Author Topic: Newbie here.  (Read 1534 times)
Matsurigatzu
  • Last login:January 26, 2009, 06:38:03 pm
Newbie here.
« on: January 13, 2009, 06:38:17 pm »
Just seeing if someone could message me on aim and i can ask questions instead of type it all out.
Just got a new Neo Geo MVS 4-25 v.3 cab.
got questions. I appreciate it!
aim= gatzu04
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: Newbie here.
« Reply #1 on: January 13, 2009, 06:48:04 pm »
You must be new to forums as well...
 :laugh2:
DaveMMR
Re: Newbie here.
« Reply #2 on: January 13, 2009, 06:48:31 pm »
You'd still have to type it out on AIM anyway, just in smaller chunks.  Posting it here helps others with similar problems.  ;)
Matsurigatzu
Re: Newbie here.
« Reply #3 on: January 13, 2009, 06:54:32 pm »
yeah,your right.
Just takes longer to get answers on here.
Well im not sure if you want to see a picture of the cab but im guessing you know what it looks like. :-)
First off: Jamma boards. What is all the talk about and would it work into the Neo Geo that i have?
also, one joystick is non responsive and buttons do not work. Is it fairly easy to replace myself? Where can i order some parts that would fit my machine?
p.s. some history here.......I got the neo geo 4 cart system for free from some guy that just bought a laundry place and said he was throwing it away and the screen had no scratches on it and had 4 games on it-Metal Slug 1,King of fighters 97, Art of fighting, and samuari showdown 2. :-)
yeah,i got lucky. I just had to pick it up and haul it away.
DaveMMR
Re: Newbie here.
« Reply #4 on: January 13, 2009, 07:31:56 pm »
yeah,your right.
Let me preface by saying I've no experience with actual arcade cabs.  But for the non responsive joystick and buttons, I'd say just as a basic starting point is to check the wiring and make sure everything is connected properly.  Check the wiki, the links on the side and/or your favorite search engine for a quick primer on hooking things up.  Hint: If you can hook up a stereo you can do this.
JAMMA is an arcade standard for easy game conversion (very over-simplified explanation).  Look into this or similar for JAMMA compatability for your Neo-Geo:
http://www.jammaboards.com/store/neogeo-mvs-to-jamma-adapter/prod_198.html
From the above page to explain MVS vs. JAMMA compatability:
"All NeoGeo MVS units are almost fully JAMMA compatible; however, they have a small twist in their pinout scheme."
« Last Edit: January 13, 2009, 07:33:47 pm by DaveMMR »
Matsurigatzu
Re: Newbie here.
« Reply #5 on: January 13, 2009, 07:35:22 pm »
I appreciate it!
It is sold out but no worries. But i have no clue how to install it.
Should i just stick to buying regular MVS carts or go for the Jamma to play a lot of games?
hmmmmmmmm
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Newbie here.
« Reply #6 on: January 13, 2009, 07:42:29 pm »
It's your call really, depends if you really like Neo-Geo games or not. Remember that as it stands you will be limited to games that use 4 buttons or less and although the JAMMA standard is 3 buttons, you will be putting yourself out of some fighting games like MK or Street Fighter unless you install more buttons. If you're unsure, rip the lot out and MAME it.
Matsurigatzu
Re: Newbie here.
« Reply #7 on: January 13, 2009, 07:56:20 pm »
I would love to know how to mod these things out. Im extremely confused still about some things. But i am learning.
The left speaker on my Cab barely makes noise while the right is perfect.
Also,One side to the speaker case is open but the other is locked and i have no key. Any hints to unlocking it?
Ginsu Victim
  • Comanche, OK -- USA
Re: Newbie here.
« Reply #8 on: January 13, 2009, 08:02:00 pm »
Drill it out.
Matsurigatzu
Re: Newbie here.
« Reply #9 on: January 13, 2009, 08:05:26 pm »
Funny!
No,but really,easiest way to getting it unlocked without damaging the Machine.
MonMotha
Re: Newbie here.
« Reply #10 on: January 13, 2009, 08:06:08 pm »
If you can get to the back of the lock, even with difficulty, by far the easiest thing to do is undo the screw that holds on the cam.  That'll instantly "unlock" it, and you can open it up for further work.  If you can't get to the back, before you try to drill it, you might try the old "screwdriver and vise grips" approach.  It tends to be a little less messy, but it doesn't always work (and it WILL destroy the lock as badly as drilling it will).  Take a large flat-blade screwdriver and jam it in the lock, then clamp on a pair of vise-grips and turn as hard as you can; use a cheater bar (aka big piece of pipe) if necessary for more leverage.  Most locks will eventually fail.
If it's a round key type lock (the "high security" type), you're just about screwed.  There are special bits for drilling them out, but they are expensive and usually only work once or twice before they need replaced.  They're also not easy to get in some places as they are considered "locksmith tools".
Matsurigatzu
Re: Newbie here.
« Reply #11 on: January 13, 2009, 08:16:23 pm »
ok! i appreciate the advice!
One more thing :-)
How do i open up to see underneath the control sticks?
dreamakuma
  • Last login:July 08, 2010, 02:14:54 am
Re: Newbie here.
« Reply #12 on: January 13, 2009, 08:25:34 pm »
Usually you open up the coin door and reah around the underside of the panel, there should be some latches,unlatch them. If you can't open the coin door(I'm saying this since you are havin problems with locks elsewhere) try from the back. All five cabs I've worked around used this scheme.
Newbie in working on cabs, expert in playing, breaking, moving slowly, and overall failing at them too.
