Author Topic: Auto power on questions  (Read 901 times)
ivwshane
    • My first mame cab! (WIP)
« on: January 24, 2009, 04:00:31 am »
I know there have been plenty of similar topics but my setup might be unique.
I just got my smart strip power strip and I'm trying to figure out the best way to use this thing.
I can power up my computer using the tv as the control device but then I run into the problem of when I shut down my computer I still will have to manually shut down the tv.
I can power off the tv if I use the computer as the control device but then I have the problem of the tv not being able to power ON automatically.
My tv powers on by a simple momentary switch and I could very easily replace the switch or solder it to something else if I have to. The question is what would I connect it to?
Anyone have any ideas on how I could simplify this?
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: Auto power on questions
« Reply #1 on: January 24, 2009, 04:29:06 am »
This is a problem with TVs that dont power back on.
Can you just hold the power button in with something?
ivwshane
« Reply #2 on: January 24, 2009, 05:12:02 am »
I feel like an idiot :banghead:
I assumed that because the power button on the tv was a momentary switch and that holding it down would simply turn the tv off and on, so I didn't bother checking:o
Ok so I can hold down the button and power the pc and tv on and off via the pc.
Which leads me to my next question; Since I can hold down the button on the tv couldn't I just replace it with a standard on/off button/switch?
Also if I want to have a master switch which controls power from the wall into the cab is there a certain type of switch or a certain rating I need to be aware of before buy one?
For example, I have an old power supply that I gutted for parts and that included an ac male connector:
and a toggle switch like this:
The male connector says: 10A 250V,
the switch says this:
5A 250VAC
10A 125VAC
7A 250VAC
That would connect to the cord from the wall.
Inside the cab I would have another male connector where the smart strip would connect.
« Last Edit: January 25, 2009, 12:33:02 am by ivwshane »
