Author Topic: Stupid Gateway splash screen  (Read 4706 times)
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« on: January 16, 2009, 05:08:05 pm »
Using the wiki, I disabled all kinds of garbage in Windows XP and have it just about where I want it. However, I still can't get rid of that Gateway splash screen. I've heard you can disable it somewhere in the bios, but I am very unfamiliar with the registry and don't want to go fooling around unless I'm sure I know what I'm doing. Can anyone direct me? Thanks.
swaffar
Re: Stupid Gateway splash screen
« Reply #1 on: January 16, 2009, 05:21:31 pm »
well for starters, you'll need to edit your BIOS not the registry... as soon as your start up i'll have to hit either Esc, F2 or F12 (depends on what BIOS your rig has on it)  but your screen should display a message telling you what to press or hold to enter BIOS settings.
look around in there to enable/disable the splash
My projects:
dkubarek
« Reply #2 on: January 16, 2009, 05:31:31 pm »
BIOS? Registry? See, I told you I don't know what I'm talking about.  ;D Thanks for the help. I'll check it out.
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #3 on: January 17, 2009, 09:40:59 am »
A lot of times, with OEM stuff like that, you won't be able to edit hte splash image in the BIOS.  They LIKE forcing you to see their logo when you load up.  Free advertising  :)
If you can't through the bios settings, find out the exact type of motherboard/bios..  Sometimes, you can get lucky on a  Google search and find a standalone piece of software that can be used to update the splash image..
dkubarek
« Reply #4 on: January 17, 2009, 11:17:14 am »
Yea, I hear that. I "turned it off" and it started by showing system checks for a split second WITH a new, smaller Gateway logo. I plan to keep this arcade in sleep mode, and most of the time the screen beats the monitor to startup, so I'll just live with it for now. Thanks for the help, guys. dk
Encryptor
  • Trade Count: (+34)
« Reply #5 on: January 17, 2009, 10:42:11 pm »
You might also check Gateways website. I have a Compaq in mine and it was the same way with the Compaq flash screen. I was able to get a utility from their website that allowed me to change it to what ever I wanted. It's worth a shot.
Encryptor
dkubarek
« Reply #6 on: January 17, 2009, 11:09:31 pm »
I'll try that. thanks.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #7 on: January 18, 2009, 04:22:48 am »
If all else fails and you really want to keep that computer, you could try the hardware method laid out on that wiki page...
It's not a pretty method and you have to deal with a blank screen during the few second of bios, but it may be a better help to the illusion than a bunch of post data...
From the wiki:
A Hardware Solution For Hiding BIOS & Boot Screens
    This may be set-up dependant thus it may or may not work for your setup. In the first step, a cheap or even free part is recommended. This will make testing this method easier on the wallet.
       1. You must be using an AGP video card in your PC. Add a PCI video card to your system (use the cheapest model you can find - it may not even have to work, so you may be able to find a free card!)
       2. Go into the BIOS setup screen of your PC, and find the "Video Card" setting. Change it to "PCI" instead of AGP.
       3. Reboot your PC
    The BIOS messages and boot screen should now be output only to the PCI card. The monitor, still plugged into the AGP card, should stay blank until Windows starts. If any BIOS changes are needed, you'll have to plug the monitor into the PCI card, so ensure your PC's BIOS settings are configured prior to attempting this step.
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
