 times)
Necroticart
  • Last login:February 05, 2023, 10:42:36 am
  • Welcome to my nightmare
« on: February 04, 2009, 02:45:10 am »
I want to make something a little differant from the usual cab that would be mainly for the PC Version of Street Fighter 4. and also I want to thank to Gatsu for the Idea and the sketchup file/ cp. Well let me know what you think or if you have any ideas to help me out?
« Last Edit: February 04, 2009, 02:56:55 am by Necroticart »
Blanka
Re: Jap inspired cab design in sketchup
« Reply #1 on: February 04, 2009, 04:34:42 am »
Make the control panel and the shelve to hold it one thing, and make it wider, matching the width of the whole thing. Then the shelve IS the control panel.
Remove the center-speaker/taxi-sign from the top of the screen. I know Lindbergh's have marquees up there, but whether that is nice design wise can be questioned. At least those are not 15cm deep. The main display will be marquee more than enough already.
Make the bottom a little airier. What is going to be in that huge box? Or is it a dog-house at the same time? That would be smart. Guarding the SF cab.
Remove the feet. It will be stable without. The feet are going to be in the way of your stool casters.
« Last Edit: February 04, 2009, 04:41:55 am by Blanka »
Blanka
« Reply #2 on: February 04, 2009, 04:44:19 am »
You know these pictures?
Nice clone
Original Sega
And check the eye-height sitting on a chair. I have the idea that the Lindberg clone although it looks very nice, has the screen leaned too far back
Blanka
« Reply #3 on: February 04, 2009, 04:47:47 am »
And the other famous one, the VEWLIX:
Here the box is mostly needed to hold 1 million YEN coins.
Necroticart
« Reply #4 on: February 05, 2009, 01:11:23 am »
thanks for the help i'm refining my design a bit will post up when i'm done
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #5 on: February 05, 2009, 10:06:55 am »
I really like the Viewlix cabs. They have such simple but effective control panel art designs.
Gatsu
« Reply #6 on: February 05, 2009, 10:52:42 am »
Yeah. I'd love to just order a Vewlix....but they are about $10,000 a piece...just the cab...no boards.
And the Street Fighter IV kit is another $5-$6,000. So you're talking the price of a car almost for an arcade cab.
Necroticart
« Reply #7 on: February 05, 2009, 02:36:38 pm »
I hope the cost drops sooner than later but I'm not counting on it the vewlix cab is a must in the gameroom when the price does eventually drop to a affordable range
Gatsu
« Reply #8 on: February 05, 2009, 02:43:12 pm »
Nah it won't drop for a good 10 or so years I'd imagine. With each cab coming with a full HD LCD tv.....it wont go down for a long while.
I wanna know how the SFIV kit hooks up though. Is it Jamma or is it something new.
Necroticart
« Reply #9 on: February 05, 2009, 03:19:27 pm »
We will know soon I emailed highwaygroup.net to ask they have the kits up for sale
MrMojoZ
« Reply #10 on: February 05, 2009, 04:29:32 pm »
Uses a JVS I/O.
Necroticart
« Reply #11 on: February 05, 2009, 05:13:56 pm »
yep I/O compatible highwaygroup.net just emailed back to confirm it atleast they will hook up to the cabs we already own
Necroticart
« Reply #12 on: February 07, 2009, 02:54:32 am »
k I decided to scrap my own plans in favor of the vewlix pdf Gatsu posted it's a lot closer to the to what I really want. I'm in the process of running the plans through sketchup so I can convert the measurements, and make any adjustments to the design that I need. Also I will post up the sketchup file when i'm done for all those that would like a decent set of plans to work with. The PDf is definitly not a good example of a good plan insanely hard to read.
« Last Edit: February 07, 2009, 03:05:24 am by Necroticart »
Gatsu
« Reply #13 on: February 07, 2009, 10:41:55 am »
the control panel and side pieces were alright to read....it was that damn bottom that was giving me a headache....
Dude. If you get a full Vewlix done, I'll have to build one as well. I'm still gonna make the Lindberg, but the Vewlix is what I really want. Im just tired of changing my mind every other week on a cab design. lol
also....can I snag that sketchup file from you when you are done? I've got a lindberg and a candy cab sketchup. That Vewlix will complete my jap cab set. hehe.
Necroticart
« Reply #14 on: February 07, 2009, 01:39:07 pm »
ya you can definitely have the file when I'm done. these vewlix cabs are a must own. and as far as those plans go I would not mine having them for the candy cabs never know i might built one later down the line
« Last Edit: February 07, 2009, 04:29:32 pm by Necroticart »
Necroticart
« Reply #15 on: February 08, 2009, 02:34:26 am »
k i've got what I could for the plans realized as I was getting into the last part of the Pdf that it was incomplete but luckly the rest has not been to hard to fill in here is what I have so far the file still needs a bit of work.
« Last Edit: February 08, 2009, 09:04:05 am by Necroticart »
Gatsu
« Reply #16 on: February 08, 2009, 02:30:44 pm »
also, for the true vewlix cab, you need the speaker areas above and below the LCD monitor. hehe
Necroticart
« Reply #17 on: February 11, 2009, 01:46:44 am »
K more work done I've got every thing to fit now except the control panel I have to put some kind of latch system to access the control panel guts
« Last Edit: February 11, 2009, 01:50:32 am by Necroticart »
TOK
  • The Game Always Wins
« Reply #18 on: February 11, 2009, 05:45:21 am »
You a good woodworker?
You have some very tricky faceted pieces at the front of the control panel. They're little with like 4 different angles on them, and they're going to have to be exactly the same for each side.
« Last Edit: February 11, 2009, 05:47:04 am by TOK »
ViciousXUSMC
  • Last login:July 28, 2009, 10:25:53 am
« Reply #19 on: February 11, 2009, 05:56:05 am »
Wow I like that cab with VF5 on it, its like the "VS Arcade" idea I had with only one player on one side and another on the other side and its using a big display like what I use now for my PC, heck its halfway like my PC desk so I am half way there :P
Its nice to see not everybody is into the old age authentic 15hz CRT stuff and can appreciate new tech.
If your into new ideas and dont want to copy a cab but make your own idea.  Another new age idea I had to save you on size/weight/cost and make it more portable is to have a half cab with a HD projector in there to throw the image othe wall or a screen.  You can get a 60"-100" screen easy for a fraction of the cost of a LCD that big.
MrMojoZ
« Reply #20 on: February 11, 2009, 09:17:33 am »
Considering how in-expensive HD tvs are nowadays I doubt you could buy a HD projector+screen at a fraction of the cost.
Gatsu
« Reply #21 on: February 11, 2009, 01:42:36 pm »
looking good man....now Im not so sure I wanna build the one I designed! lol!
ViciousXUSMC
« Reply #22 on: February 11, 2009, 02:52:58 pm »
Yeah you can, a Optoma HD65 is like $700
A CHEAP 37" HD TV is like $900-1000
The HD65 can give you a screen that its easily 60" big and up to 100"
Any LCD in that range is going to be multiple thousands of dollars.  I do electronics price research almost daily and have been on the market for a HD projector for awhile so I keep an eye on the prices.
I also use a 37" for my computer monitor it was $1000 shipped about 2 years ago and it was on ultra closeout sale.
MrMojoZ
« Reply #23 on: February 11, 2009, 05:06:33 pm »
A cheap 37" HD LCD TV is $550 or less, I don't know what you are looking at.  ???
Necroticart
« Reply #24 on: February 11, 2009, 10:22:01 pm »
Thanks Gatsu and as far as what cab you build just remember this one is a ton of work.  I'm debating If i'm still going to build it myself anytime soon but either way I still want working cab plans, in the long run this is still going to be a lot cheaper than buying an actual Vewlix cab.   Also a note on what TV to use as MrMojoZ stated you can get a cheap LCD HD 37" but unfortunately i'm sure at $550 it's going to have an 8 ms response time and in fighting games thats unacceptable thats a 2-3 frame delay bottom line your better of spending the money on a good LCD
« Last Edit: February 11, 2009, 10:37:29 pm by Necroticart »
ViciousXUSMC
« Reply #25 on: February 12, 2009, 03:27:17 am »
Ok a 37" 720p Walmart Vizio maybe... like what my friend has and its trash.
I mean a good 1080p set, not Samsung or Sony or some over priced brand just a good quality set.
Send me links please to these $550 sets I am much intersted.
Even the Buy.com Westinghouse was like $700 and its the bottom of the barrel IMO for a good set.
Gatsu
« Reply #26 on: February 12, 2009, 09:30:04 am »
I've got a Vizio 27" 720p set and have been very pleased with it. I paid under $500 for it at the time.
RetroGreg
« Reply #27 on: February 12, 2009, 11:04:11 am »
I have a 32" 720 p Vizio that I use with my 360 and it has been great. No lag or issues at all.
MrMojoZ
« Reply #28 on: February 12, 2009, 11:52:41 am »
http://www.google.com/products?q=37%22+HD+LCD&oe=UTF-8&sa=N&lnk=pruser&price1=500&price2=550
Umm okay.
I like projectors alot, but they aren't the bang for buck option.  :cheers:
Necroticart
« Reply #29 on: February 13, 2009, 03:07:01 am »
ok here is what i've got so far still needs alot of work for one the PDF has the board thickness around 1 1/2" and i'm still working out the cp build details and the top back still needs slimmed down but, I wanted to post up the sketchup file for all of you to can get a 3D veiw of the machine as Pictures can only go so far.
« Last Edit: February 13, 2009, 03:16:22 am by Necroticart »
Blanka
« Reply #30 on: February 13, 2009, 03:32:48 am »
Don't use the 38mm MDF. The core is much less dense than in thinner panels. Glue together two 18mm sheets.
Demmit, Sketchup 7. Still have to buy that version  :cry:
Necroticart
« Reply #31 on: February 14, 2009, 10:21:48 am »
thanks for the tip can see the logic behind it.  Also i'm still working on the file i'll post up a better version when i'm done
Numbski
  • Last login:November 03, 2020, 01:51:50 pm
    • Numbski
« Reply #32 on: March 26, 2009, 07:51:37 am »
Resolution wouldn't be my primary concern, but refresh rate.  It makes a HUGE difference.  I have an older rear-projection 720p/1080i Sony, and side by side with a recent model that does higher refresh rates, there's just no comparison.
Build a man a fire, keep him warm for the night.
Set a man on fire, keep him warm for the rest of his life.
Gatsu
« Reply #33 on: March 26, 2009, 11:17:58 am »
can't wait to see this cab done. A fellow japanese cab project. hehe.
yuro
  • Last login:March 04, 2019, 05:36:45 pm
« Reply #34 on: April 13, 2009, 09:09:03 pm »
Any updates on this?
I would love to get my hands on that sketchup file!
Necroticart
« Reply #35 on: April 15, 2009, 09:48:26 pm »
Sorry I have not had any time to work on it lately I'm in the process of moving to a new house but I gave my original file to Donovan and his modified design just caught the eye of Seth Killian ;D http://www.capcom-unity.com/street_fighter/blog/2009/04/15/totally_amazing_fanmade_sfiv_cabinet.
also if you want the sketchup file it's posted in one of my previous posts
« Last Edit: April 15, 2009, 09:52:13 pm by Necroticart »
mayhem
  • Last login:July 11, 2016, 03:37:04 am
  • http://cmaccs.com/
    • C-Macc's
« Reply #36 on: April 15, 2009, 10:07:36 pm »
this is different. could easily knock up that frame in metal as well ... the wood work would be a problem for me though ..
OI like what the other lads done very good .
