Author Topic: Vid of my Mame Cab  (Read 2549 times)
TrAb
  • Last login:April 14, 2020, 05:24:51 pm
Vid of my Mame Cab
« on: January 29, 2009, 03:27:27 pm »
Watch in High quality
« Last Edit: January 29, 2009, 03:35:14 pm by TrAb »
Ginsu Victim
  • Comanche, OK -- USA
Re: Vid of my Mame Cab
« Reply #1 on: January 29, 2009, 03:44:13 pm »
Use InstantSheller. You can hide all of that startup garbage.
TrAb
« Reply #2 on: January 29, 2009, 04:11:40 pm »
I heard of that, im going to try it tonight. Thanks
ivwshane
    • My first mame cab! (WIP)
« Reply #3 on: January 29, 2009, 04:39:43 pm »
It looks pretty nice! I like the video preview for the games, how hard was that to implement?
Would you mind sharing your mala layout?
TrAb
« Reply #4 on: January 29, 2009, 04:43:30 pm »
The video's were not hard to get working. Just downloaded the video pack which took forever to download but it was worth it. I cant remember the site but im sure somebody on here will give u the link. Also i have no problems sharing the layout, but it isnt mine i got it off a user on this board so it is on here somewhere. If i can find the link ill post it up.
IG-88
« Reply #5 on: January 29, 2009, 04:59:40 pm »
I'm confused. Why do you need MaLa and Emu Loader both?
-HarumaN
Ginsu Victim
« Reply #6 on: January 29, 2009, 05:09:22 pm »
is it both or just the video?
severdhed
  • Last login:Yesterday at 04:00:01 pm
  • RIP Dinosaur Hippo
« Reply #7 on: January 29, 2009, 05:21:39 pm »
here is a link to that mala layout...i just saw this the other day
http://forum.arcadecontrols.com/index.php?topic=72576.0
TOK
  • The Game Always Wins
« Reply #8 on: January 29, 2009, 08:04:16 pm »
Is this a pretty typical load time for the newer front ends with extra's like videos? I think it was like 1:20 to the point where you could choose a game.
I'm running a stripped down version of XP and MaLa. My cab is to the menu in about 35 seconds and I'd like it quicker.
Thats a nice setup, but I think all the splash screens and stuff would make me nuts.
TrAb
« Reply #9 on: January 29, 2009, 11:09:48 pm »
Im not using emu loaded i just found that video and it was the best one i saw so i just use it  :laugh2:
cyapps
  • Last login:January 04, 2011, 02:51:31 pm
« Reply #10 on: January 29, 2009, 11:20:14 pm »
I believe http://www.emumovies.com has video previews of games.
TrAb
« Reply #11 on: January 29, 2009, 11:43:14 pm »
I tried that instant sheller out and it does get rid of the screen i was wanting to get rid of. But it also annoys me, because i do sometimes like to tab out of mala and use the desktop and it just makes the desktop not load at all.
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #12 on: January 29, 2009, 11:47:30 pm »
After exiting mala, hit ctrl+alt+del, choose new task, then type "explorer.exe"
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Ginsu Victim
« Reply #13 on: January 29, 2009, 11:53:39 pm »
Set Mala to run explorer.exe upon exit, or when you exit Mala, just CRTL+ALT+DEL and run explorer.exe from there.
Of course you don't have to shell to mala. You could just use everything else InstantSheller offers and set mala to run on startup the normal way.
TrAb
« Reply #14 on: January 30, 2009, 12:03:49 am »
I tried running explorer.exe first thing and all it did was bring up my documents, the desktop did not load or anything. But i may just not shell anything and use its other features as mentioned. Thanks guys ill get a new vid soon
Ginsu Victim
« Reply #15 on: January 30, 2009, 12:44:36 am »
It won't load your desktop. It will take you to Windows Explorer. You can only get a desktop by shelling to explorer first thing.
Ummon
  • Trade Count: (+13)
« Reply #16 on: January 30, 2009, 03:11:03 am »
Is there a thread with your cab components and specs?  If not, what monitor are you using?
Yo. Chocolate.
Stephen Hawking
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« Reply #17 on: January 30, 2009, 06:15:28 am »
I noticed you have Primal Rage on your menu, is that a working version?
TrAb
« Reply #18 on: January 30, 2009, 11:09:03 am »
Yeah it works, just on some characters when they fall they animation is messed up for a split second but other than that its fine. Very playable...
TrAb
« Reply #19 on: January 30, 2009, 11:10:21 am »
The monitor is a 25" MK1 monitor, not sure which model and make exactly  :dunno sorry.
severdhed
« Reply #20 on: January 30, 2009, 12:41:26 pm »
that is because mala is not shelled correctly.  there are two places in the registry where you can specify which application is the shell.    one under HKLM and one under HKCU.  (plus there is a key that tells your PC which one to use)  if you set it as shell under HKLM, when you try to manually run explorer, you just get windows explorere.  if you set it under HKCU, and then manually launch explorer, it will load the windows desktop like normal.
if you follow the instructions in the WIKI under Hiding Windows, it will show you what settings to change to make this work.
Ginsu Victim
« Reply #21 on: January 30, 2009, 01:37:02 pm »
Ooo, didn't know that. Thanks for the tip.
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #22 on: February 02, 2009, 11:11:02 am »
Looks nice all the way around.  :applaud:
You should compile your version of Mame as well to get rid of the nag screens.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Ginsu Victim
« Reply #23 on: February 02, 2009, 11:18:45 am »
I finally did that the other day. No nag screens and hiscore saving FTW!
Visitor Q
  • The Saw Is Family
« Reply #24 on: February 02, 2009, 11:57:07 am »
Having a Mame cab without hi score support is like eating cake without icing.  :P
Ummon
« Reply #25 on: February 02, 2009, 09:34:04 pm »
I'd just use savestate. If it goes away, then so be it. Kind of refreshing, actually, to see a default score board.
Yo. Chocolate.
Stephen Hawking
