Author Topic: Mala crashing  (Read 3305 times)
ivwshane
    • My first mame cab! (WIP)
Mala crashing
« on: February 04, 2009, 01:08:52 am »
I'm using a tree and when I go to a sub menu and then back out it crashes.
This is what the malaexelog says:
2009/02/03  22:05:13.06   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02700000
2009/02/03  22:05:13.07   Error: Object Class: TfrmMain, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02700000
2009/02/03  22:05:18.45   Error: Object Class: TfrmMain, Object Function: CropStringLength, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02700000
loadman
  • Moderator
    • MaLa
Re: Mala crashing
« Reply #1 on: February 04, 2009, 01:38:46 am »
Make sure you are using an appropriate graphic
ivwshane
Re: Mala crashing
« Reply #2 on: February 04, 2009, 01:49:03 am »
What exactly is appropriate?
I don't have any porn images showing:p
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
Re: Mala crashing
« Reply #3 on: February 04, 2009, 08:37:52 pm »
REMOVE all screenshots for mame or one emulator at a time. When it quits crashing, you could slowly add the screenshots back in, a handfull at at time to help narrow down where the problem lies.
I had a very similar problem with mame screenshots. I just removed them all and haven't had time to put them back in yet.
Good luck!
ivwshane
Re: Mala crashing
« Reply #4 on: February 07, 2009, 03:31:59 am »
I just wanted to give an update. I still haven't pinpointed exactly what's causing the crash but removing the pics worked. Because it was crashing when I would go back to a category select screen I only removed the icons that were apart of that particular tree. What's weird is that one pic does work and when I compared it to another pic the properties were similar, so I'm not sure why on pic would work and another wouldn't, especially since the pics were all taken from a layout that had already been working.
loadman
  • Moderator
    • MaLa
Re: Mala crashing
« Reply #5 on: February 07, 2009, 03:57:33 am »
Can you post some graphics that mala does not like.
Possibly I could give a better error message to pin this problem down in future
ivwshane
Re: Mala crashing
« Reply #6 on: February 09, 2009, 01:11:03 am »
The pacman one works but the ryu one doesn't.
