Author Topic: robotron cocktail degauss needed...?  (Read 4089 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: February 01, 2009, 11:23:15 am »
so i moved my robotron cocktail...it was facing east/west...but now it needs to be running north/south...
the problem is that when i rotate it ninety degrees...the colour on the right(east) side fades drastically...
am i going to need a degaussing wand or is there a better way to get the monitor back to normal...?
thanks... :cheers:
Kevin Mullins
    • Me on Myspace
Re: robotron cocktail degauss needed...?
« Reply #1 on: February 01, 2009, 12:07:31 pm »
Are you leaving it OFF for awhile before or after moving it ?
The auto degauss only works when it's "cold".
(if it is working at all)
fixedpigs
« Reply #2 on: February 01, 2009, 01:15:24 pm »
it was off for at least two months...
i then moved it to a new house where it was oriented north/south...
i turned it on to find that the right(east) side of the monitor was faded...
i then rotated the table ninety degrees while it was on and the colour returned...
Level42
« Reply #3 on: February 01, 2009, 02:43:04 pm »
Anything magnetic next to it ? Speakers, other machines ?
fixedpigs
« Reply #4 on: February 01, 2009, 04:20:10 pm »
nope...not at all...
i was figuring that the magnetic poles were affecting it since the monitor lies flat... ???
Level42
« Reply #5 on: February 01, 2009, 04:58:57 pm »
Yes it does have more effect.
fixedpigs
« Reply #6 on: February 12, 2009, 12:03:46 am »
so here are some photographs of what i'm talking about...
running north/south and there is the fading on the right side...
running east/west and everything is dandy...
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: February 12, 2009, 07:42:29 am »
Looks familiar -- my Joust cocktail is the same way. If I would rotate it, even temporarily, it would end up needing degaussing, even after moving back. I used a corded drill waved in circular motion over the affected area when I didn't want to wait for the degaussing coil to kick in. Worked OK, although the drill has since died.
As the fates would have it, when I rearranged the games, it has ended up facing so that it had no problems at all.
Working: Not Enough
Projects: Too Many
Progress: None
themonk3y
  • Last login:February 12, 2010, 08:23:37 pm
« Reply #8 on: February 12, 2009, 10:24:38 am »
How did you degauss with a drill?
fixedpigs
« Reply #9 on: February 12, 2009, 10:38:44 am »
exactly...!
how do i degauss this thing...?
thanks...!
CheffoJeffo
« Reply #10 on: February 12, 2009, 11:13:12 am »
Place the drill body parallel close to the problem portion of monitor, start it up and move it in circles gradually increasing the diameter and distance from the screen. Can also use a soldering gun (not iron, but a gun).
Randy Fromm has some magic words that he recommends you recite during the process, but I don't have them handy.  ;)
Working: Not Enough
Projects: Too Many
Progress: None
fixedpigs
« Reply #11 on: February 12, 2009, 11:19:23 am »
move it clockwise...counter-clockwise...does it matter...?
should the drill itself be spinning clockwise or counter...does it matter...?
thanks again... :cheers:
CheffoJeffo
« Reply #12 on: February 12, 2009, 12:57:24 pm »
Doesn't matter -- you just need a moving, fluctuating magnetic field.
In theory you can do it with static magnets, if you can move them fast enough.
Working: Not Enough
Projects: Too Many
Progress: None
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #13 on: February 12, 2009, 05:01:22 pm »
You can also stick small pieces of flexible stick-on magnet strips at key locations on the outside edge of the tube. (As was demonstrated by Mr. Rick Nieman of Nieman Displays)
NO MORE!!
Mauzy
« Reply #14 on: February 12, 2009, 06:24:50 pm »
You could also place it wherever it is going to stay and lay a 19 inch TV face down directly over the tube of the game monitor. Turn on the TV causing it to degauss itself, thus degaussing the game monitor at the same time. I've done this a couple times and it always works nicely.
