Author Topic: Mala won't shut down windows, standby or run explorer after quiting.  (Read 5219 times)
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
Mala doesn't run whatever selection I have made when I quit the program. I'm running Windows XP in a shell and when I quit Mala with explorer.exe in the command the screen just goes to my desktop. No Explorer. I can get there using control-alt-delete and then running explorer or shutdown or standby from the taskbar menu either on run program or just the shutdown button. Any thoughts?
loadman
  • Moderator
    • MaLa
Re: Mala won't shut down windows, standby or run explorer after quiting.
« Reply #1 on: January 27, 2009, 02:09:34 pm »
Watz the debug log say?
dkubarek
« Reply #2 on: January 27, 2009, 08:30:26 pm »
Yea, sorry, I just learned how to activate the debug log. I bet that helps solve the problem. Here's some of the log where it occurred:
2009/01/27  20:32:25.78   Info: Starting MaLa 1.0.5.8
2009/01/27  20:32:25.79   Info: Check plugin directory: C:\mala\plugins
2009/01/27  20:32:25.79   Info: Collecting event plugins (*.mplugin) in C:\mala\plugins\
2009/01/27  20:32:25.81   Info: Check backup directory: C:\mala\backups
2009/01/27  20:32:25.81   Info: Check to see if hook dll is required
2009/01/27  20:32:25.81   Info: Win98/ME Hook dll not loaded because OS is: WinXP
2009/01/27  20:32:27.70   Info: Loading config params from ini file
2009/01/27  20:32:27.76   Info: Setting params from ini file
2009/01/27  20:32:27.76   Info: Creating and loading mame cl conditions: C:\mala\mame.clc
2009/01/27  20:32:27.78   Info: Creating and loading mame info pages: C:\mala\mame.mli
2009/01/27  20:32:27.78   Info: Creating and loading other emu info pages: C:\mala\otheremu.mli
2009/01/27  20:32:27.78   Info: Creating and loading filter sets: C:\mala\mala.mlf
2009/01/27  20:32:27.78   Info: Creating and loading non mame emulators: C:\mala\mala.mle
2009/01/27  20:32:27.78   Info: Creating and loading layout ...
2009/01/27  20:32:27.79   Info: Collecting layout files (*.mll) in C:\mala\
2009/01/27  20:32:27.79   Info: Creating and loading mala tree
2009/01/27  20:32:27.79   Info: Collecting game list files (mlg) in C:\mala\
2009/01/27  20:32:27.79   Info: Creating and loading bios
2009/01/27  20:32:27.92   Info: Creating audio object
2009/01/27  20:32:28.07   Info: Creating and loading mala lcd screens
2009/01/27  20:32:28.07   Info: Creating and loading mame lcd screens
2009/01/27  20:32:28.07   Info: Creating and loading jukebox lcd screens
2009/01/27  20:32:28.07   Info: Creating and loading led config and attroct mode list
2009/01/27  20:32:28.07   Info: Collecting attract mode files (*.mlc) in C:\mala\
2009/01/27  20:32:28.07   Info: Loading game list: C:\mala\01093bros_favs.mlg
2009/01/27  20:32:28.07   Info: Loading layout: C:\mala\alien.mll
2009/01/27  20:32:42.35   Info: Destroying audio object
2009/01/27  20:32:42.50   Info: Writing params to ini file
2009/01/27  20:32:42.60   Info: Screensaver: ScreenSaver Form Destroyed
2009/01/27  20:32:42.95   Info: Showing taskbar
2009/01/27  20:32:42.95   Info: Closing MaLa 1.0.5.8
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #3 on: January 27, 2009, 08:51:39 pm »
you dont have a tick in use alternative shutdown method do you
dkubarek
« Reply #4 on: January 27, 2009, 09:37:36 pm »
no. nothing checked in alternative shutdown.
dungbeetle46
« Reply #5 on: January 27, 2009, 09:52:14 pm »
what are you using to shell mala
dkubarek
« Reply #6 on: January 27, 2009, 10:24:19 pm »
I'm not great with computers so I'm not sure if I'm answering this right. But, I'm using Windows XP pro and I made a shell in the registry.
dungbeetle46
« Reply #7 on: January 27, 2009, 10:41:40 pm »
try shelling with instantsheller (googleit) should fix the problem
dkubarek
« Reply #8 on: January 27, 2009, 10:57:17 pm »
Should I start over, or can I just have instant sheller override what I did? I used the wiki and liked my results. I also heard of a few people having instant sheller force a reinstall of Windows, which would suck. I'm fine with Mala now. I rarely need to have it shut down because I have Windows set to go to standby. I just wanted to see if there was an easy fix for Mala not running anything at close.
dungbeetle46
« Reply #9 on: January 27, 2009, 11:00:37 pm »
I am not sure if instantsheller will clash with your already done registry changes but I have used instantsheller for over 3 years in 7 cabs and never had a problem, so I will leave that decision to you
cheers
dkubarek
« Reply #10 on: January 28, 2009, 08:24:24 pm »
Probably a mistake on my part for assuming this, but Mala exits fine on esc, just not exiting using the mouse. It's not in a cab yet, but when it is I won't have a mouse so I'm good to go. Thanks for the help.
loadman
  • Moderator
    • MaLa
« Reply #11 on: January 29, 2009, 07:39:35 pm »
Yep,
If you exit via mouse it  assumed you are doing it for maintenance purposes and won't won't to shut down windows too.
