Author Topic: TV Tube Swap help  (Read 2735 times)
Paul Olson
    • Paul's Arcade
TV Tube Swap help
« on: January 08, 2009, 12:03:11 pm »
I am looking for TVs to try to swap. I have a 19k4915 and a 25k7191 that have some burn in. So far I have read that RCAs with dials are good candidates. Do you know of any others? Are there any TVs that work for most monitors? I am also trying to get some tech links about this so I have plenty of references, if you have any good links, please share them.
I have done a handful of capkits, but nothing else with monitors. Any tips would be appreciated.
Thanks,
Paul
Ken Layton
  • Guru
  • Technician
Re: TV Tube Swap help
« Reply #1 on: January 08, 2009, 12:27:10 pm »
Here are the links you need:
http://home.earthlink.net/~arcadeparts/index.html
http://www.8liners.com/datatech/monitor.html
http://www.rcilink.com/arcade/TubeSwap.htm
http://chux0r.org/20EZ.php
http://coinop.org/repair/Monitor_Tubeswap.aspx
Most 1980's and early 1990's tv sets seem to have pretty good candidate donor tubes in them. In general the tv's from the 80's that had pushbutton tuners seem to have exact replacement tubes as the original monitor! Granted the yokes may be different and/or bonded (glued to the tube) yokes.
« Last Edit: January 08, 2009, 01:02:19 pm by Ken Layton »
Paul Olson
    • Paul's Arcade
« Reply #2 on: January 08, 2009, 03:13:22 pm »
Thanks Ken, that helped a lot.
Paul Olson
    • Paul's Arcade
« Reply #3 on: January 09, 2009, 11:45:30 am »
Is there anything I need to watch out for when looking for a tube for the k4915? I don't know if there is a big difference in the tube for medium res. The tube in mine is M48AAW00xWMA. I found an RCA TV with an A48ABE10x, do you have any idea if this would work. All I know from the numbers is that the 48 means 19". I am looking for a Zenith TV that will hopefully use the same tube I have.
Thanks,
Paul
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 09, 2009, 01:35:57 pm »
The M48AAW uses socket adapter 23, but the A48ABE10X uses socket adapter 24. These tubes are not compatible with each other. Wired totally different.
Paul Olson
    • Paul's Arcade
« Reply #5 on: January 09, 2009, 03:12:41 pm »
Thanks for the information Ken. Do you happen to know what model TVs may have used the M48AAW00X?
Thanks,
Paul
Ken Layton
  • Guru
  • Technician
« Reply #6 on: January 09, 2009, 04:38:44 pm »
Nope.
Jack Burton
« Reply #7 on: January 09, 2009, 04:46:33 pm »
Ken, I've got a RCA lyceum TV with pushbuttons on the front.  The tube number and model are missing, or I would give them to you.
Do you think it would be a good candidate for a swap?
I have thinking about converting this TV so that I can connect arcade pcbs to it.  I think I might be able to swap the chassis and connect the monitor controls to the pots on the front for brightness, sharpness, tint, etc.
