Author Topic: Game Launcher and MAME  (Read 3492 times)
chuggy
  • Last login:December 12, 2004, 11:37:49 pm
« on: June 23, 2003, 08:36:03 pm »
I know that i dont know a lot about the software end of this, but im sure this will prove that! I am trying to run MAME and nesticle through game launcher. I got Nesticle running without a problem, but i cant get MAME to run, all my screenshots will load, and it found my directory, but when it opens the game it just goes black for a second, and then goes back to GL. ANy ideas?
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
Re:Game Launcher and MAME
« Reply #1 on: June 23, 2003, 09:07:09 pm »
edit your mame config file
-- banned --
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: June 23, 2003, 09:07:31 pm »
When you are first setting up emus in GL, set it up with the debug option (in glaunch.cfg i believe) on to see what GL is passing in the command line and more importantly to see the error message.
You can also look at runit.bat and the logs in the log directory...
*Shrug* those are good starting points.
report back with more info if you can't figure it out that way.
Rampy
chuggy
« Reply #3 on: June 23, 2003, 09:39:25 pm »
the error message is as follows:
C:\mame .exe   .mario
'mame.exe' is not recognized as an internal or external command, operable program or batch file
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #4 on: June 24, 2003, 12:12:16 am »
C:\mame .exe   .mario
Ah yes, wonderful buggy GameLauncher.  Make your roms folder a subfolder of where your mame.exe folder is.  Then tell GameLauncher not to send full rom path.
In your example, your rom folder would be c:\roms
I struggled with this stupid problem for a week before I finally figured it out.  For some reason, Game Launcher replaces the path "c:\roms\" with "."  $20 says this will fix your problem.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
chuggy
« Reply #5 on: June 24, 2003, 02:11:12 am »
being the fool that i am i slightly botched the error. Oops!
Here is what it really said:
C:\mame> mame.exe marble
'mame.exe' is not recognized as an internal or external command operable program or batch file.
C:\mame>cd C:\GL\glaunch
C:\GL\glanunch>pause
Press any key to continue
My roms folder is in C:\mame\roms
exe is in C:\mame
Dave Dribin
  • Last login:May 26, 2007, 11:17:39 pm
  • ugh... yeah
    • Dave Dribin's Home Page
« Reply #6 on: June 24, 2003, 04:00:48 am »
It means exactly what it says.. "mame.exe" is not a valid executable.  Can you run MAME by hand?  If so,  what is the exact command you use?
-Dave
Odonadon
    • Turbo2k
« Reply #7 on: June 24, 2003, 12:26:34 pm »
exe is in C:\mame
Sounds like you're running Win2k or XP, and it can't find any file by the name of mame.exe .  Which version of mame do you have installed?  DOS command line?  If that's so, it should be dmame.exe.  Fastmame?  Shoudl be fastmame.exe.  Verify that you do indeed have a mame.exe in that directory.
Odonadon
rampy
  • *shrug*
« Reply #8 on: June 24, 2003, 12:40:57 pm »
I've been bitten by the mamepp.exe bug before =P
usually i rename it to mame.exe for simplicities sake...
Rampy
chuggy
« Reply #9 on: June 24, 2003, 06:01:02 pm »
Ok
so i got it to launch the games that i have. But now i cant seem to remove the unwanted games from my list. Do i want to use a rom file or not? It would seem easier to not, but it doesnt find any roms if i have it set to no. Also my map file seems to be right, but its not reading that either?
arrrrrg!
chuggy
« Reply #10 on: June 24, 2003, 06:52:48 pm »
another notch completed.
I got the directory to work, but now for some reason. My map file is only showing some of the games properly? I even cut and pasted the rom names from the rom file so i know they are the right names. Any other ideas. Its not all of the games only some of them.
Dave Dribin
  • ugh... yeah
« Reply #11 on: June 27, 2003, 12:06:07 am »
Which games work and which games don't?  List a couple examples of each, and their corresponding entry in the map file.  It could be an upper case/lower case issue, though I thought I fixed that.
-Dave
chuggy
« Reply #12 on: June 28, 2003, 09:30:05 pm »
Thanks for the reply, but i got it to work. I cant actually tell you what was wrong, cuz i dont know. lol. Now all i got to do is find a stable nes emulator.
