Author Topic: Load Application on Mala Load (Resolved: use MaLa Launcher plugin)  (Read 3899 times)
kagaden
  • Last login:September 10, 2022, 10:58:37 pm
Hi Loadman,
I have Mala shelled into Windows XP and I'm running a script called HyperAttract that Brian_Hoffman created for me. Essentially what it does is exit out of any emulator after a period of inactivity, and back to the Mala frontend, allowing the monitor to go into sleep mode. I don't believe there's a feature in Mala like this yet. However, there's a problem with the timer running this type of script as a service. You can view the thread in the software forum here for details:
http://forum.arcadecontrols.com/index.php?topic=88532.0
I noticed that there was a feature to load on Mala exit, so I was curious if you could implement a feature that would allow the loading of .exe's on Mala startup in the next version of Mala? Hopefully this wouldn't be too troublesome and I'd kindly donate for the feature.
Thanks for the great frontend!
-K
« Last Edit: January 25, 2009, 06:16:58 pm by loadman »
loadman
  • Moderator
    • MaLa
Re: Feature Request: Load Application on Mala Load
« Reply #1 on: January 25, 2009, 01:31:51 am »
Couldn't you write a simple batch file that loaded this program then mala?
or possibly you could try loading this as a sudo encoder?  options- controller - encoder
« Last Edit: January 25, 2009, 01:34:41 am by loadman »
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #2 on: January 25, 2009, 02:07:10 am »
Get the MaLa Launcher plugin I wrote from malafe.net.
loadman
  • Moderator
    • MaLa
« Reply #3 on: January 25, 2009, 01:00:59 pm »
kagaden
« Reply #4 on: January 25, 2009, 02:04:19 pm »
Ah hah, good to know ;P I'll give it a shot. Thanks guys!
loadman
  • Moderator
    • MaLa
« Reply #5 on: January 25, 2009, 02:38:54 pm »
Let us know how it goes. Not sure if we have much feedback for that plugin
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #6 on: January 25, 2009, 05:43:24 pm »
I use it to launch cpwizard and its working fine for me
kagaden
« Reply #7 on: January 27, 2009, 12:51:41 am »
Installed it tonight and it worked like a charm. Thanks a million again guys!
TheShanMan
Re: Load Application on Mala Load (Resolved: use MaLa Launcher plugin)
« Reply #8 on: January 27, 2009, 01:11:05 pm »
I wrote it for my own use but glad it's helping others out too!
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #9 on: January 27, 2009, 01:16:43 pm »
Hey Shan, I am just curious what you load during Mala setup that required a plug-in verses putting that item in the windows startup folder.
-csa
TheShanMan
« Reply #10 on: January 27, 2009, 05:29:48 pm »
I have mala set as my shell, not explorer. So the windows startup folder doesn't work.
