Author Topic: Do I varnish over gloss on MDF  (Read 2519 times)
langdoguk
  • Last login:October 30, 2009, 03:45:23 pm
  • hey you Guys !
« on: January 16, 2009, 04:50:28 am »
Hi there,
I have used MDF for my cab which I put 3 coats of primmer on sanding gently between coats now I have put one coat of pink gloss on and I am going to do one more coat.
I have 2 questions maybe you could help me with:
1. Do I sand between coats of gloss ?
2. Do i put a varnish over the gloss and if so is there a certain kind ?
Thanks in advance  :cheers:
« Last Edit: January 16, 2009, 07:14:51 am by langdoguk »
Help I'm useless !!!!
Blanka
Re: Do I varnish over glass on MDF
« Reply #1 on: January 16, 2009, 04:58:32 am »
That's too many layers of primer! Better 1 layer of primer and 3 final ones. Let each layer of gloss paint harden well: 1 week at least (it sucks, I know, but you will be rewarded). Sand between every layer. Don't be a whimp on sanding, but don't remove everything either off course! It is even possible to end the painting with polishing to remove every dust particle.
If you like the gloss, keep it that way. Or are you sure the varnish is specially made for finishing that particular solid-gloss-paint? They really should be compatible.
« Last Edit: January 16, 2009, 05:05:23 am by Blanka »
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
Re: Do I varnish over gloss on MDF
« Reply #2 on: January 16, 2009, 04:39:01 pm »
Skip the varnish and use some spray lacquer instead.
StarControl
  • Last login:April 23, 2011, 12:04:24 pm
« Reply #3 on: January 19, 2009, 04:01:21 pm »
Do you let the gloss paint harden for the full week before sanding?
Chadwick
« Reply #4 on: January 19, 2009, 08:02:49 pm »
Yes.
Sanding between each coat is more about prepping the surface for the next coat than it is about "finishing" the previous coat.
« Last Edit: January 19, 2009, 09:36:02 pm by Chadwick »
