Author Topic: T-molding  (Read 2247 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
T-molding
« on: January 10, 2009, 11:12:50 am »
i want neon green t-molding i need to know the cheapest out there and how to make the slot for it pls help
Franco B
Re: T-molding
« Reply #1 on: January 11, 2009, 04:35:30 am »
Google is your friend ;)
www.t-molding.com have [3/4'' Bright Green T-Molding (Galaxian) #24] priced at $0.50/ft (minimum order of 20ft).
You will need to buy/borrow a router and use a slotting cutter like this [Whiteside Slotting Cutter 1/16" 3-Wing] and also a arbour to hold the cutter like this [Whiteside Slotting Cutter Arbor 1/4" Shank, 2-3/8"OL].
