Author Topic: how do I get ledblinky (color.ini) to match the buttons I have configured?  (Read 7644 times)
ivwshane
    • My first mame cab! (WIP)
I'm using mala (I would love to be able to do this in mame32 though) and I've managed to figure how to show button colors with the use of colors.ini but it's not matching/mapping to the way I have the buttons configured.
My layout is like this:
 p1   a1 a2   p2
 567             567
 234             234
1                 1
Right now it shows the p1 and p2 buttons as a1 and a2, what do I need to do to correct this?
Also how can I specify certain button layouts for specific games and have the colors match as well?
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Make sure your Device/Port input map is correct - the LEDs must be assigned to the same keycodes as the keyboard encoder. If you turn on the Debug/Verbose option (Misc Options tab), run a game, then post or email the debug.log file, I should be able to solve the problem.
By the way, you can use LEDBlinky with Mame32. From the FE menu, select 'Other' and from the Mame tab, check the 'Use MAME to Trigger Game Start/Stop Events' option. Then run LEDBlinky.exe before you start Mame32. But you won't be able to use any of the FE options.
Robots will kill you.
Arcade Addiction
ivwshane
Thanks.
[01/22/2009 12:34:40]
[01/22/2009 12:34:40] LEDBlinky v3.7.3.0
[01/22/2009 12:34:40] Received Event - Queue:[1] Msg:[8].
[01/22/2009 12:34:40] Detected LED Devices: 101000000000000000000000
[01/22/2009 12:34:40] MaLa UI LED profile:
[01/22/2009 12:34:40] Device 1; PBA:49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 12:34:40] Device 3; PBA:0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 12:34:40] Game Start Key: 49
[01/22/2009 12:34:40] Emulator: [MAME]
[01/22/2009 12:34:40] 4 games loaded from Controls_override.ini
[01/22/2009 12:34:40] Controls.dat INI file Version=0.111.5, Time=2008-06-20 18:27:09, Generated by=SirPoonga
[01/22/2009 12:34:40] 1065 games loaded from controls.ini
[01/22/2009 12:34:40] MAME.xml v0.129 (JAN 4 2009)
[01/22/2009 12:34:42] 2917 games loaded from Mame.xml
[01/22/2009 12:34:42] 3501 clones loaded from Mame.xml
[01/22/2009 12:34:42] 1389 games loaded from Colors.ini
[01/22/2009 12:34:42] Received Event - Queue:[1] Msg:[9~SFEXP~2P sim~].
[01/22/2009 12:34:42] Received Event - Queue:[1] Msg:[9~SFEX2P~2P sim~].
[01/22/2009 12:34:44] Received Event - Queue:[1] Msg:[9~SFEX2~2P sim~].
[01/22/2009 12:34:44] Received Event - Queue:[1] Msg:[9~SFEX2P~2P sim~].
[01/22/2009 12:34:44] Received Event - Queue:[1] Msg:[9~SFEXP~2P sim~].
[01/22/2009 12:34:45] Received Event - Queue:[1] Msg:[9~SF2~2P sim~].
[01/22/2009 12:34:47] Received Event - Queue:[1] Msg:[3].
[01/22/2009 12:34:47] Control List for SF2: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_BUTTON6|P1_JOYSTICK_UP|P1_JOYSTICK_DOWN|P1_JOYSTICK_LEFT|P1_JOYSTICK_RIGHT|START1|COIN1|P2_BUTTON1|P2_BUTTON2|P2_BUTTON3|P2_BUTTON4|P2_BUTTON5|P2_BUTTON6|P2_JOYSTICK_UP|P2_JOYSTICK_DOWN|P2_JOYSTICK_LEFT|P2_JOYSTICK_RIGHT|START2|COIN2|CONTROL_JOY8WAY
[01/22/2009 12:34:47] Device 1; PBA:49,0,0,0,0,49,49,49,49,49,0,0,0,0,49,0,49,49,49,0,0,0,0,0,0,49,0,0,49,49,49,0
[01/22/2009 12:34:47] Device 3; PBA:0,0,49,49,0,0,49,49,49,0,0,49,49,0,0,0,49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 12:36:23] Received Event - Queue:[1] Msg:[4].
[01/22/2009 12:36:27] Received Event - Queue:[1] Msg:[2].
Here is my device port.ini if it helps.
;File created by GenLEDBlinkyInputMap.exe (arzoo 2008)
;For exclusive use with LEDBlinky Arcade LED Controller and Animation Editor.
;column 1: Label
;column 2: S=single R=red G=green B=blue
;column 3: input code(s). Seperate multiple values with bar (|).
[LEDWiz-Device1]
Port01=P1B1,R,JOYCODE_1_BUTTON1
Port02=P1B1,G,JOYCODE_1_BUTTON1
Port03=P1B1,B,JOYCODE_1_BUTTON1
Port04=P1B2,R,JOYCODE_1_BUTTON2
Port05=P1B2,G,JOYCODE_1_BUTTON2
Port06=P1B2,B,JOYCODE_1_BUTTON2
Port07=P1B3,R,JOYCODE_1_BUTTON3
Port08=P1B3,G,JOYCODE_1_BUTTON3
Port09=P1B3,B,JOYCODE_1_BUTTON3
Port10=P1B4,R,JOYCODE_1_BUTTON4
Port11=P1B4,G,JOYCODE_1_BUTTON4
Port12=P1B4,B,JOYCODE_1_BUTTON4
Port13=P1B5,R,JOYCODE_1_BUTTON5
Port14=P1B5,G,JOYCODE_1_BUTTON5
Port15=P1B5,B,JOYCODE_1_BUTTON5
Port16=
Port17=P1B6,R,JOYCODE_1_BUTTON6
Port18=P1B6,G,JOYCODE_1_BUTTON6
Port19=P1B6,B,JOYCODE_1_BUTTON6
Port20=P1B7,R,JOYCODE_1_BUTTON7
Port21=P1B7,G,JOYCODE_1_BUTTON7
Port22=P1B7,B,JOYCODE_1_BUTTON7
Port23=P1START,R,JOYCODE_1_START
Port24=P1START,G,JOYCODE_1_START
Port25=P1START,B,JOYCODE_1_START
Port26=JOY1,R,MOUSECODE_1_BUTTON1
Port27=JOY1,G,MOUSECODE_1_BUTTON1
Port28=JOY1,B,MOUSECODE_1_BUTTON1
Port29=JOY2,R,MOUSECODE_1_BUTTON2
Port30=JOY2,G,MOUSECODE_1_BUTTON2
Port31=JOY2,B,MOUSECODE_1_BUTTON2
Port32=
[LEDWiz-Device2]
Port01=
Port02=
Port03=
Port04=
Port05=
Port06=
Port07=
Port08=
Port09=
Port10=
Port11=
Port12=
Port13=
Port14=
Port15=
Port16=
Port17=
Port18=
Port19=
Port20=
Port21=
Port22=
Port23=
Port24=
Port25=
Port26=
Port27=
Port28=
Port29=
Port30=
Port31=
Port32=
[LEDWiz-Device3]
Port01=P2B1,B,JOYCODE_2_BUTTON1
Port02=P2B1,G,JOYCODE_2_BUTTON1
Port03=P2B1,R,JOYCODE_2_BUTTON1
Port04=P2B2,B,JOYCODE_2_BUTTON2
Port05=P2B2,G,JOYCODE_2_BUTTON2
Port06=P2B2,R,JOYCODE_2_BUTTON2
Port07=P2B3,B,JOYCODE_2_BUTTON3
Port08=P2B3,G,JOYCODE_2_BUTTON3
Port09=P2B3,R,JOYCODE_2_BUTTON3
Port10=P2B4,B,JOYCODE_2_BUTTON4
Port11=P2B4,G,JOYCODE_2_BUTTON4
Port12=P3B4,R,JOYCODE_2_BUTTON4
Port13=P2B5,B,JOYCODE_2_BUTTON5
Port14=P2B5,G,JOYCODE_2_BUTTON5
Port15=P2B5,R,JOYCODE_2_BUTTON5
Port16=
Port17=P3B6,B,JOYCODE_2_BUTTON6
Port18=P2B6,G,JOYCODE_2_BUTTON6
Port19=P2B6,R,JOYCODE_2_BUTTON6
Port20=P2B7,B,JOYCODE_2_BUTTON7
Port21=P2B7,G,JOYCODE_2_BUTTON7
Port22=P2B7,R,JOYCODE_2_BUTTON7
Port23=P2START,B,JOYCODE_2_START
Port24=P2START,G,JOYCODE_2_START
Port25=P2START,R,JOYCODE_2_START
Port26=MOUSE,B,TRACKBALL
Port27=MOUSE,G,TRACKBALL
Port28=MOUSE,R,TRACKBALL
Port29=
Port30=
Port31=
Port32=
arzoo
    • LEDBlinky
I need you to check off the 'Verbose' option also - this will generate a lot more info in the log.
Arcade Addiction
ivwshane
Sorry about that.
[01/22/2009 12:43:37]
[01/22/2009 12:43:37] LEDBlinky.mplugin> LEDBlinky MaLa Plugin v3.7.3.0
[01/22/2009 12:43:37] LEDBlinky v3.7.3.0
[01/22/2009 12:43:37] LEDBlinky.mplugin> Sending event message [FE_HANDLE 327982].
[01/22/2009 12:43:37] LEDBlinky.mplugin> Sending event message [FE_START].
[01/22/2009 12:43:37] Received Event - Queue:[1] Msg:[1].
[01/22/2009 12:43:37] Detected LED Devices: 101000000000000000000000
[01/22/2009 12:43:37] MaLa UI LED profile:
[01/22/2009 12:43:37] Device 1; PBA:49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 12:43:37] Device 3; PBA:0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 12:43:37] Game Start Key: 49
[01/22/2009 12:43:37] LEDBlinky.mplugin> Sending event message [EMULATOR_SELECTED C:\Documents and Settings\vw\Desktop\mame32\MameUI32\MameUI32.exe~M.A.M.E.].
[01/22/2009 12:43:38] Received Event - Queue:[1] Msg:[7~C:\Documents and Settings\vw\Desktop\mame32\MameUI32\MameUI32.exe~M.A.M.E.].
[01/22/2009 12:43:38] LEDBlinky.mplugin> Sending event message [list_SELECTED].
[01/22/2009 12:43:38] Received Event - Queue:[2] Msg:[8].
[01/22/2009 12:43:38] Emulator: [MameUI32] M.A.M.E.
[01/22/2009 12:43:38] 4 games loaded from Controls_override.ini
[01/22/2009 12:43:38] Controls.dat INI file Version=0.111.5, Time=2008-06-20 18:27:09, Generated by=SirPoonga
[01/22/2009 12:43:38] 1065 games loaded from controls.ini
[01/22/2009 12:43:38] MAME.xml v0.129 (JAN 4 2009)
[01/22/2009 12:43:40] 2917 games loaded from Mame.xml
[01/22/2009 12:43:40] 3501 clones loaded from Mame.xml
[01/22/2009 12:43:40] 1389 games loaded from Colors.ini
[01/22/2009 12:43:40] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2~2P sim~].
[01/22/2009 12:43:40] Received Event - Queue:[1] Msg:[9~SF2~2P sim~].
[01/22/2009 13:12:06] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SFEXP~2P sim~].
[01/22/2009 13:12:06] Received Event - Queue:[1] Msg:[9~SFEXP~2P sim~].
[01/22/2009 13:12:06] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SFEX2P~2P sim~].
[01/22/2009 13:12:06] Received Event - Queue:[1] Msg:[9~SFEX2P~2P sim~].
[01/22/2009 13:12:06] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SFEX2~2P sim~].
[01/22/2009 13:12:06] Received Event - Queue:[1] Msg:[9~SFEX2~2P sim~].
[01/22/2009 13:12:07] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SFEX2P~2P sim~].
[01/22/2009 13:12:07] Received Event - Queue:[1] Msg:[9~SFEX2P~2P sim~].
[01/22/2009 13:12:07] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SFEXP~2P sim~].
[01/22/2009 13:12:07] Received Event - Queue:[1] Msg:[9~SFEXP~2P sim~].
[01/22/2009 13:12:08] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2~2P sim~].
[01/22/2009 13:12:08] Received Event - Queue:[1] Msg:[9~SF2~2P sim~].
[01/22/2009 13:12:08] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2CE~2P sim~].
[01/22/2009 13:12:08] Received Event - Queue:[1] Msg:[9~SF2CE~2P sim~].
[01/22/2009 13:12:19] LEDBlinky.mplugin> Sending event message [FE_QUIT].
[01/22/2009 13:12:19] Received Event - Queue:[1] Msg:[2].
[01/22/2009 13:12:25] LEDBlinky.mplugin> LEDBlinky handle indicates that prior instance has terminated.
[01/22/2009 13:12:25] LEDBlinky v3.7.3.0
[01/22/2009 13:12:25] LEDBlinky.mplugin> Sending event message [list_SELECTED].
[01/22/2009 13:12:25] Received Event - Queue:[1] Msg:[8].
[01/22/2009 13:12:25] Event: FEStart
[01/22/2009 13:12:25] Settings.ini ******************** BEGIN
[01/22/2009 13:12:25] [GameOptions]
[01/22/2009 13:12:25] LightGameControls=1
[01/22/2009 13:12:25] GamePauseSpeakControls=0
[01/22/2009 13:12:25] GamePauseLWAFile=
[01/22/2009 13:12:25] UseMameOutputs=0
[01/22/2009 13:12:25] LightPlayerStartCoin=1
[01/22/2009 13:12:25] GameStartLWAFile=
[01/22/2009 13:12:25] GameStartSpeakControls=0
[01/22/2009 13:12:25] GameStartSpeakPrimaryControls=0
[01/22/2009 13:12:25] GameStartSpeakName=0
[01/22/2009 13:12:25] GameStartStrobeName=0
[01/22/2009 13:12:25] GameStartSpeakText=
[01/22/2009 13:12:25] GameStartStrobeText=0
[01/22/2009 13:12:25] AbortSpeechAnyKey=0
[01/22/2009 13:12:25] SpeakControlsPrefix=
[01/22/2009 13:12:25] SpeakPrimaryControlsPrefix=Primary Control
[01/22/2009 13:12:25] [FEOptions]
[01/22/2009 13:12:25] FE=MALA
[01/22/2009 13:12:25] LightFEControls=1
[01/22/2009 13:12:25] DemoGameControls=1
[01/22/2009 13:12:25] DemoScrollDelay=0
[01/22/2009 13:12:25] DemoDuration=5
[01/22/2009 13:12:25] FELWAFile=
[01/22/2009 13:12:25] FEScreenSaverLWAFile=
[01/22/2009 13:12:25] FEScreenSaverRandomText=0
[01/22/2009 13:12:25] FEScreenSaverRandomTextDelay=60
[01/22/2009 13:12:25] FEScreenSaverRandomTextBerzerkMode=0
[01/22/2009 13:12:25] FEStartLWAFile=
[01/22/2009 13:12:25] FEStartSpeakText=
[01/22/2009 13:12:25] FEStartStrobeText=0
[01/22/2009 13:12:25] FEQuitLWAFile=
[01/22/2009 13:12:25] FEQuitSpeakText=
[01/22/2009 13:12:25] FEQuitStrobeText=0
[01/22/2009 13:12:25] FESpeakControlsKey=0
[01/22/2009 13:12:25] FESettingsFile=
[01/22/2009 13:12:25] [MAMEConfig]
[01/22/2009 13:12:25] Colors_ini=C:\Documents and Settings\vw\Desktop\mala\plugins\ledblinky\Colors.ini
[01/22/2009 13:12:25] Mame_cfg_folder=C:\Documents and Settings\vw\Desktop\mame32\MameUI32\cfg
[01/22/2009 13:12:25] MameControllerFile=
[01/22/2009 13:12:25] UseMameDefaultForOtherEmulators=1
[01/22/2009 13:12:25] MameOutputBufferSize=
[01/22/2009 13:12:25] MameControlsFile=
[01/22/2009 13:12:25] MameXmlFile=
[01/22/2009 13:12:25] UseMameToTriggerGameStart=0
[01/22/2009 13:12:25] [RandomText]
[01/22/2009 13:12:25] Text0=Get The Intruder
[01/22/2009 13:12:25] Text1=Intruder Alert!
[01/22/2009 13:12:25] Text2=I detect coin in pocket.
[01/22/2009 13:12:25] [Speech]
[01/22/2009 13:12:25] SpeechRate=0
[01/22/2009 13:12:25] SpeechVolume=100
[01/22/2009 13:12:25] Voice=Microsoft Sam
[01/22/2009 13:12:25] [CabAttract]
[01/22/2009 13:12:25] CabAttractMode_FE=0
[01/22/2009 13:12:25] CabAttractMode_ScreenSaver=0
[01/22/2009 13:12:25] CabAttractMode_GamePlay=0
[01/22/2009 13:12:25] CabAttractModeLWAFile=dissolveinout.lwax
[01/22/2009 13:12:25] CabAttractModeLEDWizDevices=
[01/22/2009 13:12:25] [JDR]
[01/22/2009 13:12:25] UseGPWiz49=0
[01/22/2009 13:12:25] UseUltraStik=1
[01/22/2009 13:12:25] UltraStikRestrictorPlate=0
[01/22/2009 13:12:25] [OtherSettings]
[01/22/2009 13:12:25] MaxPlayers=2
[01/22/2009 13:12:25] CocktailMode=0
[01/22/2009 13:12:25] RandomAniExcludeSelected=0
[01/22/2009 13:12:25] GameStartDelayTimeout=20
[01/22/2009 13:12:25] LogFile=Debug.log
[01/22/2009 13:12:25] Verbose=1
[01/22/2009 13:12:25] DisplayErrorsOnQuit=0
[01/22/2009 13:12:25] DeviceListOverride=
[01/22/2009 13:12:25] NoLEDs=0
[01/22/2009 13:12:25] Settings.ini ******************** END
[01/22/2009 13:12:25] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2CE~2P sim~].
[01/22/2009 13:12:25] Detected LED Devices: 101000000000000000000000
[01/22/2009 13:12:25] DevicePort-Input.ini ******************** BEGIN
[01/22/2009 13:12:25] [LEDWiz-Device1]
[01/22/2009 13:12:25] Port01=P1B1,R,JOYCODE_1_BUTTON1
[01/22/2009 13:12:25] Port02=P1B1,G,JOYCODE_1_BUTTON1
[01/22/2009 13:12:25] Port03=P1B1,B,JOYCODE_1_BUTTON1
[01/22/2009 13:12:25] Port04=P1B2,R,JOYCODE_1_BUTTON2
[01/22/2009 13:12:25] Port05=P1B2,G,JOYCODE_1_BUTTON2
[01/22/2009 13:12:25] Port06=P1B2,B,JOYCODE_1_BUTTON2
[01/22/2009 13:12:25] Port07=P1B3,R,JOYCODE_1_BUTTON3
[01/22/2009 13:12:25] Port08=P1B3,G,JOYCODE_1_BUTTON3
[01/22/2009 13:12:25] Port09=P1B3,B,JOYCODE_1_BUTTON3
[01/22/2009 13:12:25] Port10=P1B4,R,JOYCODE_1_BUTTON4
[01/22/2009 13:12:25] Port11=P1B4,G,JOYCODE_1_BUTTON4
[01/22/2009 13:12:25] Port12=P1B4,B,JOYCODE_1_BUTTON4
[01/22/2009 13:12:25] Port13=P1B5,R,JOYCODE_1_BUTTON5
[01/22/2009 13:12:25] Port14=P1B5,G,JOYCODE_1_BUTTON5
[01/22/2009 13:12:25] Port15=P1B5,B,JOYCODE_1_BUTTON5
[01/22/2009 13:12:25] Port17=P1B6,R,JOYCODE_1_BUTTON6
[01/22/2009 13:12:25] Port18=P1B6,G,JOYCODE_1_BUTTON6
[01/22/2009 13:12:25] Port19=P1B6,B,JOYCODE_1_BUTTON6
[01/22/2009 13:12:25] Port20=P1B7,R,JOYCODE_1_BUTTON7
[01/22/2009 13:12:25] Port21=P1B7,G,JOYCODE_1_BUTTON7
[01/22/2009 13:12:25] Port22=P1B7,B,JOYCODE_1_BUTTON7
[01/22/2009 13:12:25] Port23=P1START,R,JOYCODE_1_START
[01/22/2009 13:12:25] Port24=P1START,G,JOYCODE_1_START
[01/22/2009 13:12:25] Port25=P1START,B,JOYCODE_1_START
[01/22/2009 13:12:25] Port26=JOY1,R,MOUSECODE_1_BUTTON1
[01/22/2009 13:12:25] Port27=JOY1,G,MOUSECODE_1_BUTTON1
[01/22/2009 13:12:25] Port28=JOY1,B,MOUSECODE_1_BUTTON1
[01/22/2009 13:12:25] Port29=JOY2,R,MOUSECODE_1_BUTTON2
[01/22/2009 13:12:25] Port30=JOY2,G,MOUSECODE_1_BUTTON2
[01/22/2009 13:12:25] Port31=JOY2,B,MOUSECODE_1_BUTTON2
[01/22/2009 13:12:25] [LEDWiz-Device2]
[01/22/2009 13:12:25] [LEDWiz-Device3]
[01/22/2009 13:12:25] Port01=P2B1,B,JOYCODE_2_BUTTON1
[01/22/2009 13:12:25] Port02=P2B1,G,JOYCODE_2_BUTTON1
[01/22/2009 13:12:25] Port03=P2B1,R,JOYCODE_2_BUTTON1
[01/22/2009 13:12:25] Port04=P2B2,B,JOYCODE_2_BUTTON2
[01/22/2009 13:12:25] Port05=P2B2,G,JOYCODE_2_BUTTON2
[01/22/2009 13:12:25] Port06=P2B2,R,JOYCODE_2_BUTTON2
[01/22/2009 13:12:25] Port07=P2B3,B,JOYCODE_2_BUTTON3
[01/22/2009 13:12:25] Port08=P2B3,G,JOYCODE_2_BUTTON3
[01/22/2009 13:12:25] Port09=P2B3,R,JOYCODE_2_BUTTON3
[01/22/2009 13:12:25] Port10=P2B4,B,JOYCODE_2_BUTTON4
[01/22/2009 13:12:25] Port11=P2B4,G,JOYCODE_2_BUTTON4
[01/22/2009 13:12:25] Port12=P3B4,R,JOYCODE_2_BUTTON4
[01/22/2009 13:12:25] Port13=P2B5,B,JOYCODE_2_BUTTON5
[01/22/2009 13:12:25] Port14=P2B5,G,JOYCODE_2_BUTTON5
[01/22/2009 13:12:25] Port15=P2B5,R,JOYCODE_2_BUTTON5
[01/22/2009 13:12:25] Port17=P3B6,B,JOYCODE_2_BUTTON6
[01/22/2009 13:12:25] Port18=P2B6,G,JOYCODE_2_BUTTON6
[01/22/2009 13:12:25] Port19=P2B6,R,JOYCODE_2_BUTTON6
[01/22/2009 13:12:25] Port20=P2B7,B,JOYCODE_2_BUTTON7
[01/22/2009 13:12:25] Port21=P2B7,G,JOYCODE_2_BUTTON7
[01/22/2009 13:12:25] Port22=P2B7,R,JOYCODE_2_BUTTON7
[01/22/2009 13:12:25] Port23=P2START,B,JOYCODE_2_START
[01/22/2009 13:12:25] Port24=P2START,G,JOYCODE_2_START
[01/22/2009 13:12:25] Port25=P2START,R,JOYCODE_2_START
[01/22/2009 13:12:25] Port26=MOUSE,B,TRACKBALL
[01/22/2009 13:12:25] Port27=MOUSE,G,TRACKBALL
[01/22/2009 13:12:25] Port28=MOUSE,R,TRACKBALL
[01/22/2009 13:12:25] [LEDWiz-Device4]
[01/22/2009 13:12:25] [LEDWiz-Device5]
[01/22/2009 13:12:25] [LEDWiz-Device6]
[01/22/2009 13:12:25] [LEDWiz-Device7]
[01/22/2009 13:12:25] [LEDWiz-Device8]
[01/22/2009 13:12:25] [LEDWiz-Device9]
[01/22/2009 13:12:25] [LEDWiz-Device10]
[01/22/2009 13:12:25] [LEDWiz-Device11]
[01/22/2009 13:12:25] [LEDWiz-Device12]
[01/22/2009 13:12:25] [LEDWiz-Device13]
[01/22/2009 13:12:25] [LEDWiz-Device14]
[01/22/2009 13:12:25] [LEDWiz-Device15]
[01/22/2009 13:12:25] [LEDWiz-Device16]
[01/22/2009 13:12:25] [PACDrive-Device1]
[01/22/2009 13:12:25] [PACDrive-Device2]
[01/22/2009 13:12:25] [PACDrive-Device3]
[01/22/2009 13:12:25] [PACDrive-Device4]
[01/22/2009 13:12:25] [PACDrive-Device5]
[01/22/2009 13:12:25] [PACDrive-Device6]
[01/22/2009 13:12:25] [PACDrive-Device7]
[01/22/2009 13:12:25] [PACDrive-Device8]
[01/22/2009 13:12:25] DevicePort-Input.ini ******************** END
[01/22/2009 13:12:25] Undefined Control-Color mapping file [C:\Documents and Settings\vw\Desktop\mala\plugins\LEDBlinky\Control-Color_MaLa.ini]. Using Default Values.
[01/22/2009 13:12:25] MaLa UI LED profile:
[01/22/2009 13:12:25] Device 1; PBA:49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:25] Device 3; PBA:0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:25] Game Start Key: 49
[01/22/2009 13:12:25] UltraStik U360(s) detected: 2
[01/22/2009 13:12:25] Set UltraStik JDR Mode [4-Way] for the FE.
[01/22/2009 13:12:25] Device 1; SBA:7,0,0,0,2
[01/22/2009 13:12:25] Device 3; SBA:0,0,0,0,2
[01/22/2009 13:12:25] FEStart Event Completed.
[01/22/2009 13:12:25] Event: FEEmulatorSelected [MAME] []
[01/22/2009 13:12:25] Emulator: [MAME]
[01/22/2009 13:12:25] Undefined Control-Color mapping file [C:\Documents and Settings\vw\Desktop\mala\plugins\LEDBlinky\Control-Color_mame.ini]. Using Default Values.
[01/22/2009 13:12:26] 4 games loaded from Controls_override.ini
[01/22/2009 13:12:26] Controls.dat INI file Version=0.111.5, Time=2008-06-20 18:27:09, Generated by=SirPoonga
[01/22/2009 13:12:26] Duplicate Rom in Controls file(s): [ASTEROID]. This may be expected.
[01/22/2009 13:12:26] Duplicate Rom in Controls file(s): [QBERT]. This may be expected.
[01/22/2009 13:12:26] Duplicate Rom in Controls file(s): [QBERTQUB]. This may be expected.
[01/22/2009 13:12:26] 1065 games loaded from controls.ini
[01/22/2009 13:12:26] MAME.xml v0.129 (JAN 4 2009)
[01/22/2009 13:12:28] 2917 games loaded from Mame.xml
[01/22/2009 13:12:28] 3501 clones loaded from Mame.xml
[01/22/2009 13:12:28] 1389 games loaded from Colors.ini
[01/22/2009 13:12:28] FEEmulaterSelected Event Completed.
[01/22/2009 13:12:28] Event: FEListSelected
[01/22/2009 13:12:28] Received Event - Queue:[1] Msg:[9~SF2CE~2P sim~].
[01/22/2009 13:12:28] Event: FEGameSelected [SF2CE] [2P sim] []
[01/22/2009 13:12:28] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2~2P sim~].
[01/22/2009 13:12:28] Received Event - Queue:[1] Msg:[9~SF2~2P sim~].
[01/22/2009 13:12:28] Event: FEGameSelected [SF2] [2P sim] []
[01/22/2009 13:12:28] Control List for SF2: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_BUTTON6|P1_JOYSTICK_UP|P1_JOYSTICK_DOWN|P1_JOYSTICK_LEFT|P1_JOYSTICK_RIGHT|START1|COIN1|P2_BUTTON1|P2_BUTTON2|P2_BUTTON3|P2_BUTTON4|P2_BUTTON5|P2_BUTTON6|P2_JOYSTICK_UP|P2_JOYSTICK_DOWN|P2_JOYSTICK_LEFT|P2_JOYSTICK_RIGHT|START2|COIN2|CONTROL_JOY8WAY
[01/22/2009 13:12:28] Device 1; PBA:49,0,0,0,0,49,49,49,49,49,0,0,0,0,49,0,49,49,49,0,0,0,0,0,0,49,0,0,49,49,49,0
[01/22/2009 13:12:28] Device 1; SBA:225,67,7,114,2
[01/22/2009 13:12:28] Device 3; PBA:0,0,49,49,0,0,49,49,49,0,0,49,49,0,0,0,49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:28] Device 3; SBA:204,25,7,0,2
[01/22/2009 13:12:28] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SFEXP~2P sim~].
[01/22/2009 13:12:28] Received Event - Queue:[1] Msg:[9~SFEXP~2P sim~].
[01/22/2009 13:12:28] Event: FEGameSelected [SFEXP] [2P sim] []
[01/22/2009 13:12:28] Control List for SFEXP: P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_BUTTON6|START1|COIN1|P2_BUTTON1|P2_BUTTON2|P2_BUTTON3|P2_BUTTON4|P2_BUTTON5|P2_BUTTON6|START2|COIN2|P1_JOYSTICK_LEFT|P1_JOYSTICK_RIGHT|P1_JOYSTICK_UP|P1_JOYSTICK_DOWN|P2_JOYSTICK_LEFT|P2_JOYSTICK_RIGHT|P2_JOYSTICK_UP|P2_JOYSTICK_DOWN||CONTROL_JOY8WAY
[01/22/2009 13:12:28] Device 1; PBA:0,0,49,49,49,0,49,0,0,0,0,49,49,49,0,0,49,0,0,0,0,0,0,0,0,0,0,49,49,0,0,0
[01/22/2009 13:12:28] Device 1; SBA:92,56,1,24,2
[01/22/2009 13:12:28] Device 3; PBA:49,0,0,0,49,49,0,0,49,49,0,0,0,49,49,0,0,0,49,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:28] Device 3; SBA:49,99,4,0,2
[01/22/2009 13:12:29] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2~2P sim~].
[01/22/2009 13:12:29] Received Event - Queue:[1] Msg:[9~SF2~2P sim~].
[01/22/2009 13:12:29] Event: FEGameSelected [SF2] [2P sim] []
[01/22/2009 13:12:29] Control List for SF2: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_BUTTON6|P1_JOYSTICK_UP|P1_JOYSTICK_DOWN|P1_JOYSTICK_LEFT|P1_JOYSTICK_RIGHT|START1|COIN1|P2_BUTTON1|P2_BUTTON2|P2_BUTTON3|P2_BUTTON4|P2_BUTTON5|P2_BUTTON6|P2_JOYSTICK_UP|P2_JOYSTICK_DOWN|P2_JOYSTICK_LEFT|P2_JOYSTICK_RIGHT|START2|COIN2|CONTROL_JOY8WAY
[01/22/2009 13:12:29] Device 1; PBA:49,0,0,0,0,49,49,49,49,49,0,0,0,0,49,0,49,49,49,0,0,0,0,0,0,49,0,0,49,49,49,0
[01/22/2009 13:12:29] Device 1; SBA:225,67,7,114,2
[01/22/2009 13:12:29] Device 3; PBA:0,0,49,49,0,0,49,49,49,0,0,49,49,0,0,0,49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:29] Device 3; SBA:204,25,7,0,2
[01/22/2009 13:12:29] LEDBlinky.mplugin> Sending event message [GAME_SELECTED SF2CE~2P sim~].
[01/22/2009 13:12:29] Received Event - Queue:[1] Msg:[9~SF2CE~2P sim~].
[01/22/2009 13:12:29] Event: FEGameSelected [SF2CE] [2P sim] []
[01/22/2009 13:12:29] Control List for SF2CE: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_BUTTON6|P1_JOYSTICK_UP|P1_JOYSTICK_DOWN|P1_JOYSTICK_LEFT|P1_JOYSTICK_RIGHT|START1|COIN1|P2_BUTTON1|P2_BUTTON2|P2_BUTTON3|P2_BUTTON4|P2_BUTTON5|P2_BUTTON6|P2_JOYSTICK_UP|P2_JOYSTICK_DOWN|P2_JOYSTICK_LEFT|P2_JOYSTICK_RIGHT|START2|COIN2|CONTROL_JOY8WAY
[01/22/2009 13:12:29] Device 1; PBA:49,0,0,49,49,49,0,0,49,49,0,0,49,49,49,0,0,0,49,0,0,0,0,0,0,49,0,0,0,0,49,0
[01/22/2009 13:12:29] Device 1; SBA:57,115,4,66,2
[01/22/2009 13:12:29] Device 3; PBA:0,0,49,49,49,49,49,0,0,0,0,49,49,49,49,0,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:29] Device 3; SBA:124,120,1,0,2
[01/22/2009 13:12:30] LEDBlinky.mplugin> Sending event message [GAME_START].
[01/22/2009 13:12:30] Received Event - Queue:[1] Msg:[3].
[01/22/2009 13:12:30] Event: FEGameStart
[01/22/2009 13:12:30] Control List for SF2CE: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_BUTTON6|P1_JOYSTICK_UP|P1_JOYSTICK_DOWN|P1_JOYSTICK_LEFT|P1_JOYSTICK_RIGHT|START1|COIN1|P2_BUTTON1|P2_BUTTON2|P2_BUTTON3|P2_BUTTON4|P2_BUTTON5|P2_BUTTON6|P2_JOYSTICK_UP|P2_JOYSTICK_DOWN|P2_JOYSTICK_LEFT|P2_JOYSTICK_RIGHT|START2|COIN2|CONTROL_JOY8WAY
[01/22/2009 13:12:30] P1_BUTTON1 (Control-Input_mame.ini): |KEYCODE_LCONTROL|JOYCODE_1_BUTTON1|MOUSECODE_1_BUTTON1
[01/22/2009 13:12:30] P1_BUTTON2 (Control-Input_mame.ini): |KEYCODE_LALT|JOYCODE_1_BUTTON2|MOUSECODE_1_BUTTON3
[01/22/2009 13:12:30] P1_BUTTON3 (Control-Input_mame.ini): |KEYCODE_SPACE|JOYCODE_1_BUTTON3|MOUSECODE_1_BUTTON2
[01/22/2009 13:12:30] P1_BUTTON4 (Control-Input_mame.ini): |KEYCODE_LSHIFT|JOYCODE_1_BUTTON4
[01/22/2009 13:12:30] P1_BUTTON5 (Control-Input_mame.ini): |KEYCODE_Z|JOYCODE_1_BUTTON5
[01/22/2009 13:12:30] P1_BUTTON6 (Control-Input_mame.ini): |KEYCODE_X|JOYCODE_1_BUTTON6
[01/22/2009 13:12:30] P1_JOYSTICK_UP (Control-Input_mame.ini): |KEYCODE_UP|JOYCODE_1_UP
[01/22/2009 13:12:30] P1_JOYSTICK_DOWN (Control-Input_mame.ini): |KEYCODE_DOWN|JOYCODE_1_DOWN
[01/22/2009 13:12:30] P1_JOYSTICK_LEFT (Control-Input_mame.ini): |KEYCODE_LEFT|JOYCODE_1_LEFT
[01/22/2009 13:12:30] P1_JOYSTICK_RIGHT (Control-Input_mame.ini): |KEYCODE_RIGHT|JOYCODE_1_RIGHT
[01/22/2009 13:12:30] START1 (Default.cfg): |JOYCODE_1_BUTTON8
[01/22/2009 13:12:30] COIN1 (Default.cfg): |KEYCODE_1
[01/22/2009 13:12:30] P2_BUTTON1 (Default.cfg): |JOYCODE_2_BUTTON1
[01/22/2009 13:12:30] P2_BUTTON2 (Default.cfg): |JOYCODE_2_BUTTON2
[01/22/2009 13:12:30] P2_BUTTON3 (Default.cfg): |JOYCODE_2_BUTTON3
[01/22/2009 13:12:30] P2_BUTTON4 (Default.cfg): |JOYCODE_2_BUTTON4
[01/22/2009 13:12:30] P2_BUTTON5 (Control-Input_mame.ini): |JOYCODE_2_BUTTON5
[01/22/2009 13:12:30] P2_BUTTON6 (Control-Input_mame.ini): |JOYCODE_2_BUTTON6
[01/22/2009 13:12:30] P2_JOYSTICK_UP (Control-Input_mame.ini): |KEYCODE_R|JOYCODE_2_UP
[01/22/2009 13:12:30] P2_JOYSTICK_DOWN (Control-Input_mame.ini): |KEYCODE_F|JOYCODE_2_DOWN
[01/22/2009 13:12:30] P2_JOYSTICK_LEFT (Control-Input_mame.ini): |KEYCODE_D|JOYCODE_2_LEFT
[01/22/2009 13:12:30] P2_JOYSTICK_RIGHT (Control-Input_mame.ini): |KEYCODE_G|JOYCODE_2_RIGHT
[01/22/2009 13:12:30] START2 (Default.cfg): |JOYCODE_2_BUTTON8
[01/22/2009 13:12:30] COIN2 (Default.cfg): |KEYCODE_2
[01/22/2009 13:12:30] CONTROL_JOY8WAY (Control-Input_mame.ini): JOY8WAY
[01/22/2009 13:12:30] Device 1; PBA:49,0,0,49,49,49,0,0,49,49,0,0,49,49,49,0,0,0,49,0,0,0,0,0,0,49,0,0,0,0,49,0
[01/22/2009 13:12:30] Device 1; SBA:57,115,4,66,2
[01/22/2009 13:12:30] Device 3; PBA:0,0,49,49,49,49,49,0,0,0,0,49,49,49,49,0,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:12:30] Device 3; SBA:124,120,1,0,2
[01/22/2009 13:12:30] Set UltraStik JDR Mode [8-Way] for SF2CE
[01/22/2009 13:12:33] LEDBlinky.mplugin> LEDBlinky.exe has completed processing GameStart event.
[01/22/2009 13:13:26] LEDBlinky.mplugin> Sending event message [GAME_QUIT].
[01/22/2009 13:13:26] Received Event - Queue:[1] Msg:[4].
[01/22/2009 13:13:26] Event: FEGameQuit
[01/22/2009 13:13:26] Device 1; PBA:49,49,49,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:13:26] Device 1; SBA:7,0,0,0,2
[01/22/2009 13:13:26] Device 3; PBA:0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[01/22/2009 13:13:26] Device 3; SBA:0,0,0,0,2
[01/22/2009 13:13:26] Set UltraStik JDR Mode [4-Way] for the FE.
[01/22/2009 13:13:29] LEDBlinky.mplugin> Sending event message [FE_QUIT].
[01/22/2009 13:13:29] Received Event - Queue:[1] Msg:[2].
[01/22/2009 13:13:29] Event: FEQuit
arzoo
    • LEDBlinky
Ok, if I understand correctly, this is how your panel is wired:
P1B1 --> Joystick 1 Button 1
P2B1 --> Joystick 2 Button 1
A1 --> Mouse Button 1
A2 --> Mouse Button 2
And you're seeing all four of these buttons light up even though you only want P1 and P2 to light up - correct?
Here's the problem - By default, mame uses the following input codes for P1B1, P1B2, and P1B3:
P1_BUTTON1: KEYCODE_LCONTROL, JOYCODE_1_BUTTON1, MOUSECODE_1_BUTTON1
P1_BUTTON2: KEYCODE_LALT, JOYCODE_1_BUTTON2, MOUSECODE_1_BUTTON3
P1_BUTTON3: KEYCODE_SPACE, JOYCODE_1_BUTTON3, MOUSECODE_1_BUTTON2
So on your cp, P1B1 and MouseB1 do the same thing (same for P1B3 and MouseB2) - correct? I guess I really need to know how you have your buttons wired.
Arcade Addiction
ivwshane
I multiple issues but the first one is that P1 start doesn't light up, instead mouse1 lights up (and the same goes for player 2, mouse2 lights but not P2 start).
The second issue is that colors.ini lights do not correspond to my button layout. For example, on sf2 the buttons that light up are 1-4,5,6 but because of my layout I need buttons 2-4, 5,6,7 to light up.
arzoo
    • LEDBlinky
To light up P1 and P2 start, check the "Light Player Start and Coin Buttons" option on the Game Options tab. The mouse buttons will continue to light up until you deassign them from P1B1 and P1B3 in mame.
I'm wondering if you have LEDBlinky pointing to the correct mame cfg folder? Is MaLa running mame from this folder:
If not, that would explain why the buttons are not lighting correctly.
Arcade Addiction
ivwshane
I have the "Light player start and coin buttons" selected but they still don't come on. (I removed the mouse buttons from p1 start and p2 start and they no longer light up, which is good).
Mala does run mame from: C:\Documents and Settings\vw\Desktop\mame32\MameUI32
Ledblinky's config folder is here: C:\Documents and Settings\vw\Desktop\mame32\MameUI32\cfg
Ledblinky also gets the colors.ini file from here: C:\Documents and Settings\vw\Desktop\mala\plugins\ledblinky\Colors.ini
Also in mala I specified the controller.ini file as being here:C:\Documents and Settings\vw\Desktop\mame32\MameUI32
I didn't specify the controller file in ledblinky.
Do I have my input map setup correctly?
arzoo
    • LEDBlinky
Sorry, somehow I missed a few lines in the log - I do see that you have the player start and coin option enabled. Looks like you're using JOYCODE_1_BUTTON8 and JOYCODE_2_BUTTON8 for the start buttons. So you need to change your input map (which is currently using JOYCODE_1_START and JOYCODE_2_START). That should fix the player start buttons.
I'm not sure what else is not working? Are the buttons lighting correctly, but just with the wrong colors? Can you post the controller.ini file here, thanks.
Arcade Addiction
ivwshane
Re: how do I get ledblinky (color.ini) to match the buttons I have configured?
« Reply #10 on: January 23, 2009, 12:19:54 am »
Ok so the p1 and p2 start buttons are working:D
However they don't seem to be lighting up any other color other than white.
And the last issue is that the "remapped" buttons don't match the lighted buttons (as illustrated in the attached pic running sfII).
arzoo
    • LEDBlinky
« Reply #11 on: January 23, 2009, 09:08:44 am »
Ok so the p1 and p2 start buttons are working :D
I'll look into the color problem later today.
I just realized that you're using a new mame .129. LEDBlinky has a bug with newer versions of mame which prevents it from picking up the remapped buttons. This has been fixed in the latest release currently in beta test. You can wait for the official release or I can send you the beta if you wish to try it out.
Arcade Addiction
ivwshane
« Reply #12 on: January 23, 2009, 01:10:29 pm »
Thanks for all of your help, I really appreciate it!
I'd love to try the beta. At least now I know I'm not crazy! I figured it had to be something I was doing wrong.
arzoo
    • LEDBlinky
« Reply #13 on: January 23, 2009, 06:01:00 pm »
I found a bug with the start and coin button colors - you must be the first LEDBlinky user with a cp that has RGB start and coin buttons!
Anyway, I fixed the bug for the next release.
Arcade Addiction
ivwshane
« Reply #14 on: January 24, 2009, 01:08:22 am »
Yeah!!
PM sent.
