Author Topic: Will newer versions of Mala require starting from scratch?  (Read 2418 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
« on: January 27, 2009, 08:02:55 pm »
When upgrading to newer versions of Mala in the future, do you have to go through and set EVERYTHING up again? All game directories, settings, checkboxes.....
If so, can you please consider an "upgrade" button or something that will keep current settings/directories, but still install the newer version and it's features/fixes?
If it's already possible to keep current settings, please explain how.
loadman
  • Moderator
    • MaLa
Re: Will newer versions of Mala require starting from scratch?
« Reply #1 on: January 27, 2009, 08:05:58 pm »
No Normally you don't do anything. Just swap the mala.exe over
However with the next version 'layouts' will be automatically upgraded (to handle definables for 'other emu's) which means they won't load on older versions again.
vetteguy112233
« Reply #2 on: January 27, 2009, 08:29:12 pm »
So as long as you aren't going from a new version to an older version, then you don't have to worry about anything. Just copy Mala.exe and all settings cary over?
loadman
  • Moderator
    • MaLa
« Reply #3 on: January 27, 2009, 09:12:45 pm »
Yes
