Author Topic: U-Trak Noise  (Read 7778 times)
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
U-Trak Noise
« on: January 21, 2009, 10:28:31 am »
I have a U-Trak installed in my new CP and it can be a little noisy when rolled in one direction, like it needs a little grease or something. =] Any ideas on the proper way to correct this?
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: U-Trak Noise
« Reply #1 on: January 21, 2009, 01:02:46 pm »
Yeah, unscrew the casing and WD40 the barswhere they meet the plastic housing.
severdhed
  • RIP Dinosaur Hippo
Re: U-Trak Noise
« Reply #2 on: January 21, 2009, 01:13:41 pm »
i was always under the impression that wd40 is bad for bearings...
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #3 on: January 21, 2009, 01:21:20 pm »
Anyone else?
scriptfactory
  • Last login:February 18, 2009, 04:31:14 pm
Re: U-Trak Noise
« Reply #4 on: January 21, 2009, 01:45:30 pm »
I know WD-40 is bad for skateboard bearings because it leaves behind this kinda' residue that actually attracts dust and dirt. It really reduces their longevity. I always use a high quality bearing lubricant (like Bones Speed Cream or Tri-Flow.)
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #5 on: January 21, 2009, 02:00:31 pm »
Funny you say that, I just had a flash back.  :)
So should I try a little Tri-Flow?
Is mine the only one of there with a little noise?
Ginsu Victim
  • Comanche, OK -- USA
Re: U-Trak Noise
« Reply #6 on: January 21, 2009, 02:29:18 pm »
My first thought was actually skateboard bearing lube, but thought, "Naaaaaaahhh." :)
scriptfactory
Re: U-Trak Noise
« Reply #7 on: January 21, 2009, 02:47:49 pm »
I'm pretty sure any plastic safe (teflon/silicone) lube/grease would be alright. A little Tri-Flow would probably be excellent but I would like to hear an expert opinion on this.
« Last Edit: January 21, 2009, 02:50:45 pm by scriptfactory »
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #8 on: January 21, 2009, 02:58:51 pm »
Standing by for an expert.  ;)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: U-Trak Noise
« Reply #9 on: January 21, 2009, 04:28:35 pm »
WD40 should be fine. Its just a light oil with other stuff added, which evaporates leaving the oil:
http://en.wikipedia.org/wiki/WD-40
But there might be some reason for the noise. One possibility is a small lump of dirt stuck to the roller at the point it contacts the ball.  There is no problem with running smooth emery paper against the roller and spinning it, to eliminate anything stuck. The roller itself is unlikely to be damaged as its hard stainless-steel.
scriptfactory
Re: U-Trak Noise
« Reply #10 on: January 21, 2009, 08:59:33 pm »
Quote from: Wikipedia
    * 50%: Stoddard solvent (i.e., mineral spirits -- primarily hexane, somewhat similar to kerosene)
    * 25%: Liquified petroleum gas (presumably as a propellant; carbon dioxide is now used instead to reduce WD-40's considerable flammability)
    * 15+%: Mineral oil (light lubricating oil)
    * 10-%: Inert ingredients
Caution
    * WD-40 is not contact cleaner. It leaves a sticky residue that can attract dust.
    * WD-40 should never be used in locks for the same reason. Locks should be cleaned with isopropyl alcohol, allowed to dry thoroughly and lubricated with dry graphite powder.
    * A sample of WD-40 that was sprayed onto a piece of steel plate and left outside at -25 for about 20 minutes froze.
This is why you can't use it on skateboard bearings. The solvent removes the real grease used in the bearings and just leaves the "light lubricating oil" which actually attracts dirt (from what I've heard.)
I've been using triflow. Is that any good?
Tri-flow is an excellent lube and offers great chain protection but it does pick up a little more dust than others... on the other hand the teflon and ptfe additives makes removing that crud much easier as it just can't stick.
I get 3500-4500 km per chain and apply lube very sparingly... I use one drop per link and then I listen to Boheniam Rhapsody while I wipe the excess down with a rag.
WD40 is better than nothing but it isn't a good chain lubricant... if you think this question gets asked here a lot come and work in our shop.
I should actually promote the use of Wd40 as then we'd sell even more new chains...especially in the winter months as it offers virtually no protection when things get ugly.
It seems that people have a lot of differing opinions on the use of WD-40...however bike chains and skateboard bearings are a lot different than a trackball...
« Last Edit: January 21, 2009, 09:03:01 pm by scriptfactory »
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #11 on: January 22, 2009, 07:21:51 am »
How do I access all this to lube it?
AndyWarne
    • Ultimarc
Re: U-Trak Noise
« Reply #12 on: January 22, 2009, 07:23:41 am »
There are 4 screws recessed in to the base. Just remove these and the top lifts off, and then the ball can be lifted out.
Another thing you can try is swap over the rollers and/or bearings and if one bearing is noisy we can send a replacement.
Andy
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #13 on: January 22, 2009, 08:26:52 am »
From the top you say? Hmmm... Well that could be a problem. I don't think I have access to the top of my CP in that way.
I am not sure how I would be able to get to the top of the U-Trak when it is flush mounted. Guess I really need to take a closer look at it.
Ginsu Victim
Re: U-Trak Noise
« Reply #14 on: January 22, 2009, 09:41:49 am »
remove it from the CP and you can open it
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #15 on: January 22, 2009, 10:10:00 am »
sigh... I did not install it in the CP so I am not 100% sure how to remove it.
Really sucks that I have to do all this work to something I had someone else build for me.  :(
I guess thats the breaks sometime.
I will have to look at the bottom of the CP but with that lip there, I wonder how it is to take it out?
Ginsu Victim
Re: U-Trak Noise
« Reply #16 on: January 22, 2009, 10:20:54 am »
There should be holes on the bottom of the trackball unit. Use a phillips head screwdriver in those holes to remove the screws.
You need to learn what you have in your CP and how to work on it. Someone else built it, but you're responsible for it.
Hoopz
  • Last login:June 13, 2025, 09:18:32 pm
  • Intellivision Rocks!
Re: U-Trak Noise
« Reply #17 on: January 22, 2009, 10:25:07 am »
QFT
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #18 on: January 22, 2009, 10:35:24 am »
Trust me I am not stranger to the inside of it, I don't even bother screwing the bottom on anymore at this point and time.
Since I've had it I have or have been dealing with the following.
Loose Connections
Possible Bad RGB Board Problem
U360 Issues
...and now this U-Trak issue.
I am not pointing the figure and I am surely not saying no one is not helping me take care of these issues because so far everyone involved has been great but...
Look... I am not trying to be a little ---smurfette--- here or anything but it's a bit much for something that is suppose to be 100% brand new. Yeah I know, ---steaming pile of meadow muffin--- happens...
Anyway… So I can unscrew this from the bottom to remove it from the control panel or to get to the parts I need to lubricate? You’ll have to excuses me as I am at work right now and this is not so clear because I don’t have it in front of me. Figured I would gather all the info. I need now and then deal with it when I get home tonight. So… The more I know going into it the better.
Ginsu Victim
Re: U-Trak Noise
« Reply #19 on: January 22, 2009, 10:40:19 am »
What I said wasn't an attack or anything. It was just a response to:
I understand your frustration. You spent money on what you hoped to be a perfect setup, and now all these problems are popping up. Good thing you bought yours with products from a reputable vendor like Ultimarc. Andy takes great care of his customer base.
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #20 on: January 22, 2009, 10:49:17 am »
Yeah... So far Andy and Scott from Mameroom have been great.
So any idea on my question, those screws on the bottom. Are they to remove the U-Trak or to get to where I need to make adjustments? Reading above it seems like Andy said I need to access it from the top to lubricated it.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: U-Trak Noise
« Reply #21 on: January 22, 2009, 10:51:15 am »
There's a mom joke in here somewhere...
-csa
Ginsu Victim
Re: U-Trak Noise
« Reply #22 on: January 22, 2009, 10:52:33 am »
They will unmount the trackball from the panel, allow you to access the top of the unit once it's out.
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #23 on: January 22, 2009, 12:05:09 pm »
I'll have to check it out when I get home, if its too much trouble I will just live with the noise and turn the speakers up.  ;)
Ginsu Victim
Re: U-Trak Noise
« Reply #24 on: January 22, 2009, 12:08:51 pm »
Nah, should be an easy fix.
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #25 on: January 22, 2009, 12:16:19 pm »
The pain in the ass part is removing it to do so but I guess that is all yet to be seen.
Hoopz
Re: U-Trak Noise
« Reply #26 on: January 22, 2009, 12:21:06 pm »
It's four screws.  Its not going to be a pain in the ass to remove four screws.
Ginsu Victim
Re: U-Trak Noise
« Reply #27 on: January 22, 2009, 12:26:56 pm »
Like Hoopz said, it's four screws. It's not rocket science. You'll go to remove it and say, "Oh, I made way too much of this."
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #28 on: January 22, 2009, 12:30:04 pm »
Maybe so but not being a pain in the ass would not being doing it at all.  :P
ashes-uk
  • Last login:January 31, 2009, 01:53:51 pm
Re: U-Trak Noise
« Reply #29 on: January 22, 2009, 12:45:03 pm »
thanks to this thread, just did my u-trak, the rollers were full of gunk and the wd40 sorted straight away.
hardest part is getting the CP off.
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #30 on: January 22, 2009, 02:10:19 pm »
<--- Saving U-Traks One Lub at a Time.  :P
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #31 on: January 25, 2009, 07:17:06 pm »
So yeah, I lubed up the bearings and where the bearings slide on the shaft... It still makes noise when rolling to the right side. I noticed when I had it apart that there was wear on the center of the shafts from where the track ball hits it, all 3 rods. I guess there is really no way to fix this because if I wax the shafts the track ball may slip.
Ideas are welcome.
Ginsu Victim
Re: U-Trak Noise
« Reply #32 on: January 25, 2009, 08:40:12 pm »
If you do decide to "wax the shaft," make sure no one catches you. ;D
Bender
Re: U-Trak Noise
« Reply #33 on: January 26, 2009, 12:02:52 am »
Ideas are welcome.
Wear? on a relatively new trackball in stainless steel?
I doubt it, I think you have some gunk built up there you need to get it off and the Track ball we be like new!
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #34 on: January 26, 2009, 07:20:23 am »
Next time I pull it apart I will snap some pix if it don't wipe off. I mean I can't even see how it could be that dirty so you have a valet point. I'll pull it one more time this week, maybe tonight.
« Last Edit: January 26, 2009, 07:22:49 am by Visitor Q »
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #35 on: January 26, 2009, 07:58:09 am »
Well I couldn't wait so I pulled it here before work, turns out I was right.  :(
I cleaned them off when they where out but the mark remains so ideas are welcome.
Bender
Re: U-Trak Noise
« Reply #36 on: January 26, 2009, 09:17:12 am »
Its hard to tell from the pictures, but it looks like your right, those are divots and not dirt, you should send them back to Andy
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #37 on: January 26, 2009, 11:02:59 am »
I am 100% sure it is not dirt, trust me.
Is this a problem? If I get new ones, won't they do the same?
Maybe I need to wait and hear from Andy on this one. All this stuff is suppose to be brand new, I don't think I have played more than two games with that track ball.  :-\
Any idea what may have caused this?
« Last Edit: January 26, 2009, 11:06:30 am by Visitor Q »
Bender
Re: U-Trak Noise
« Reply #38 on: January 26, 2009, 11:14:46 am »
that is very strange
something weird is going on, did you get this from a third party?
I got a u-track a couple of months ago and it works fantastic, I did have to take it apart to get a little dirt off the rollers cause I was test fitting it in the workshop and a lot of crud got in there. I've never seen anything like you have there, Its almost like someone grinded those spots down or ran a trackball made of sandpaper through there
Visitor Q
  • The Saw Is Family
Re: U-Trak Noise
« Reply #39 on: January 26, 2009, 11:24:35 am »
It came from Mameroom, they built the CP.  :dunno
I don't understand why I am having so many problems.  :'(
I mean Andy and Scott from Mameroom have been great so far but I don't understand why I am having so many problems. I've spent more time adjusting, fixing and correcting than playing at this point. I know, welcome to the BYOAC.  :D
« Last Edit: January 26, 2009, 11:45:35 am by Visitor Q »
