Author Topic: Samsung SyncMaster 710n "Not Optimal Resolution" error.  (Read 9983 times)
Jarmoz
  • Newbie
  • Last login:January 21, 2009, 12:14:17 pm
« on: January 21, 2009, 12:14:17 pm »
Hy..when i plug in my monitor,it says "not optimum mode, recommended: 1280x1024 60Hz".
i installed drivers and tried to change the resolution.
i searched about it from Google,but no help.
some more info:
http://www.fixya.com/support/t373790-not_optimum_mode
srarcade
  • Last login:June 18, 2018, 03:16:29 pm
Re: Samsung SyncMaster 710n "Not Optimal Resolution" error.
« Reply #1 on: January 21, 2009, 03:23:15 pm »
Did it work beforehand or is this a new monitor for you? It might be your current resolution is too low/high for it to properly display. If you have another display that works you can change your display settings to 1280x1024 60hz on there and save it, then try booting up with this monitor.
EDIT: Sorry missed the part where you said you tried to change the resolution. Have you tried another PC on this same monitor?
« Last Edit: January 21, 2009, 03:27:25 pm by srarcade »
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #2 on: January 24, 2009, 04:21:43 am »
This will also come up if you are giving it 72Hz - so go to the all modes tab and check you are on a 60Hz mode.
