Author Topic: Tab not working in MAME  (Read 7238 times)
MilitiaMan
  • Last login:May 28, 2011, 09:25:35 am
  • It's a fine line between hobby and mental illness.
« on: June 24, 2003, 02:45:09 pm »
This is probably the most frustrating thing I have ever experienced with MAME or the building of my cab ... and the answer is probabnly going to be painfully easy.
Here is the problem:
I can't get into the options/settings area of MAME ... I press tab on the kb, I press the button on my cp I have assigned to tab and nothing happens.  :-[
I can go to notepad and press tab repeatedly to verify that the buttons are working but for some reason MAME is not recognizing this as the command to open the settings box.
Any ideas?
MM
AlanS17
    • AlanS17
Re:Tab not working in MAME
« Reply #1 on: June 24, 2003, 02:48:00 pm »
Did you somehow redefine the button? Try installing a fresh copy of MAME or something and start from scratch.
SNAAAKE
  • -Banned-
« Reply #2 on: June 24, 2003, 02:51:07 pm »
delete the .CFG files !
and next time you start mame,everything will be default. ;)
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: June 24, 2003, 02:51:31 pm »
Any ideas?
MM
Delete your C:\Mame\mame.cfg file (older MAME versions).  If that doesn't work, look for a C:\mame\cfg\default.cfg file and delete it.  You will then need to reset your "Inputs - All games" settings if you changed them.
Reply back if that doesn't work and I'll try to come up with something else.
The Man
  • Last login:August 27, 2009, 03:41:49 pm
  • I'm easy like Sunday mornin!
« Reply #4 on: June 24, 2003, 02:58:04 pm »
Any ideas?
MM
I have the same problem.  I just delete the default.cfg file and its fixed.  But this happens all the time on the CP I built for my Brother In-law.  I have a couple of questions for you:
What version of MAME are you using?
Are you using an encoder and what kind is it?
What OS are you running?
I sure would be interested to find what's doing this.  I know that a person isn't redefining the TAB key, so I would like to find out what causes this.
Thanks,
TM
AlanS17
    • AlanS17
« Reply #5 on: June 24, 2003, 03:02:54 pm »
It's the MAME gnomes. They're sneaky devils...
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« Reply #6 on: June 24, 2003, 03:04:59 pm »
I thought they stopped selling Tab years ago.
mclaught
  • Last login:April 20, 2006, 08:09:11 pm
« Reply #7 on: June 24, 2003, 05:01:45 pm »
i had the same problem with version .37b5, tab didn't work at all. I then installed version .61 and it worked fine. Try installing a newer version if nothing else works, it worked for me.
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #8 on: June 24, 2003, 05:07:29 pm »
I have a bad story on this one...
I pushed Esc trying to get myself out of the control CFG menu... but it mapped the cfg menu to "none".
Snaake is dead-on!
Visit my MAME lightgun site:
http://www.lightgun.tk
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: June 24, 2003, 08:53:14 pm »
Redefining tab is one the easiest things to (accidently) do; it only takes four key presses: [TAB], [Enter], [Enter], [ESC] (and then [ESC], [ESC] to finalize it.)
One way to protect against this is delete cfg/default.cfg, start any game in mame, exit mame, and then make the just created cfg/default.cfg read-only.
Robin
Knowledge is Power
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: June 24, 2003, 08:59:38 pm »
Hey, Tiger-Heli,
How old?  0.37b series or before?  Not anytime within year or two, I don't think.  Just wondering. :)
Robin
Knowledge is Power
OSCAR
    • Oscar Controls
« Reply #11 on: June 24, 2003, 10:33:52 pm »
Hey, Tiger-Heli,
dosMAME .70 still uses the mame.cfg file, doesn't it?  Just the winMAME compiles use the mame.ini file if I'm not mistaken, but I've been wrong before...
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #12 on: June 25, 2003, 02:31:27 am »
Hey, Tiger-Heli,
Yes, but the current (and recent) dmame mame.cfg file does not contain any info on key input remapping.  Tiger-Heli was suggesting deleting mame.cfg would fix the TAB input problem, and I don't remember mame.cfg containing the input info.
I was introduced to mame at 0.37b12, but didn't get into coding it until pretty much the end of the 0.37b series; that's why I ask "how old?"  I'm a "middle-ager" when it comes to mame.
Robin
Knowledge is Power
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #13 on: June 25, 2003, 03:24:58 am »
Hehe, suprised no one suggested ctrlr files yet?  Then definately make the default.cfg read only.
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: June 25, 2003, 06:38:13 am »
Hey, Tiger-Heli,
I was thinking of before MAME went to a WinMAME/DMame split.  The command line version that ended up as DMAME.  I almost posted to delete your mame.cfg file, to which 90% of people would have said "Where's that, I don't have one?"
I feel very, very old . . .
OSCAR
    • Oscar Controls
« Reply #15 on: June 25, 2003, 08:46:56 am »
I pulled a hard drive out of one of my old computers a couple weeks ago and I found a MAME .28 installation on it.  And I know I had MAME on a different computer before that one.  Heh, now I feel old, too...   ;)
Tiger-Heli
    • Tiger-Heli
« Reply #16 on: June 25, 2003, 09:04:45 am »
Quote from: OSCAR
I think it was somewhere late 0.33, early 0.34 for me.  I don't feel as old anymore.   Thanks OSCAR!
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #17 on: June 25, 2003, 03:30:09 pm »
Don't you mean mame\cfg\default.cfg, this is the file to delete, it contains all the key bindings.
