Author Topic: PC Monitor  (Read 1913 times)
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
PC Monitor
« on: January 14, 2009, 10:23:49 am »
I'm planning on using a pc monitor for my next cab.  I want to remove the outer plastic case to save space.  There appears to be a metal cage surrounding the entire monitor.  Is it safe to handle the monitor by this metal case?
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
Ginsu Victim
  • Comanche, OK -- USA
Re: PC Monitor
« Reply #1 on: January 14, 2009, 11:03:36 am »
Use the 9-volt battery test.
Try touching it with your tongue first.
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
Re: PC Monitor
« Reply #2 on: January 14, 2009, 12:18:45 pm »
You can touch it without it shocking you.
Trample the weak, hurdle the dead
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: PC Monitor
« Reply #3 on: January 14, 2009, 12:36:06 pm »
that would be a "Faraday cage".  it is for noise suppression to/from the monitor.
u may be able to use without pending the noise factor..
