Author Topic: Info Window Position Question  (Read 2194 times)
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« on: January 31, 2009, 12:34:42 am »
I am currently using MaLa in a dual monitor setup. The main monitor is a widescreen monitor that is rotated and the second monitor is a standard monitor in normal orientation. I have been able to create a layout that works very well with this arrangement.
I want to be able to use the Info window to display flyers for each of my games. This works well too, except for the fact that the Info window opens in the middle of the layout. This puts most of the info window on the main monitor and the rest of it on the secondary monitor.
I would like to know if there is any way to have the Info window open lower down so that it is entirely on the main monitor. Any comments or suggestions would be greatly appreciated.
Cheers.
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Info Window Position Question
« Reply #1 on: January 31, 2009, 01:12:06 am »
That should be easy.
I will put it on my list
froggerman
« Reply #2 on: January 31, 2009, 01:24:39 am »
That would be great. I had a couple of other requests but it looks like you have taken care of them according to your WIP log.
Cheers.
