Author Topic: ACT Gun Help  (Read 1526 times)
FrizzleFried
    • Idaho Garagecade
ACT Gun Help
« on: January 21, 2009, 07:26:08 pm »
I found someone selling an ACT PC light gun for cheap...this is how he describes it:
PC & TV USB light gun. It needs to connect to your VGA port via the VGA Box. I have the PC USB version.
Can anyone tell me if this gun will work with a JPAC/SOFT15KHZ combo  running an arcade monitor?
BobA
  • What Me Worry?
Re: ACT Gun Help
« Reply #1 on: January 22, 2009, 10:30:23 am »
The USB PC version means it is meant to run on a PC monitor.   Will not work on an arcade monitor.
My Bad apparently this is the unit that works with arcade monitors.
 :cry: :cry:
« Last Edit: January 23, 2009, 12:18:00 am by BobA »
bboysnj
  • Last login:November 05, 2021, 01:57:25 pm
Re: ACT Gun Help
« Reply #2 on: January 22, 2009, 05:13:36 pm »
It was my understanding the TV version doesn't work with arcade montiors -- you want the USB/VGA version, which is the PC version, for your arcade machine.
At least, that's the one I have, and it works like a charm with my ArcadeVGA card on a real arcade monitor.
Great question Fred; I was actually looking to upgrade to a PC with more OOmph -- but that would involve a motherboard without AGP slots -- I want to accomodate a dual or quad core processor - so it would mean bye-bye to my ArcadeVga card (v1).  If we confirm the guns work with Softkhz, then I'm all in too!  Anyone out there use this combo?  Thanks!
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
Re: ACT Gun Help
« Reply #3 on: January 22, 2009, 06:18:13 pm »
I've a dual core cpu with a agp slot on the motherboard
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
FrizzleFried
    • Idaho Garagecade
Re: ACT Gun Help
« Reply #4 on: January 22, 2009, 06:39:51 pm »
So you're saying you DID get it running with an AVGA/JPAC combo?  If so,  that's at least a good forward step.  Somewhere I read someone had issues getting them to work with SOFT15KHZ but for the life of me I can't find that post.
Has ANYONE gotten these to work with soft15khz running?
I guess that's the question now.
bboysnj
Re: ACT Gun Help
« Reply #5 on: January 23, 2009, 01:03:17 am »
Affirmative on ActLabs w/Avga and Jpac!
Cynos -- what's the build of your mb?  Help a brother out!
CathalDublin
Re: ACT Gun Help
« Reply #6 on: January 23, 2009, 02:46:51 pm »
Asrock 4CoreDual-SATA2 R2.0 So775
Max 2gb ram though :(
heard reports on the web of people getting it running 4gb but i had no luck although I havent got the latest bios on it
I believe this has too Asrock P4i65G
« Last Edit: January 23, 2009, 02:50:46 pm by cynos »
bboysnj
Re: ACT Gun Help
« Reply #7 on: January 23, 2009, 08:47:38 pm »
Cynos you rule - thanks!!!
