Author Topic: 25" arcade monitor  (Read 3129 times)
Shapermc
  • Last login:May 26, 2005, 05:00:12 pm
25" arcade monitor
« on: June 23, 2003, 03:56:00 pm »
I am wanting to purchase one. I need this size. I will not be able to pay untill next month, but am starting to look early. If you have one used in stock let me know.
I am looking for a good deal. Please Email me at mwmson @ hotmail.com (take out the spaces)
SNAAAKE
  • -Banned-
Re:25" arcade monitor
« Reply #1 on: June 23, 2003, 06:56:19 pm »
did you look around?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3229702398&category=13716
This is the cheapest.
new is like $300.
AlanS17
    • AlanS17
« Reply #2 on: June 23, 2003, 10:33:18 pm »
That's the same one I saw. (Isn't this a helpful post?)
Solidus
  • Last login:September 05, 2009, 05:07:09 am
« Reply #3 on: July 09, 2003, 04:24:21 pm »
You cant blame the guy for TRYING to help out...
RandyT
    • GroovyGameGear.com
« Reply #4 on: July 09, 2003, 05:01:07 pm »
I have some super-nice 27's that only need 24.5" width to fit.  You don't even have to take them out of the metal case.
Too big?
RandyT
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #5 on: July 09, 2003, 05:33:45 pm »
how much do you want for one?
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
said7
  • Last login:January 24, 2012, 02:24:47 pm
  • "I smell..... NERDS" - Ogar
    • www.said7.com
« Reply #6 on: July 10, 2003, 10:52:55 am »
Isnt CGA bad?
Check out my site: http://www.said7.com
Arcade site comming soon.
RandyT
« Reply #7 on: July 10, 2003, 12:07:36 pm »
Isnt CGA bad?
I think that guy is mis-using the term CGA a bit.
I don't think the monitor would actually work with a real CGA card without adding some extra components.
Standard arcade monitors are RGB analog (millions of possible colors) at 15.75 khz horizontal scan frequency, which is pretty much the same as a television but sharper and with much better color.
CGA monitors, on the other hand, use a digital color signal.  The RGB lines are either completely on or completely off, which severely limits the number of colors that can be displayed ( I think the pallette was 8 colors, but I forget).
In any case, they are different birds :)
RandyT
said7
    • www.said7.com
« Reply #8 on: July 10, 2003, 02:56:54 pm »
So i reckon that monitor on ebay wouldnt be so good for a mame cabinet.
Better off your with VGA?
BTW RAndy what kinda monitors you got available.
RandyT
« Reply #9 on: July 10, 2003, 03:51:54 pm »
Actually it should be ok, if you have an ArcadeVGA card or want to use the software tweaks to run a 15.75khz monitor.
The one on Ebay appears to be a television that has been retrofitted with a chassis that has RGB analog inputs.  You should contact the seller to be sure.
For ease of interfacing, you can use straight VGA, but you'll sacrifice authenticity and they cost a little more.  You'll need to scale everything and run at higher than native res of the software, which may or may not cause a hit on processor speed.
For authenticity use Standard Res and an ArcadeVGA card or a software hack for displaying to 15.75khz monitors.  You may need to do a little configuring for the best result.
If money is no object, substitute the WG9200? (multi-frequency) in the above and get the best of all worlds.
Mine are industrial grade 27" RGB monitors (15.75khz).  The CRT face is made of tinted glass for contrast enhancement.  They come in a square metal case that is just a hair larger than the face of the CRT (about 24 3/8" wide).  They also have a composite input for a VCR and the like.
The image is very bright and absolutely no burn-in or scratches on the screen.  It is estimated that these units have less than 100 hours on them.  The difference between one of these and an S-Vid TV has to be seen to really be appreciated  :o :).
Price: $235 plus shipping and insurance.  Contact me if you need pictures or more info.
RandyT
said7
    • www.said7.com
« Reply #10 on: July 11, 2003, 08:56:02 am »
Thanks man. Ill keep you in mind when I got my cab complete.
Im thinking about upgrading my 19 in WG9100.
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« Reply #11 on: July 12, 2003, 01:51:15 am »
Check your pm randyt !
IIOIOOIOO
  • Last login:August 04, 2003, 02:18:12 pm
« Reply #12 on: July 12, 2003, 03:55:13 pm »
Also, check out 8lines.com or genao on Ebay for some sweet sweet deals on monitor and chassis. He is magical, and 25" (horizontal, not diag) < $200 is hard to beat. You can read his ebay feedback or google groups some to hear reports on his mad monitoring skills.
meta87
« Reply #13 on: July 12, 2003, 10:20:52 pm »
I think his username is actually, genao.com :)
